Clark Elevation Question Icon_minitimeby Negaduck Today at 8:01 pm
» For a laugh....
Clark Elevation Question Icon_minitimeby MikeC Today at 10:18 am
Clark Elevation Question Icon_minitimeby Airbrushler Yesterday at 5:33 pm
Clark Elevation Question Icon_minitimeby Strato50 Wed Sep 18, 2019 8:49 pm
Clark Elevation Question Icon_minitimeby hachleopard2 Sat Sep 14, 2019 7:23 pm
Clark Elevation Question Icon_minitimeby Jarlath Fri Sep 13, 2019 4:04 pm
Clark Elevation Question Icon_minitimeby Strato50 Wed Sep 11, 2019 10:50 pm
Clark Elevation Question Icon_minitimeby treemagnet Tue Sep 10, 2019 5:15 pm
Clark Elevation Question Icon_minitimeby Strato50 Tue Sep 10, 2019 3:29 am
Clark Elevation Question I_vote_lcapClark Elevation Question I_voting_barClark Elevation Question I_vote_rcap
Clark Elevation Question Empty
PostSubject: Clark Elevation Question   Clark Elevation Question Icon_minitimeWed May 20, 2015 10:01 pm
Hi Guys,
I'm in the process of switching my Clark board out of my old T-34 and into the new one.
The old one never had elevation, so I'm hooking the new one up to the stock HL one. I have everything working on the tank fine, but the elevation motor only goes one way.
I thought the Clark boards gave you control of up and down without cycling all the way around?
PostSubject: Re: Clark Elevation Question   Clark Elevation Question Icon_minitimeWed May 20, 2015 10:48 pm
clark board does give you that option if you have it as a servo. It plugs in next to the recoil servo I believe.mike has done these and can pipe in here...
PostSubject: Re: Clark Elevation Question   Clark Elevation Question Icon_minitimeWed May 20, 2015 10:50 pm
Stince, did you do the re-wiring ?
 HL Gun Elevation and AirSoft Correction
In HL original design, gun Elevation and AirSoft sharing same driving H/W, so the gun elevation can only be controlled  in one direction, if you missed the angle you want, you will need to wait a full cycle of gun elevation, to correct this problem, we add dedicate AirSoft control h/w to TK20 board. the following shows you how to correct HL tank and get two direction elevation.
The picture below is original wiring in HL tank:
Clark Elevation Question Cn9_ori
Modify it as the following:
Clark Elevation Question Cn9_mod2
PostSubject: Re: Clark Elevation Question   Clark Elevation Question Icon_minitimeThu May 21, 2015 10:16 am
I never really figured out that issue with a couple of my Clarks... most of my tanks it will go up and down, but a couple.. it only goes when I go 'left' on my stick. I pretty much gave up lol Razz
PostSubject: Re: Clark Elevation Question   Clark Elevation Question Icon_minitimeThu May 21, 2015 2:22 pm
Well HL use the same Pos(+) for both the elevation and Airsoft so both motors can only going one way. Clark's diagram basically switches the Airsoft (+) to tap into the MG/Light so now elevation has its own Pos(+) and can be controlled/reversed. If you are not using Airsoft than the Airsoft connection on Clark became the AUX power for driving other things, like laser LED etc.
PostSubject: Re: Clark Elevation Question   Clark Elevation Question Icon_minitimeFri May 22, 2015 11:08 am
Yea, I think it's a matter of not having rewired those tanks completely from the ground up, and simply not realizing it. I haven't looked in ages! Razz
