Tiger Power Second Lieutenant
| Subject: spin spin spin Wed Jan 20, 2016 2:05 pm | |
| i talked to dean at the show about my KT he said it was normal, not that I don't believe him, its just none of my other tanks do it so before I get mad and run it over or sell it I wanted to ask you all your thoughts. I got my board in the mail today to be able to battle you guys but dont want to waste the time putting it in if its going to keep acting up, rather save it for a good tank. it drives fine then if I turn it some times randomly spins even if Iam off the controller I have had it spin up to 5 times non stop.. the trims are fine everything looks good. I don't think its a low voltage thing. this tanks been frustrating _____________________________________________ Tiger PowerDer Tiger ist auf dem losen |
| Subject: Re: spin spin spin Wed Jan 20, 2016 2:16 pm | |
| No, you don't believe me. What you are describing now is not what I understood. Basically what I said was the RX-18's have superspin so if you push you stick over they will spin in place. What you are describing where it spins on its own off the controller sounds like a signal thing to me but for sure it is something that shouldn't be happening... _____________________________________________ "There are things in Russia which are not as they seem..." Georgy Konstantinovich Zhukov
| Subject: Re: spin spin spin Wed Jan 20, 2016 2:36 pm | |
| Subject: Re: spin spin spin Wed Jan 20, 2016 2:39 pm | |
| Subject: Re: spin spin spin Wed Jan 20, 2016 2:41 pm | |
| Kyle,
Try swapping the electronics with your Taigen Tiger or your other Heng Long and see if the KT still do the same thing (it shouldn't). and if the the other tank start doing it you know it is the electronics. I think your KT is only one on 27Mhz crystals, right ? The other 2 is on 2.4Ghz ?
All of your electronics (Heng Long 27Mhz/2.4Ghz, Taigen 2.4Ghz) will work with the Mako board to be IR ready.
I will be in K/W this Sunday, if you want leave the KT and the Mako with me and I will put it together for you. |
| Subject: Re: spin spin spin Wed Jan 20, 2016 3:18 pm | |
| that's not funny mike that poor tiger and yah that's fine I work till 4 on sunday not sure when you in area _____________________________________________ Tiger PowerDer Tiger ist auf dem losen |
| Subject: Re: spin spin spin Wed Jan 20, 2016 3:53 pm | |
| Probably around 6pm to be confirmed. We usually meet in the north end at the Tim's on Victoria Street N just east of Cognestoga Pkwy. |
| Subject: Re: spin spin spin Wed Jan 20, 2016 4:11 pm | |
| On Victoria the one near Kw surplus? In the gas station. Or do you mean vic and Westmount. _____________________________________________ Tiger PowerDer Tiger ist auf dem losen |
| Subject: Re: spin spin spin Wed Jan 20, 2016 4:15 pm | |
| Victoria and Bingmans. _____________________________________________ "There are things in Russia which are not as they seem..." Georgy Konstantinovich Zhukov
| Subject: Re: spin spin spin Wed Jan 20, 2016 4:17 pm | |
| Oh ok. Not really near the express way lol. _____________________________________________ Tiger PowerDer Tiger ist auf dem losen |
| Subject: Re: spin spin spin Wed Jan 20, 2016 4:18 pm | |
| Further east. The standalone one on Victoria N and Lackner. 1475 Victoria St N. I am coming in from Guelph don't want to get too deep into K/W and have to deal with traffic |
| Subject: Re: spin spin spin Wed Jan 20, 2016 4:20 pm | |
| Lol Guelph traffic worse . _____________________________________________ Tiger PowerDer Tiger ist auf dem losen |
| Subject: Re: spin spin spin Wed Jan 20, 2016 6:54 pm | |
| Make sure whatever board you are giving me with the KT that it actually works properly. |
| Subject: Re: spin spin spin Wed Jan 20, 2016 8:11 pm | |
| Sounds very much like crappy signal issues, either voltage drops or a crystal is loose and rattling around. Hard to say otherwise without wire cutters and a soldering iron.
It's Taigen electronics? _____________________________________________ Tiger I - Panzer II - Panzer III - Panzer IV - Chi Nu Kai - Panther G - KV-1b 756(r) M4A3(76) Sherman - T-34/85 - M3 Grant - SECRET PROJECT
| Subject: Re: spin spin spin Thu Jan 21, 2016 7:08 pm | |
| Okay I am confirmed to be in K/W for 6pm on Sunday. Kyle, if you want to bring the KT I can install either the new MAKO board or one of mine for you. I can probably do it there but make plans for me to take the tank and the board with me. If you want to bring you other tank I can also try to get them IR battle ready as well, depended on whether there is already mounts and stuff.
It will cost you, of course, parts only, so nothing a free lunch and dinner won't cover. |
| Subject: Re: spin spin spin Fri Jan 22, 2016 8:43 am | |
| Lol Mike, Ya no problem, and I only got the one ir tank. It works fine just don't under stand the spin problem it has _____________________________________________ Tiger PowerDer Tiger ist auf dem losen |
| Subject: Re: spin spin spin Fri Jan 22, 2016 9:10 am | |
| Kyle, most of the BB tanks has the IR mount and stuff set-up and you can have both BB and IR set-up on them. Just make sure you don't have BBs in the gun when you are doing IR battle. All the electronics have IR and BB functions, just not the emitters and receivers which are external anyway. If you want two IR tank to battle each other I can try to set that up for you.
Just have a look at the T34 and the Tiger and see which one have the mounts already in them. That would make them easier to put IR on as well.
You kinda need 2 IR tank to be able to battle............ |
| Subject: Re: spin spin spin Fri Jan 22, 2016 9:18 am | |
| - Strato50 wrote:
- Sounds very much like crappy signal issues, either voltage drops or a crystal is loose and rattling around. Hard to say otherwise without wire cutters and a soldering iron.
It's Taigen electronics? There is also the possibility that the wire from the antenna wire maybe loose or disconnected. Does the tank get weirder the farther the way the controller gets? _____________________________________________ HL Panzer III | HL Tiger | HL Jagdpanther | HL Panther | Mato Sherman Hooben Elefant | HL Pershing | HL Bergepanzer IV | Tamiya Leopard 1A | WSN T-34 HL "Golden" Pan-Tiger | M16 Halftrack | HL Panzer IV | Tamiya KV-1 | Tamiya Tiger
| Subject: Re: spin spin spin Fri Jan 22, 2016 10:42 am | |
There is also the possibility that the wire from the antenna wire maybe loose or disconnected. Does the tank get weirder the farther the way the controller gets? ^^^ Sounds like a very probable situation. _____________________________________________ Tiger I - Panzer II - Panzer III - Panzer IV - Chi Nu Kai - Panther G - KV-1b 756(r) M4A3(76) Sherman - T-34/85 - M3 Grant - SECRET PROJECT
| Subject: Re: spin spin spin Fri Jan 22, 2016 11:22 am | |
| no difference at distance and no its a HL board it happens randomly too not all the time, when mike comes down he can test drive it and see what I mean _____________________________________________ Tiger PowerDer Tiger ist auf dem losen |
| Subject: Re: spin spin spin Fri Jan 22, 2016 1:02 pm | |
| Looks like Tank Overhaul to me. I will sort this out and it will be ready for the next meet for sure if not earlier. |
| Subject: Re: spin spin spin Fri Jan 22, 2016 2:06 pm | |
| stick of boom followed by running over with car _____________________________________________ Tiger PowerDer Tiger ist auf dem losen |
| Subject: Re: spin spin spin Sat Jan 23, 2016 11:31 pm | |
| Kyle, 6pm tomorrow at the Tim's. |
| Subject: Re: spin spin spin Sat Jan 23, 2016 11:35 pm | |
| Yes hopeful Dean can come too lok _____________________________________________ Tiger PowerDer Tiger ist auf dem losen |
| Subject: Re: spin spin spin | |
