My Panther G. First try at painting. - Page 3 Icon_minitimeby Jarlath Today at 12:29 am
My Panther G. First try at painting. - Page 3 Icon_minitimeby hachleopard2 Sat Sep 14, 2019 7:23 pm
My Panther G. First try at painting. - Page 3 Icon_minitimeby Jarlath Fri Sep 13, 2019 4:04 pm
My Panther G. First try at painting. - Page 3 Icon_minitimeby Strato50 Wed Sep 11, 2019 10:50 pm
My Panther G. First try at painting. - Page 3 Icon_minitimeby treemagnet Tue Sep 10, 2019 5:15 pm
My Panther G. First try at painting. - Page 3 Icon_minitimeby Strato50 Tue Sep 10, 2019 3:29 am
My Panther G. First try at painting. - Page 3 Icon_minitimeby knispel Tue Sep 10, 2019 1:21 am
My Panther G. First try at painting. - Page 3 Icon_minitimeby Negaduck Sun Sep 08, 2019 5:09 pm
My Panther G. First try at painting. - Page 3 Icon_minitimeby Strato50 Sat Sep 07, 2019 9:30 pm
My Panther G. First try at painting. - Page 3 I_vote_lcapMy Panther G. First try at painting. - Page 3 I_voting_barMy Panther G. First try at painting. - Page 3 I_vote_rcap
Go to page : Previous  1, 2, 3
kwa
kwa
My Panther G. First try at painting. - Page 3 Empty
PostSubject: Re: My Panther G. First try at painting.   My Panther G. First try at painting. - Page 3 Icon_minitimeThu Sep 08, 2016 6:40 pm
IR emitter actually works properly or at least it did before I fully assembled the turret. Woo hoo!
Now the boo hoo! I got a 2 pin plug coming out of the turret that I didn't label or the label came off. I don't know where it goes unless it goes into CN11 the smoke switch and I don't remember anything being there (3 months ago, I shoulda taken a picture).  And one of the plugs that is for flash control, I think came off the plug from the turret and I can't tell which is the red wire pin connects too.  If I am wrong will it damage the board or the flash?
HL Panther G, HL Early Tiger I
Jughead
Jughead
PostSubject: Re: My Panther G. First try at painting.   My Panther G. First try at painting. - Page 3 Icon_minitimeThu Sep 08, 2016 7:18 pm
You didn't say how small the plug was , if it's real small it's either your emitter or barrel flash , your previous post showed your emitter wire red and black, that's goes directly beside your 5 pin connector, your apple base and blue ring wiring , your barrel flash wire goes in plug positioned almost in center of board , it's the only small plug there , can't miss it , hope this helps, assuming your running a clark
kwa
kwa
PostSubject: Re: My Panther G. First try at painting.   My Panther G. First try at painting. - Page 3 Icon_minitimeThu Sep 08, 2016 8:38 pm
Yes it's a clark board.
The tank drives, turns, flashes, makes sounds, IR emitts, MG fires, driving light works, turret rotates right, binds when past centerline to the left, grumble, no elevation or depression, grumble, but I am sure that plug is in wrong slot.
I didn't plug in the two plugs. I can hopefully post a pic or two tomorrow after work.
Jughead
Jughead
PostSubject: Re: My Panther G. First try at painting.   My Panther G. First try at painting. - Page 3 Icon_minitimeThu Sep 08, 2016 10:02 pm
Your turret and elevation function is in your 8way plug , shouldn't be an issue , check your connection, also check your alignment holes on your turret ring, , it could be warped due to misalignment, make sure there siting in all 3 screw holes correctly , this will cause a bind , sometimes the little things causes the biggest problems , lol
kwa
kwa
PostSubject: Re: My Panther G. First try at painting.   My Panther G. First try at painting. - Page 3 Icon_minitimeFri Sep 09, 2016 8:31 pm
I figured it out, the extra loose plug was for the apple, once I figured that out, the rest was easy. The smoker is not working, the elevation control is ok.
kwa
kwa
PostSubject: Re: My Panther G. First try at painting.   My Panther G. First try at painting. - Page 3 Icon_minitimeFri Sep 09, 2016 8:45 pm
Jughead
Jughead
PostSubject: Re: My Panther G. First try at painting.   My Panther G. First try at painting. - Page 3 Icon_minitimeFri Sep 09, 2016 9:42 pm
The apple ? Never seen the apple plugged into some other plug than the 5 way with the blue ring, you must have some weird wire setup
kwa
kwa
PostSubject: Re: My Panther G. First try at painting.   My Panther G. First try at painting. - Page 3 Icon_minitimeFri Sep 09, 2016 9:51 pm
I think Dean said Mike wired it up.  It's got a 2 pin connector  and a 3 pin connector on the Apple.  2 pin is a plug on the side of the apple. 3 pins on bottom of apple.
Page 3 of 3Go to page : Previous  1, 2, 3
