| Subject: Making my own Real Rust Sun Dec 06, 2015 7:02 pm | |
| _____________________________________________ |
Reaper332 Sgt-Major
| Subject: Re: Making my own Real Rust Sun Dec 06, 2015 7:15 pm | |
| Nice work mate..... very cool |
| Subject: Re: Making my own Real Rust Sun Dec 06, 2015 7:20 pm | |
| Thanks Brother took a while to make just what you see...lol _____________________________________________ |
Reaper332 Sgt-Major
| Subject: Re: Making my own Real Rust Sun Dec 06, 2015 7:30 pm | |
| Yeah I bet .... going to do up the step by step pics today on the rust technique I did on the JT |
| Subject: Re: Making my own Real Rust Sun Dec 06, 2015 7:38 pm | |
| That's cool cause they look real , Awesome job _____________________________________________ |
Al.M Retired
Posts : 75 Join date : 2015-09-14 Age : 66 Location : Cambridge
| Subject: Re: Making my own Real Rust Mon Dec 07, 2015 5:56 am | |
| What did you use to set the rust? Just a mat varnish? _____________________________________________ King Tiger, Sherman. All under construction. Now also T34/85 |
| Subject: Re: Making my own Real Rust Mon Dec 07, 2015 8:11 am | |
| yep just the frosted clear we use to clear the tanks just sprayed some in a tuna can and dipped the brush in the clear to pick up the rust to apply _____________________________________________ |
Al.M Retired
| Subject: Re: Making my own Real Rust Tue Dec 08, 2015 8:17 am | |
| Ok. Im not familiar with the frosted clear you are speaking of. _____________________________________________ King Tiger, Sherman. All under construction. Now also T34/85 |
| Subject: Re: Making my own Real Rust Tue Dec 08, 2015 10:15 pm | |
| they have it at Canadian tire you have to read on the side to make sure it's the clear they have another that has a hint of green in it _____________________________________________ |
Al.M Retired
| Subject: Re: Making my own Real Rust Wed Dec 09, 2015 5:41 am | |
| Ok. Great. Thank you. I will give it a try. That's probably why i couldn't match the effect on the T34. _____________________________________________ King Tiger, Sherman. All under construction. Now also T34/85 |
kaptain Jack Staff Sergeant
| Subject: Re: Making my own Real Rust Wed Dec 09, 2015 8:52 am | |
| Are you using it as a clear coat? |
Al.M Retired
| Subject: Re: Making my own Real Rust Wed Dec 09, 2015 10:17 am | |
| Not sure who that was aimed at kaptain but if it is me. Should I not? _____________________________________________ King Tiger, Sherman. All under construction. Now also T34/85 |
| Subject: Re: Making my own Real Rust Wed Dec 09, 2015 1:23 pm | |
| - Airbrushler wrote:
- they have it at Canadian tire you have to read on the side to make sure it's the clear they have another that has a hint of green in it
Greg, do you use this as a flat coat or a sealant ? Does it chemically melt anything ? |
| Subject: Re: Making my own Real Rust Wed Dec 09, 2015 7:53 pm | |
| I've used that too and it's not bad, it adds a matte finish.
I thinkkkkk I've had it bubble on me a tiny bit but I cannot be sure. _____________________________________________ Tiger I - Panzer II - Panzer III - Panzer IV - Chi Nu Kai - Panther G - KV-1b 756(r) M4A3(76) Sherman - T-34/85 - M3 Grant - SECRET PROJECT
| Subject: Re: Making my own Real Rust Wed Dec 09, 2015 8:28 pm | |
| i use it on my whole tanks to seal it but this tank was already done with the clear coat before. To add the rust i sprayed some of the clear into a small container i dipped my brush in it to wet the brush and then dipped it into the rust and then applied it to the tank _____________________________________________ |
| Subject: Re: Making my own Real Rust Thu Dec 10, 2015 12:07 am | |
| Greg so you use this as the flat finishing coat after everything is done ? It will be a lot cheaper than buying clear flat sprays from Tamiya or Testor. |
| Subject: Re: Making my own Real Rust Thu Dec 10, 2015 2:40 am | |
| yes i use it on all tanks just make sure it is the clear and not the one with the green tint in it i know Glen uses it to he is the one the first suggested using this as a flat clear for the tanks _____________________________________________ |
| Subject: Re: Making my own Real Rust Thu Dec 10, 2015 8:41 am | |
| Okay will give it a try. Thanks !
I might even have some in the basement........... |
Al.M Retired
| Subject: Re: Making my own Real Rust Thu Dec 10, 2015 2:27 pm | |
| I just went out and got some. Sprayed it on a cut out battery box piece and so far no adverse effects on the plastic at all. Will see again in a couple hours. I would say though i would think it would have done something by now if it was going to since it is dry _____________________________________________ King Tiger, Sherman. All under construction. Now also T34/85 |
| Subject: Re: Making my own Real Rust Thu Dec 10, 2015 3:14 pm | |
| I am not worry about unfinished plastic. More worry about decals and also acrylic painted surfaces. Will give it a try on something I don't care much for and see what happens. |
Al.M Retired
| Subject: Re: Making my own Real Rust Fri Dec 11, 2015 11:14 am | |
| well have 2 coats on the tank and it did not bother the paint or decals. Just did not give me the effect that i was thinking it would. Beginner here thought it was going to give me that dusty look. at this point it still looks the same _____________________________________________ King Tiger, Sherman. All under construction. Now also T34/85 |
| Subject: Re: Making my own Real Rust Fri Dec 11, 2015 2:53 pm | |
| I only expected it to give a flat coat overall. If you want dusty look you might want to use Buff diluted on air brush or Testor has a spray can called Smoke. If you are not good at weathering like I do, Tamiya's paint master kits are great. You do heave to seal it after you are done, with the aforementioned frost window spray. |
Al.M Retired
| Subject: Re: Making my own Real Rust Fri Dec 11, 2015 4:14 pm | |
| Ok dumb questions. What is buff and how do you get that dusty gray look like on the tank in this post. _____________________________________________ King Tiger, Sherman. All under construction. Now also T34/85 |
| Subject: Re: Making my own Real Rust Fri Dec 11, 2015 4:39 pm | |
| Dean is the expert on weathering but this is whatI was referring to: [img] [/img] |
Al.M Retired
| Subject: Re: Making my own Real Rust Fri Dec 11, 2015 5:37 pm | |
| Ok great. Dean you can chime in any time. LOL. I need to match the weathering on the T34 I bought and want the same effect on the King Tiger _____________________________________________ King Tiger, Sherman. All under construction. Now also T34/85 |
| Subject: Re: Making my own Real Rust | |
