Clark Flash No Longer Needed Icon_minitimeby Shoveler74 Today at 6:03 am
Clark Flash No Longer Needed Icon_minitimeby hachleopard2 Sat Sep 14, 2019 7:23 pm
Clark Flash No Longer Needed Icon_minitimeby Jarlath Fri Sep 13, 2019 4:04 pm
Clark Flash No Longer Needed Icon_minitimeby Strato50 Wed Sep 11, 2019 10:50 pm
Clark Flash No Longer Needed Icon_minitimeby treemagnet Tue Sep 10, 2019 5:15 pm
Clark Flash No Longer Needed Icon_minitimeby Strato50 Tue Sep 10, 2019 3:29 am
Clark Flash No Longer Needed Icon_minitimeby knispel Tue Sep 10, 2019 1:21 am
Clark Flash No Longer Needed Icon_minitimeby Negaduck Sun Sep 08, 2019 5:09 pm
Clark Flash No Longer Needed Icon_minitimeby Strato50 Sat Sep 07, 2019 9:30 pm
Clark Flash No Longer Needed I_vote_lcapClark Flash No Longer Needed I_voting_barClark Flash No Longer Needed I_vote_rcap
Clark Flash No Longer Needed Empty
PostSubject: Clark Flash No Longer Needed   Clark Flash No Longer Needed Icon_minitimeTue May 03, 2016 7:32 pm
I am converting my Abt. 506 Taigen Tiger I from SLU to Clark.
The one thing I am deficient in is a Clark Flash.
If anyone here has one to spare, perhaps we can work out a sale, or trade.
PostSubject: Re: Clark Flash No Longer Needed   Clark Flash No Longer Needed Icon_minitimeTue May 03, 2016 8:13 pm
Glen, flash as in the flash bulb in the barrel and the associated connector ?
PostSubject: Re: Clark Flash No Longer Needed   Clark Flash No Longer Needed Icon_minitimeTue May 03, 2016 8:31 pm
Yes, that's it.
The bulb, connected wires (yellow & black, at least on the other one's i have used), and the connector that plugs into J3 on the Clark Board.
PostSubject: Re: Clark Flash No Longer Needed   Clark Flash No Longer Needed Icon_minitimeTue May 03, 2016 8:39 pm
Also, will the HL Flash work with a Clark?
I have one but I don't feel comfortable with them because they store a high voltage.
PostSubject: Re: Clark Flash No Longer Needed   Clark Flash No Longer Needed Icon_minitimeTue May 03, 2016 8:40 pm
Yes they will. But not a big deal to get you one with the regular LED.
PostSubject: Re: Clark Flash No Longer Needed   Clark Flash No Longer Needed Icon_minitimeTue May 03, 2016 9:20 pm
Good what are we looking at for cost?
And, would you advise against using the HL?  I have on, "new in the box".  My concern is that I believe they are a capacitor that stores up a lot of energy and can zap the unwary if they are working around them.  Electronic are not my area Embarassed  , I may be wrong with that concern.
PostSubject: Re: Clark Flash No Longer Needed   Clark Flash No Longer Needed Icon_minitimeTue May 03, 2016 9:23 pm
No the High intensity flash will work just fine. Make sure you plug it into the correct 5 pin plug on the board as there is 2 5 pin spot. Judhead in Welland might have some small plugs as well that he can pass onto you.
Besides, what else is it going to do sitting NIB ?
PostSubject: Re: Clark Flash No Longer Needed   Clark Flash No Longer Needed Icon_minitimeTue May 03, 2016 9:28 pm
It has the 5 pin plug that fits right into CN3.
I had it left over from some HL builds, didn't wind up using this particular one.
Is it true that once they are used, they store high voltage?  If they do, does it dissipate after the tank is shut down and the battery removed?
Jughead
Jughead
PostSubject: Re: Clark Flash No Longer Needed   Clark Flash No Longer Needed Icon_minitimeTue May 03, 2016 10:08 pm
Glen , I'll see Mike Saturday , if he has what you need , I have some small plugs here , and I might make trip out to field on Sunday to check it out
PostSubject: Re: Clark Flash No Longer Needed   Clark Flash No Longer Needed Icon_minitimeTue May 03, 2016 10:15 pm
Thanks, but if the HL Flash will work, I think I might as well use it since it is here.
PostSubject: Re: Clark Flash No Longer Needed   Clark Flash No Longer Needed Icon_minitimeWed May 04, 2016 5:28 pm
Works just fine as the Clark boards are designed to use it from the get-go.
They can be had quite cheaply, WELL under $20 so I'd cruise around eBay or some of the more known parts places to see what prices are like these days.
PostSubject: Re: Clark Flash No Longer Needed   Clark Flash No Longer Needed Icon_minitimeWed May 04, 2016 7:52 pm
Thanks, I already had an HL High Tension Flash in my collection of parts, and it was never out of the box Smile
Looks like they just plug into CN3
PostSubject: Re: Clark Flash No Longer Needed   Clark Flash No Longer Needed Icon_minitimeWed May 04, 2016 8:07 pm
Yup.
PostSubject: Re: Clark Flash No Longer Needed   Clark Flash No Longer Needed Icon_minitimeWed May 04, 2016 8:13 pm
Just tested it, works just fine, thanks everyone Smile
PostSubject: Re: Clark Flash No Longer Needed   Clark Flash No Longer Needed Icon_minitimeThu Jun 01, 2017 1:00 pm
I'm gonna thread resurrect here... The High-Voltage flash unit has a 5 pin connector, 3 are used for +ve, -ve, and Strobe Signal. The remaining 2 are specifically for recoil/airsoft switch contact which is not used by the Clark board correct?
PostSubject: Re: Clark Flash No Longer Needed   Clark Flash No Longer Needed Icon_minitimeThu Jun 01, 2017 1:22 pm
Yes.
PostSubject: Re: Clark Flash No Longer Needed   Clark Flash No Longer Needed Icon_minitimeThu Jun 01, 2017 1:46 pm
Of you can use an LED bulb and hook it up into Port J3 on the Clark board?
This is assuming of course you are wanting a flash of some sort...
Cool to know...
PostSubject: Re: Clark Flash No Longer Needed   Clark Flash No Longer Needed Icon_minitimeThu Jun 01, 2017 1:50 pm
Always want flash. To me recoil and flash are a bare minimum...
Can-Am RC Tank Club :: The Quartermaster's Depot :: Looking to Buy-
