Stince's Sherman Icon_minitimeby hachleopard2 Yesterday at 7:23 pm
Stince's Sherman Icon_minitimeby Jarlath Fri Sep 13, 2019 4:04 pm
Stince's Sherman Icon_minitimeby Strato50 Wed Sep 11, 2019 10:50 pm
Stince's Sherman Icon_minitimeby treemagnet Tue Sep 10, 2019 5:15 pm
Stince's Sherman Icon_minitimeby Strato50 Tue Sep 10, 2019 3:29 am
Stince's Sherman Icon_minitimeby knispel Tue Sep 10, 2019 1:21 am
Stince's Sherman Icon_minitimeby Negaduck Sun Sep 08, 2019 5:09 pm
Stince's Sherman Icon_minitimeby Strato50 Sat Sep 07, 2019 9:30 pm
Stince's Sherman Icon_minitimeby Airbrushler Sat Sep 07, 2019 8:15 pm
Stince's Sherman I_vote_lcapStince's Sherman I_voting_barStince's Sherman I_vote_rcap
 Stince's Sherman
Go to page : 1, 2, 3, 4  Next
Stince's Sherman Empty
PostSubject: Stince's Sherman   Stince's Sherman Icon_minitimeSun Jun 10, 2012 10:43 pm
Here is a Can-Am exclusive - my Sherman build! Very Happy
So here is the plan: replace the gearboxes with metal one, install a SLU, replace the road wheels with metal ones, replace Tranny cover, add a cast metal effect to the hull, recoil? (not sure what to do yet), change the barrel, paint and weather. I think that might cover it. scratch
This won't be the fast of builds, because of limited time being used by two busy kids, but the goal is to have it ready for the July BattleDay, hopefully.
First step - Break down the Sherman, strip away the old electronics and dremel away any unwanted plastic posts.
Stince's Sherman DSC00037
Next was the gearboxes. I decided to use the 3:1 Tiger 2.0 gears.
Stince's Sherman DSC00039
I cut about 3/4" strip out of center of the metal mounting plate that comes with gears. After some careful alignment, I then epoxy the plates in place.
Stince's Sherman DSC00045
After the epoxy had set and hard I install the gearboxes. They fit very nice and no problem with hitting the tranny cover. I thought this part would give me the most problem, but was surprisingly easy. The Sherman's drive spockets are a tight fit but they do fit the Tiger's drive shafts. I don't think these gearboxes will give the speed the Sherman should have, but I can always replace the motors.
Stince's Sherman DSC00057
Stince's Sherman DSC00058
While I was at it I also switch out the road wheels on one side with the metal ones with suspension just to see how they will work. These new ones are really nice and easy to install.
Stince's Sherman DSC00059
PostSubject: Re: Stince's Sherman   Stince's Sherman Icon_minitimeSun Jun 10, 2012 11:11 pm
While I was waiting for the epoxy to dry, I thought I would try out the cast metal effect.
I'm using a product call Mr. Surfacer 500. This stuff has a strong smell, so use it in a well vented area or when the wife is away. Very Happy
Stince's Sherman DSC00038
To use it, just cut up some sponges, dip it in the solution and dab the area you want until the sponge becomes dry.
Here is a sample piece I did on the battery cover to see how it would work. It not the best picture Embarassed , I'll take more when I do the hull.
Stince's Sherman DSC00044
PostSubject: Re: Stince's Sherman   Stince's Sherman Icon_minitimeSun Jun 10, 2012 11:31 pm
Also an interesting side note that might useful to Captain Action.
I was curious to see what the gears look like in the in the plastic gearboxes, so I open one and they look like they maybe the same size as some the gears from the stock metal gears from the HL's. I wished I know that before I cut out all the mounts, I would've tried and save the other gears for my Tiger. Oh well, live and learn.
Another blurry pic Embarassed
Stince's Sherman DSC00047
Stince's Sherman DSC00049
PostSubject: Re: Stince's Sherman   Stince's Sherman Icon_minitimeMon Jun 11, 2012 12:30 am
This looks fantastic, I definitely know a Sherman is my next tank! I love the mato hull Smile
PostSubject: Re: Stince's Sherman   Stince's Sherman Icon_minitimeTue Jun 19, 2012 12:00 am
Did a little work on the Sherman. The metal suspension from Mato come with their name stamped on the side with some numbers.
I decided to remove these. It was an easy job, just a quick clean up with the dremel and now are ready for paint. Very Happy
Stince's Sherman DSC00042
The red circle show where the letters and numbers.
Stince's Sherman DSC00043
All cleaned up and ready for paint.
Next step is the cast metal effect on the hull and turret.
PostSubject: Re: Stince's Sherman   Stince's Sherman Icon_minitimeWed Jun 20, 2012 9:09 pm
Did the cast metal effect yesterday using Mr. Surfacer 500. This stuff drys pretty quick and has a strong smell, so use it where there is good ventilation.
It was quite easy, first I strip the hull and turret of any removable parts and then used some painters masking tape to cover the areas that I didn't want affected.
I cut a sponge into some pieces dipped them in the bottle and dabbed small areas at a time until the sponge became dry, then grabbed new piece of sponge and tart anew area bleeding it in..
Stince's Sherman IMG_0676
Stince's Sherman IMG_0677
Stince's Sherman IMG_0680
Stince's Sherman IMG_0686
Stince's Sherman IMG_0688
Stince's Sherman IMG_0690
Now I just have to add some parts back on it and it will be ready for paint. Very Happy
PostSubject: Re: Stince's Sherman   Stince's Sherman Icon_minitimeWed Jun 20, 2012 9:29 pm
On a side note.. Just ordered my Mato Sherman Wink
I really like the surface effect! Where'd you get it?
real_hulu
real_hulu
PostSubject: Re: Stince's Sherman   Stince's Sherman Icon_minitimeWed Jun 20, 2012 9:38 pm
wait... where did you order that?
I think matomart is still out of stock.
PostSubject: Re: Stince's Sherman   Stince's Sherman Icon_minitimeWed Jun 20, 2012 10:31 pm
I order it from ebay, it's a real hard product to find in North America. It came from Hong Kong and took about a month regular mail.
real_hulu
real_hulu
PostSubject: Re: Stince's Sherman   Stince's Sherman Icon_minitimeThu Jun 21, 2012 3:07 pm
You need change the barrel. Very Happy
PostSubject: Re: Stince's Sherman   Stince's Sherman Icon_minitimeThu Jun 21, 2012 5:38 pm
RcTankWars, from mr Phil.
He had the special of the tank without the Mato guts and I wanted one a couple months ago. He just got a few more Razz
PostSubject: Re: Stince's Sherman   Stince's Sherman Icon_minitimeThu Jun 21, 2012 6:30 pm
How much without the guts if you don't mind me asking?
PostSubject: Re: Stince's Sherman   Stince's Sherman Icon_minitimeThu Jun 21, 2012 6:38 pm
I believe he had it on there for $105. There may even be some left Razz
I had him install some 'custom' 3:1s (now that I see stince's build, I don't know why..) and also got some motors for my heavies Razz
PostSubject: Re: Stince's Sherman   Stince's Sherman Icon_minitimeThu Jun 21, 2012 6:58 pm
Ya, that fat barrel is really buggy me.
I think I will cut it off and use the metal insert tube that's used for shooting the BB's for the barrel for now. It's closer to the proper size.
I'm also thinking of cutting down the extra ring on the turret at the bottom.
PostSubject: Re: Stince's Sherman   Stince's Sherman Icon_minitimeThu Jun 21, 2012 10:38 pm
I still have original barrel from my Panzer III L and it look to be the right size, at least better than what they have on it.
From what I could fine the barrel lenght on a Sherman 75mm is 67.7" long, not sure about the 76mm. If you scale that down it works to be about 4.23". The lenght of the Panzer barrel is almost 4.5", which pretty close.
What do you guys think? confused
real_hulu
real_hulu
PostSubject: Re: Stince's Sherman   Stince's Sherman Icon_minitimeFri Jun 22, 2012 11:11 am
No idea, I don't know the barrel length.. the simple way is order one from the guy who made the barrel for Tim's Sherman. But it may cost 20$ including the shipping/
So how many Sherman in our club. 3 or 4...
We will see more tanks roll over on the field. Very Happy
Stince's Sherman IMG_0552
PostSubject: Re: Stince's Sherman   Stince's Sherman Icon_minitimeSat Jun 23, 2012 4:48 pm
Stince's Sherman Sherma10
PostSubject: Re: Stince's Sherman   Stince's Sherman Icon_minitimeSun Jun 24, 2012 8:25 am
Rolling would be a desirable manoeuvre................................................if we were an r/c flying club Wink
No Shermans for me, guaranteed I's roll one at least once or twice/meet Embarassed Laughing Laughing
PostSubject: Re: Stince's Sherman   Stince's Sherman Icon_minitimeTue Jun 26, 2012 11:39 pm
Today I decided to get ride of the extra ring at the bottom of the turret that Mato put in to make room for their airsoft gun.
Here is a before and after.
Before
Stince's Sherman IMG_0689
After
Stince's Sherman DSC00032
It wasn't to difficult to do, but I forgot to take picture while I was cutting, so hopefully I can explain this clearly.
First I cut around the bottom edge using a small sawblade ( the kind that fits on an extco handle). You will need to put in a notch on the bottom plate where the one back post meets and remove the front lip on the bottom part too.
Stince's Sherman DSC00030
Stince's Sherman DSC00031
Next I sanded both pieces smooth and than epoxy them together.
Stince's Sherman DSC00036
To fit the two halves together you will need to remove about 3/16" from three of the post on the top half or you will have a gap.
Stince's Sherman DSC00035
Once your done It makes the tank so much better looking. Very Happy
Stince's Sherman DSC00034
Stince's Sherman DSC00033
But now the seam in the turret from the two halves is bugging me. Hopefully when it's painted it won't be so noticeable. Suspect
PostSubject: Re: Stince's Sherman   Stince's Sherman Icon_minitimeThu Jun 28, 2012 6:22 pm
Small update!
I made some vent covers for what I'm guessing is the air in-take(?).
Stince's Sherman Vent
PostSubject: Re: Stince's Sherman   Stince's Sherman Icon_minitimeThu Jun 28, 2012 11:16 pm
I chopped off the dumb oversize barrel and found a replacement for now.
Stince's Sherman BDSC00030
Here is the difference between the barrels.
Stince's Sherman BDSC00040
Can you guess where the new barrel came from? Wink
PostSubject: Re: Stince's Sherman   Stince's Sherman Icon_minitimeThu Jun 28, 2012 11:19 pm
i like it the one off your PIII
PostSubject: Re: Stince's Sherman   Stince's Sherman Icon_minitimeThu Jun 28, 2012 11:21 pm
Bingo!! You got it! cheers
of the Pan-Tiger Panzer Div.
PostSubject: Re: Stince's Sherman   Stince's Sherman Icon_minitimeFri Jun 29, 2012 8:16 pm
Looks good ,I must chop my Sherman top one day too....
The Great Pan-Tiger pirat
PostSubject: Re: Stince's Sherman   Stince's Sherman Icon_minitimeFri Jun 29, 2012 10:20 pm
Thanks Captain!
It's coming along slow. Just have to figure out the 3 piece tranny, then ready for paint.
Stince's Sherman
Page 1 of 4Go to page : 1, 2, 3, 4  Next
