» Hello new here by Hammertime999999999 Today at 6:49 am
Posts : 54 Join date : 2014-12-09 Location : Grande Prairie
Subject: Battle Armor Cromwell. Tue Jul 07, 2015 9:29 am
Here are some pictures of a Cromwell I fabbed up using the hull off of a T-34 and the top have of Christians Cromwell kit. I had to center the middle wheel on each side and I modded the T-34 wheels with some home cast inserts.
I have very seriously considering buying the kit from Ludwig, but I have concerns with the lower chassis. This basically solves all the worries, and you can even use a Taigen metal lower T34 if you so choose. Really brilliant stuff Dan.
BattleArmorRC Private
You have to cut out the center suspension mount and move it equidistant to the other wheels, so I would suggest you stick with a Heng Long hull. I fashioned a needle point to my soldering iron and I was able to easily remove the center suspension assembly and move it forward.
This plus a little work around the rear end and the T-34 hull is a natural fit for this kit.
I would be hard pressed to sell this. Much effort and uniqueness mean this a keeper for me. Sorry guys, but thank you for the nice comments.
However for a project base tank this is a nice kit, and I would recommend it. I did have to do a lot of custom resin castings to finish it off as well though so prepare to be resourceful. Probably the most work I have ever put into a tank
Subject: Re: Battle Armor Cromwell. Wed Aug 05, 2015 12:31 am
Here is the Cromwell in motion. BARC4 with Benedini. It runs strong in the grass
