Minature Two Wire Plug Sources, Where? Icon_minitimeby Strato50 Yesterday at 8:49 pm
Minature Two Wire Plug Sources, Where? Icon_minitimeby hachleopard2 Sat Sep 14, 2019 7:23 pm
Minature Two Wire Plug Sources, Where? Icon_minitimeby Jarlath Fri Sep 13, 2019 4:04 pm
Minature Two Wire Plug Sources, Where? Icon_minitimeby Strato50 Wed Sep 11, 2019 10:50 pm
Minature Two Wire Plug Sources, Where? Icon_minitimeby treemagnet Tue Sep 10, 2019 5:15 pm
Minature Two Wire Plug Sources, Where? Icon_minitimeby Strato50 Tue Sep 10, 2019 3:29 am
Minature Two Wire Plug Sources, Where? Icon_minitimeby knispel Tue Sep 10, 2019 1:21 am
Minature Two Wire Plug Sources, Where? Icon_minitimeby Negaduck Sun Sep 08, 2019 5:09 pm
Minature Two Wire Plug Sources, Where? Icon_minitimeby Strato50 Sat Sep 07, 2019 9:30 pm
Minature Two Wire Plug Sources, Where? I_vote_lcapMinature Two Wire Plug Sources, Where? I_voting_barMinature Two Wire Plug Sources, Where? I_vote_rcap
Minature Two Wire Plug Sources, Where? Empty
PostSubject: Minature Two Wire Plug Sources, Where?   Minature Two Wire Plug Sources, Where? Icon_minitimeWed Nov 26, 2014 9:24 pm
I was hoping someone could tell me where to look for miniature two wire plugs (+ & -)
I would like something durable that could be connected and disconnected frequently.
This would be to handle something like an emitter.
PostSubject: Re: Minature Two Wire Plug Sources, Where?   Minature Two Wire Plug Sources, Where? Icon_minitimeThu Nov 27, 2014 9:45 am
Glen,
I think Stince posted this a while ago but I can't find the original post but here is what I have from eBay. I am pretty sure this is the seller from Stince post and where I got mine from.
http://www.ebay.ca/itm/10-Pairs-22AWG-100mm-Cable-w-2Pin-JST-M-F-Plug-RC-Battery-Motor-Connection-/321222841692?pt=LH_DefaultDomain_0&hash=item4aca5f955c
PostSubject: Re: Minature Two Wire Plug Sources, Where?   Minature Two Wire Plug Sources, Where? Icon_minitimeThu Nov 27, 2014 12:43 pm
I got them there too. They work very well...
PostSubject: Re: Minature Two Wire Plug Sources, Where?   Minature Two Wire Plug Sources, Where? Icon_minitimeThu Nov 27, 2014 6:44 pm
PostSubject: Re: Minature Two Wire Plug Sources, Where?   Minature Two Wire Plug Sources, Where? Icon_minitimeFri Nov 28, 2014 9:51 am
Thanks
I was looking at something like this as a possibility to IR my HL Jagdpanther, which is airsoft.
I did not want to drill into the mantlet to install an emitter tube and was looking at options to use a removable barrel mount emitter, like I do on my KT.
I thought perhaps the emitter wires could be connected to a small plug hidden in the driver's vision port, to use to plug in a removable, barrel mounted emitter.
Minature Two Wire Plug Sources, Where? Img_2215
PostSubject: Re: Minature Two Wire Plug Sources, Where?   Minature Two Wire Plug Sources, Where? Icon_minitimeFri Nov 28, 2014 10:03 am
Glen, if you just need one set I can spare you one. I actually have my IR emitter installed IN the driver's vision slot on my JP.
PostSubject: Re: Minature Two Wire Plug Sources, Where?   Minature Two Wire Plug Sources, Where? Icon_minitimeFri Nov 28, 2014 10:07 am
I'm curious Glen why you want an external emitter mount over an in hull emitter?
PostSubject: Re: Minature Two Wire Plug Sources, Where?   Minature Two Wire Plug Sources, Where? Icon_minitimeFri Nov 28, 2014 10:16 am
To allow it to track the barrel elevation.
If you are referring to something hull mounted, at a fixed elevation, unless we are finding the need to elevate the emitter is not really necessary.  Then a hull mount would be a lot simpler.
PostSubject: Re: Minature Two Wire Plug Sources, Where?   Minature Two Wire Plug Sources, Where? Icon_minitimeFri Nov 28, 2014 10:19 am
Oops, missed that one when I read Dean's post.  Embarassed
And that works OK?, if it does, that would be the way to go.  I often mess up and find the gun, and emitter, have inadvertently been pointed at the sky, ineffectively.
PostSubject: Re: Minature Two Wire Plug Sources, Where?   Minature Two Wire Plug Sources, Where? Icon_minitimeFri Nov 28, 2014 10:22 am
With the fan pattern of normal emitters being AT LEAST a 20 degree cone, elevation tracking for the emitter is not really necessary in 99% of the firing positions we would have on our field... Not to metion those external emmitters are butt ugly! LOL!
PostSubject: Re: Minature Two Wire Plug Sources, Where?   Minature Two Wire Plug Sources, Where? Icon_minitimeFri Nov 28, 2014 10:24 am
No question there  Wink
This is looking more like the way to go if I get the JP field ready.
PostSubject: Re: Minature Two Wire Plug Sources, Where?   Minature Two Wire Plug Sources, Where? Icon_minitimeFri Nov 28, 2014 10:29 am
Glen, its kinda of like the Leo and the targeting system. In theory you should only be able to shoot at what you can see, and if you can't see where the gunner is or something similar, you probably should not be able to shoot at it. Good enough for me anyway, but of course it won't have as much of a fanning effect as if you mount it on the barrel.
PostSubject: Re: Minature Two Wire Plug Sources, Where?   Minature Two Wire Plug Sources, Where? Icon_minitimeFri Nov 28, 2014 11:14 am
MikeC wrote:
 my JP.
Mike, I was curious as to what you have for gearboxes in that one.
I like the look of these;
http://www.immortalhobbies.com/immortal-store.php#!/Steel-Gearbox-4-to-1-Ratio-long-shaft/p/43020064/category=10646609
But my experience shows they need to be lower than the Mato or Waltersons 3:1 because while they fit the Panther F upper hull, the configuration of the JP's upper hull does not allow enough room for the Mato or Waltersons.
PostSubject: Re: Minature Two Wire Plug Sources, Where?   Minature Two Wire Plug Sources, Where? Icon_minitimeFri Nov 28, 2014 11:53 am
Glen,
Here is couple of pics of my JP. I used the Taigen all metal lower and I think the gearbox came with it I think or I just transplanted my stock HL one. You can also see the location of the IR emitter in the driver's vision slot. It spent the day at Oshawa as a loaner for people to try out and it worked okay as far as I can tell.
Minature Two Wire Plug Sources, Where? <a href=Minature Two Wire Plug Sources, Where? Dscn0810" />
Minature Two Wire Plug Sources, Where? <a href=Minature Two Wire Plug Sources, Where? Dscn0811" />
Minature Two Wire Plug Sources, Where? <a href=Minature Two Wire Plug Sources, Where? Dscn0812" />
PostSubject: Re: Minature Two Wire Plug Sources, Where?   Minature Two Wire Plug Sources, Where? Icon_minitimeFri Nov 28, 2014 11:59 am
Thanks, Mike
Those look like the stock HL's with the zinc cast gears.
I guess if the upgrades don't fit, those a cheap enough, they could be replaced in kind, if or when they wear out.
Here is the fitting question about the upgrades in the link I posted.
The upgrade is in the upper photo, a stock Panther Gearbox is in the bottom, the height and motor configuration are critical to getting gearboxes into the JP, it is tough to tell from the picture of the upgrade if it will fit.  Curtis has offered to let me check this out on Dec. 6th.
Minature Two Wire Plug Sources, Where? Gearbo10
