Tamiya MF-01 unit question Icon_minitimeby hachleopard2 Yesterday at 7:23 pm
Tamiya MF-01 unit question Icon_minitimeby Jarlath Fri Sep 13, 2019 4:04 pm
Tamiya MF-01 unit question Icon_minitimeby Strato50 Wed Sep 11, 2019 10:50 pm
Tamiya MF-01 unit question Icon_minitimeby treemagnet Tue Sep 10, 2019 5:15 pm
Tamiya MF-01 unit question Icon_minitimeby Strato50 Tue Sep 10, 2019 3:29 am
Tamiya MF-01 unit question Icon_minitimeby knispel Tue Sep 10, 2019 1:21 am
Tamiya MF-01 unit question Icon_minitimeby Negaduck Sun Sep 08, 2019 5:09 pm
Tamiya MF-01 unit question Icon_minitimeby Strato50 Sat Sep 07, 2019 9:30 pm
Tamiya MF-01 unit question Icon_minitimeby Airbrushler Sat Sep 07, 2019 8:15 pm
Tamiya MF-01 unit question I_vote_lcapTamiya MF-01 unit question I_voting_barTamiya MF-01 unit question I_vote_rcap
Tamiya MF-01 unit question Empty
PostSubject: Tamiya MF-01 unit question   Tamiya MF-01 unit question Icon_minitimeWed Dec 02, 2015 1:19 pm
For all you Tamiya guys out there, question from a novice........ Is there a IR battle connection in the MF-01 unit, or do you need extra pieces of electronics to make it IR battle ready ? I know you need the base and apple and stuff, but I am just wondering if there is another piece of electronics control/board that you need or if the connection comes out of the MF-01 unit.
PostSubject: Re: Tamiya MF-01 unit question   Tamiya MF-01 unit question Icon_minitimeWed Dec 02, 2015 3:01 pm
I don't know if it helps
https://youtu.be/XvzEemaad40
PostSubject: Re: Tamiya MF-01 unit question   Tamiya MF-01 unit question Icon_minitimeWed Dec 02, 2015 6:32 pm
there is nothing else need if you want to wire it straight to the MF-01
PostSubject: Re: Tamiya MF-01 unit question   Tamiya MF-01 unit question Icon_minitimeWed Dec 02, 2015 7:49 pm
Hi Mike,
The Tamiya electronics consist of two parts, the MF board and the DMD board.
The receiver is a 5-pin plug that plugs into the CN1 slot and the IR is a 2-pin plugs into the CN2 slot, both are found on the MF board.
You can find the PFDs manuals for the tanks here. http://www.tamiya.com/english/rc/manuals.htm The tank manuals are near the bottom.
PostSubject: Re: Tamiya MF-01 unit question   Tamiya MF-01 unit question Icon_minitimeWed Dec 02, 2015 10:02 pm
Okay so I still need the DMD Control unit (T-03) even with this set then ? This is so confusing.
Tamiya MF-01 unit question <a href=Tamiya MF-01 unit question B7c78710" />
PostSubject: Re: Tamiya MF-01 unit question   Tamiya MF-01 unit question Icon_minitimeThu Dec 03, 2015 11:40 am
The DMD board is pretty much a ESC board, it controls the motors.
The SLU and the DBU were like that too, one board for the motors and one for rest of the features.
We are spoiled with all-in-one board from Clark.
PostSubject: Re: Tamiya MF-01 unit question   Tamiya MF-01 unit question Icon_minitimeThu Dec 03, 2015 12:13 pm
I like the fact that Tamiya cleverly hided the control board underneath the speaker so it looks like this kit is all you need to run the tank.
PostSubject: Re: Tamiya MF-01 unit question   Tamiya MF-01 unit question Icon_minitimeThu Dec 03, 2015 1:54 pm
Well technically it is an added option, because you could just run the tank with the DMD board, it just would have any sound, recoil, or IR  system.
Both boards are usually included in the kits, yours may of been an added option for an earlier kit that didn't include it.
If you bought it for the price on the box then that's a great deal, they are normally 3 times that amount.
PostSubject: Re: Tamiya MF-01 unit question   Tamiya MF-01 unit question Icon_minitimeFri Dec 04, 2015 9:35 pm
Okay, so if that's the case, then I could in theory use a Clark board as a ESC with 2 channels controlling the movement, and use the MF-01 for everything else then with the other two channels ?
A new Clark board is still cheaper than a Tamiya DMD controllers..........
