Strengthening Chally lower hull Icon_minitimeby Abteilung 506 Today at 12:36 am
» Hello new here
Strengthening Chally lower hull Icon_minitimeby Abteilung 506 Today at 12:13 am
Strengthening Chally lower hull Icon_minitimeby dgsselkirk Yesterday at 11:59 pm
Strengthening Chally lower hull Icon_minitimeby dgsselkirk Yesterday at 2:04 pm
» 2024 CLUB DUES.....
Strengthening Chally lower hull Icon_minitimeby dgsselkirk Yesterday at 1:07 pm
» Taigen KV metal swing arms
Strengthening Chally lower hull Icon_minitimeby MikeC Sat Mar 23, 2024 6:10 pm
Strengthening Chally lower hull Icon_minitimeby Hammertime999999999 Sat Mar 23, 2024 1:41 pm
» HERITAGECON 2024
Strengthening Chally lower hull Icon_minitimeby Negaduck Fri Mar 22, 2024 7:38 pm
» New member
Strengthening Chally lower hull Icon_minitimeby Hammertime999999999 Fri Mar 22, 2024 2:58 pm
Strengthening Chally lower hull I_vote_lcapStrengthening Chally lower hull I_voting_barStrengthening Chally lower hull I_vote_rcap
Bktanker
Strengthening Chally lower hull Empty
PostSubject: Strengthening Chally lower hull   Strengthening Chally lower hull Icon_minitimeFri Jun 24, 2016 1:33 pm
Resin lower, and a Home Depot strapping tie for cross brace:
Strengthening Chally lower hull Dscn1510
PostSubject: Re: Strengthening Chally lower hull   Strengthening Chally lower hull Icon_minitimeFri Jun 24, 2016 1:48 pm
What do you use as the resin? Seems like a fair volume to coat the entire floorpan...
PostSubject: Re: Strengthening Chally lower hull   Strengthening Chally lower hull Icon_minitimeFri Jun 24, 2016 2:16 pm
Just normal casting resin you get at Michael's. 4oz mixed for the main compartment and 2oz mixed for the gearbox compartment. Fill just to the power switch mounting post height, and since it is a 2.4 Ghz with volume control and smoker on/off on the radio, there is no other opening on the lower hull. Also, the Chally has a separate mount for the actual suspension arm and is outside of the lower, there is no worries of jamming or fouling the suspension arms/springs.
I have to remove the smoker and replace it with a smaller TARR unit as once you strengthen the hull, it doesn't flex anymore and you can't jam the upper/smoker into the lower. Apparently the Heng Long smoker only fits between the gearbox if the lower hull flexes. Go figure.
PostSubject: Re: Strengthening Chally lower hull   Strengthening Chally lower hull Icon_minitimeFri Jun 24, 2016 9:50 pm
My lay out for Challenger 2
Strengthening Chally lower hull 13516240_2048341102058073_7712770573270749940_n
PostSubject: Re: Strengthening Chally lower hull   Strengthening Chally lower hull Icon_minitimeFri Jun 24, 2016 10:29 pm
That is one cavernous hull, wow Razz
Hach is that the Clark sound amp? What do you think of them?
PostSubject: Re: Strengthening Chally lower hull   Strengthening Chally lower hull Icon_minitimeFri Jun 24, 2016 10:36 pm
If you set voltage booster to 11 volts and use separate battery It's great. I use woofer speaker, it's face down to floor with holes so the sound come out very loud.
» Matomart Chally
» Add on Armour for Chally 2
» Plastic Chally track links
» Tanks and hulls for sale
» Stug IV kit and lower hull
