VK 2002 German Prototype Icon_minitimeby hachleopard2 Yesterday at 7:23 pm
VK 2002 German Prototype Icon_minitimeby Jarlath Fri Sep 13, 2019 4:04 pm
VK 2002 German Prototype Icon_minitimeby Strato50 Wed Sep 11, 2019 10:50 pm
VK 2002 German Prototype Icon_minitimeby treemagnet Tue Sep 10, 2019 5:15 pm
VK 2002 German Prototype Icon_minitimeby Strato50 Tue Sep 10, 2019 3:29 am
VK 2002 German Prototype Icon_minitimeby knispel Tue Sep 10, 2019 1:21 am
VK 2002 German Prototype Icon_minitimeby Negaduck Sun Sep 08, 2019 5:09 pm
VK 2002 German Prototype Icon_minitimeby Strato50 Sat Sep 07, 2019 9:30 pm
VK 2002 German Prototype Icon_minitimeby Airbrushler Sat Sep 07, 2019 8:15 pm
VK 2002 German Prototype I_vote_lcapVK 2002 German Prototype I_voting_barVK 2002 German Prototype I_vote_rcap
VK 2002 German Prototype Empty
PostSubject: VK 2002 German Prototype   VK 2002 German Prototype Icon_minitimeWed Nov 30, 2016 8:44 pm
Some work in progress... Very Happy
Not sure exactly where this prototype fits in but the Germans tried all sorts of experimental roadwheel layouts. Another interesting one was a Panzer III with half-track interleaved roadwheels, really cool.
VK 2002 German Prototype Fththrfth
VK 2002 German Prototype Pbucket
PostSubject: Re: VK 2002 German Prototype   VK 2002 German Prototype Icon_minitimeWed Nov 30, 2016 10:34 pm
That's cool Jordan.......... I always like those VK series......
PostSubject: Re: VK 2002 German Prototype   VK 2002 German Prototype Icon_minitimeThu Dec 01, 2016 1:29 am
Awesome Work Jordan that is Cool
VK 2002 German Prototype Soviet10
PostSubject: Re: VK 2002 German Prototype   VK 2002 German Prototype Icon_minitimeThu Dec 01, 2016 3:39 am
Been busy doing suspension adjustments and putting some much-earned primer on!
A bit on the suspension... I ground away all the existing Panzer IV mounts and roughly spaced out 6 new holes that I calculated for Panther road wheels & the length of hull I had to work with between drive sprocket and idler. Drilled out those holes & then mounted hexagonal M3-threaded standoffs, the kind that hold things together in your PC but are also popular with aircraft and drone builders..
VK 2002 German Prototype 18985110
Then I bolted some Panther suspension pieces right on! When I show this tank off I'll explain what a pain in the butt that was... let's just say for now that 10x6x3mm bearings don't just slide smoothly onto HL axles.
Each suspension arm has a leaf spring that I am constantly adjusting in length. I kept it simple... I used a couple medium sized Zip-Ties® and glued them together in layers to form a spring. Voila.
PostSubject: Re: VK 2002 German Prototype   VK 2002 German Prototype Icon_minitimeThu Dec 01, 2016 10:30 am
I have a long barrel for this if you want it Jordan...
PostSubject: Re: VK 2002 German Prototype   VK 2002 German Prototype Icon_minitimeFri Dec 02, 2016 4:27 am
Well thank you Dean but it'll stay as is, nearly every reference to this prototype had the short barrel anyway so it fits.
Got some more painting done. It's been really slow at work, unusually, we don't get streaks like this especially in winter... I have to admit though painting is a lot easier under bright lights & with lots of cleaning brushes and water on hand Wink
Starting from the basic rattle-can grey primer I just randomly applied brown areas as I saw fit, no real reference tanks for this one. Then those brown patches were outlined in green more or less, & then the blanks filled in with yellow. Took me a couple hours and I'm pretty happy with the results.
PostSubject: Re: VK 2002 German Prototype   VK 2002 German Prototype Icon_minitimeFri Dec 02, 2016 7:57 am
camo au naturel ! I like it !
PostSubject: Re: VK 2002 German Prototype   VK 2002 German Prototype Icon_minitimeFri Dec 02, 2016 4:33 pm
Wow... those links are firm... No Sag?
PostSubject: Re: VK 2002 German Prototype   VK 2002 German Prototype Icon_minitimeSat Dec 03, 2016 12:20 am
There is a bit, but they are partially resting on a metal enclosure I fabbed up to cover the leaf springs on top. A rudimentary track guide Razz
