» For a laugh....
RS-395 Brushed DC Motor : Review! Icon_minitimeby MikeC Today at 10:18 am
RS-395 Brushed DC Motor : Review! Icon_minitimeby MikeC Today at 12:01 am
RS-395 Brushed DC Motor : Review! Icon_minitimeby Airbrushler Yesterday at 5:33 pm
RS-395 Brushed DC Motor : Review! Icon_minitimeby Strato50 Wed Sep 18, 2019 8:49 pm
RS-395 Brushed DC Motor : Review! Icon_minitimeby hachleopard2 Sat Sep 14, 2019 7:23 pm
RS-395 Brushed DC Motor : Review! Icon_minitimeby Jarlath Fri Sep 13, 2019 4:04 pm
RS-395 Brushed DC Motor : Review! Icon_minitimeby Strato50 Wed Sep 11, 2019 10:50 pm
RS-395 Brushed DC Motor : Review! Icon_minitimeby treemagnet Tue Sep 10, 2019 5:15 pm
RS-395 Brushed DC Motor : Review! Icon_minitimeby Strato50 Tue Sep 10, 2019 3:29 am
RS-395 Brushed DC Motor : Review! I_vote_lcapRS-395 Brushed DC Motor : Review! I_voting_barRS-395 Brushed DC Motor : Review! I_vote_rcap
RS-395 Brushed DC Motor : Review! Empty
PostSubject: RS-395 Brushed DC Motor : Review!   RS-395 Brushed DC Motor : Review! Icon_minitimeFri Aug 28, 2015 1:12 am
Hello all. I just installed a pair of motors that I haven't tried before so here's a brief review and summary of my thoughts.
The motors in question are listed as "Banebots 12V 15500rpm, 16.65oz-in" on robotshop.com and "RS395 Motor - 12V" on Banebots.com
http://www.robotshop.com/ca/en/baneb...-dc-motor.html
http://banebots.com/pc/MOTOR-BRUSH/M3-RS395-12
Specs are listed more thoroughly on banebots:
[th]Performance[/th]
ModelM5-RS395-12
Operating v: 5v - 15v
Nominal v: 12v
No Load RPM: 15500
No Load A: 0.5A
Stall Torque: 16.65 oz-in117.6 mN-m
Stall Current: 15A
Kt: 1.11 oz-in/A7.8 mN-m/A
Kv: 1292 rpm/V
Efficiency: 75.8%
RPM - Peak Eff: 13110
Torque - Peak Eff: 3.04 oz-in21.5 mN-m
Current - Peak Eff: 2.7A
[th]Physical[/th]
Weight: 3.4 oz(96g)
Length - for motor: 1.83 in(46.6mm)
Diameter (with flux ring): 1.13 in(28.8mm)
Diameter (no flux ring): 1.08 in(27.5mm)
ShaftDiameter: 0.09 in(2.3mm)
Shaft Length: 0.3 in(7.6mm)
Mounting Screws (2)M2.6
RS-395 Brushed DC Motor : Review! Attachment
Anyhow I 'discovered' this motors while watching a youtube video going over the various aspects of the new RcTank.de Panther metal lower hull. It made mention that the motors are significantly longer than stock, so even in a wide Panther I had to slightly bend the wire tabs so they would not touch the opposite gearbox.
Performance wise.., these motors are SLOW. Significantly slower than the stock motors that came with my steel 4:1 Taigen-ish gearboxes from rctank.de. I don't know those specs so I cannot compare. My Panther is running ~25-30% slower than previous. This is a total crawler now. However the torque increase is immense! I was crawling over rocks, through thick uncut grass and embankments and the tank did not hesitate. I can control the speed of a very-slow crawl with these motors to an extent I have not had before. I'm impressed. The tank will crawl without stuttering at scale half walking speed. Very cool
A note on noise; previously this tank was giving the all too typical squeal and rattle that Heng Long style gearboxes give off under various loads. In certain turns, reverse, one gearbox or the other invariably gives off sound. Not anymore. It may be a fluke in how I installed the motors, or reset the pinions, but this tank sounds like the low hum of 2 high torque motors and metal tracks. The gearbox sound has been reduced ~90%. The only tank I own that makes less sound is my Mato Sherman with brass gears, and it's nearly as slow and half the weight!
In summary I would recommend these motors for very heavy tanks with 4:1 gearboxes, metal-hulled tanks under 14lb with 3:1 gearboxes or any tank you want to be quiet & drive incredibly scale.
If you're in Canada I recommend robotshop.com, they carry a bunch of useful stuff including servos and motors, inexpensive shipping and fast delivery.
Up next, the RS380 Motor - 7.2V motor from Banebots... nearly as much torque but 1.75x the RPM. A medium tanks dream!
-Jordan Kipp
Capp
Capp
PostSubject: Re: RS-395 Brushed DC Motor : Review!   RS-395 Brushed DC Motor : Review! Icon_minitimeFri Aug 28, 2015 7:49 am
Thank you for the review Jordan they sound like a fit for something I am building and hopeing to show at the next battle day if I can get there.
