» We are go for this weekend
The Great Track Debate Icon_minitimeby dgsselkirk Today at 7:32 am
» Not a great forecast...
The Great Track Debate Icon_minitimeby dgsselkirk Today at 7:18 am
» New Tamiya Tank
The Great Track Debate Icon_minitimeby MikeC Today at 12:45 am
» Big Mike's Recoil system & manlet mounts
The Great Track Debate Icon_minitimeby Jarlath Yesterday at 4:08 pm
» July 19-21 Battle Weekend Attendance Poll...
The Great Track Debate Icon_minitimeby Captain Action Yesterday at 8:38 am
» Captured Half Track
The Great Track Debate Icon_minitimeby Shoveler74 Tue Jul 16, 2019 9:43 pm
» question Forgebear Tanks
The Great Track Debate Icon_minitimeby Jarlath Mon Jul 15, 2019 9:28 pm
» Here is what's in store for you guys coming this weekend....
The Great Track Debate Icon_minitimeby Strato50 Mon Jul 15, 2019 7:29 pm
» Heng Long Trucks ?
The Great Track Debate Icon_minitimeby Airbrushler Sun Jul 14, 2019 2:35 pm
The Great Track Debate I_vote_lcapThe Great Track Debate I_voting_barThe Great Track Debate I_vote_rcap
silverblood
What can of Track?
Plastic
The Great Track Debate I_vote_lcap50%The Great Track Debate I_vote_rcap
 50% [ 5 ]
Metal
The Great Track Debate I_vote_lcap20%The Great Track Debate I_vote_rcap
 20% [ 2 ]
No Preference
The Great Track Debate I_vote_lcap30%The Great Track Debate I_vote_rcap
 30% [ 3 ]
Total Votes : 10
The Great Track Debate Empty
PostSubject: The Great Track Debate   The Great Track Debate Icon_minitimeMon Sep 12, 2016 9:28 am
One of the biggest debates among RC tankers, other than the Tamiya one, is what is better to use metal or plastic tracks?
Whats your preference and why?
PostSubject: Re: The Great Track Debate   The Great Track Debate Icon_minitimeMon Sep 12, 2016 9:37 am
For battling, I've always been a fan of the plastic tracks.
The lighter weight is easier on the gearboxes and the battery tends to have a longer life.   If you're able to keep the weight down on the tank, then you can float across the grass and not get bogged down.
The downside of plastic track is that will stretch a little on the hot days and can occasionally cause the track to slip off.
PostSubject: Re: The Great Track Debate   The Great Track Debate Icon_minitimeMon Sep 12, 2016 12:32 pm
the only tamiya track i have a problem with is the KT because its a 2 link type with no meat for the pins sit in
Tamiya Tiger 1 are 1 link and thick where the pins sit
Tamiya Sherman come already together with the outer parts that the drive sprocket grabs seems to be metal and the pins are not easy to remove from.
I guess it comes down to what plastic the companies use for the track and the cheaper tank companies will use cheaper plastics that will stretch more from the heat then just from use and time
PostSubject: Re: The Great Track Debate   The Great Track Debate Icon_minitimeMon Sep 12, 2016 2:51 pm
Having only ever driven around a metal lower/metal track heavy Taigen KV-1, I'm biased regarding my track opinions.
I believe I understand the differences however and please correct me if I'm wrong.
Plastic Tracks
Pros:
- Cheap, 1/6th the cost of most comparable metal track versions...
- Light in mass. Drivetrain requires far less effort/torque to move the tracks, especially from stationary point.
- Light in mass. May not get traction due to lack of ground pressure/engagement with surface.
Cons:
- Far easier to stretch and break on outdoor terrain due to side loads/debris.
- Visually less accurate (track sag)
Metal Tracks
Pros:
- Heavy in mass. Usually better traction on surfaces due to mass/friction. Heavier vehicle mass = ability to go through longer grass easier.
- Usually very robust. Far less susceptible to side loads/debris.
- Visually better (Track sag)
Cons:
- Cost
- Heavy. Requires gearbox upgrades from plastic due to mass, plus the mass adds more stress and strain on the suspension. Higher flex possibilities in tank chassis. Aluminum tracks are roughly 3x the mass of plastic.
PostSubject: Re: The Great Track Debate   The Great Track Debate Icon_minitimeMon Sep 12, 2016 4:55 pm
Metal in longer grass does not run better at all believe me. Michael and I sometimes look at each other and say why do we spend all this money on metal upgrades on motors, tracks, gearboxes, when Scout runs circles around us battling with her little Pz. IV? LOL!
Yes, metal makes the tank move prettier but can cost you in the battle....
PostSubject: Re: The Great Track Debate   The Great Track Debate Icon_minitimeMon Sep 12, 2016 7:29 pm
My T-34 loves the long grass, it built so light it sprints across the top of it.  The guys that went Oshawa can vouch for it, it was running every where.
The Great Track Debate Speedy10
PostSubject: Re: The Great Track Debate   The Great Track Debate Icon_minitimeMon Sep 12, 2016 7:42 pm
my Pz IV has the metal winter track and it can run just as fast as any but i guess being wider helps with the weight. If anything the clark battle damage holds it back
Jughead
Jughead
PostSubject: Re: The Great Track Debate   The Great Track Debate Icon_minitimeMon Sep 12, 2016 8:01 pm
Metal tracks on rear wheel drive tanks , since they only run on 3rd of the track anyways , plastic on front wheel drive , especially german tanks with super wide tracks
PostSubject: Re: The Great Track Debate   The Great Track Debate Icon_minitimeMon Sep 12, 2016 10:09 pm
Plastic for me, especially on grass surfaces.
Wolfleader
Wolfleader
PostSubject: Re: The Great Track Debate   The Great Track Debate Icon_minitimeWed Jul 19, 2017 11:09 pm
Metal for me.  I don't so much battle as much as do marathon runs with my tank on parks, paths and sidewalks.   This means that the track has to be sturdy enough to withstand moving through a number of different surfaces some of which like hard gravel paths and rough concrete can be pretty rough on plastic tracks.
We shape our fate as our fate shapes us
Can-Am RC Tank Club :: Assembly Area :: The Bi-Monthy Poll-
