ibu2 install in taigen Icon_minitimeby MikeC Today at 12:01 am
ibu2 install in taigen Icon_minitimeby Airbrushler Yesterday at 5:33 pm
ibu2 install in taigen Icon_minitimeby Strato50 Wed Sep 18, 2019 8:49 pm
ibu2 install in taigen Icon_minitimeby hachleopard2 Sat Sep 14, 2019 7:23 pm
ibu2 install in taigen Icon_minitimeby Jarlath Fri Sep 13, 2019 4:04 pm
ibu2 install in taigen Icon_minitimeby Strato50 Wed Sep 11, 2019 10:50 pm
ibu2 install in taigen Icon_minitimeby treemagnet Tue Sep 10, 2019 5:15 pm
ibu2 install in taigen Icon_minitimeby Strato50 Tue Sep 10, 2019 3:29 am
ibu2 install in taigen Icon_minitimeby Negaduck Sun Sep 08, 2019 5:09 pm
ibu2 install in taigen I_vote_lcapibu2 install in taigen I_voting_baribu2 install in taigen I_vote_rcap
lesteryz
ibu2 install in taigen Empty
PostSubject: ibu2 install in taigen   ibu2 install in taigen Icon_minitimeSun Feb 05, 2017 7:27 pm
Has anyone installed a ibu2 board in a taigen. Having trouble installing all the upper hull connections. There is info on their site but no video. Dont want to screw it up it is an expensive board. There is a extra wire harness for taigen I also ordered but came with no instructions.
PostSubject: Re: ibu2 install in taigen   ibu2 install in taigen Icon_minitimeSun Feb 05, 2017 8:09 pm
Mike has been playing around with them, he should be able to help you.
PostSubject: Re: ibu2 install in taigen   ibu2 install in taigen Icon_minitimeSun Feb 05, 2017 8:38 pm
Les, which plug are you talking about ? IBU2 is plug and play 100% with Heng Long and Taigen. You just need to make sure it is the right plug, no re-wiring of any kind needed.
Just pick up a used IBU3 as well so have been trying that out. Have about 4-5 IBU2 Base/Pro installed. My T-90 was running on it and so was the Sherman Firefly at the last couple of meets.
lesteryz
PostSubject: Re: ibu2 install in taigen   ibu2 install in taigen Icon_minitimeSun Feb 05, 2017 9:53 pm
Does your recoil work ? There is an 8 pin and a five pin coming fro the upper hall where does the 5 pin plug in, I think it comes from recoil.
PostSubject: Re: ibu2 install in taigen   ibu2 install in taigen Icon_minitimeSun Feb 05, 2017 10:07 pm
Which Taigen tank do you have ? Is this the new BB recoil ? If so only the IBU3 will work with it out of the box.
lesteryz
PostSubject: Re: ibu2 install in taigen   ibu2 install in taigen Icon_minitimeSun Feb 05, 2017 10:19 pm
Asiatam recoil with ibu2 board
PostSubject: Re: ibu2 install in taigen   ibu2 install in taigen Icon_minitimeSun Feb 05, 2017 10:37 pm
Les, can you send some pictures ? The 8 pin should go into the 8 pin, the 5 pin depends on where it is coming from, it could be the Xenon flash, or the IR. Either way, if you keep your connections the Asiatam recoil should work as is (you still have a power feed directly connected to the witch, right ?).
lesteryz
PostSubject: Re: ibu2 install in taigen   ibu2 install in taigen Icon_minitimeSun Feb 05, 2017 10:43 pm
Yes the power feed is connected, I will send you sum pics tomorrow have to go to work
lesteryz
PostSubject: Re: ibu2 install in taigen   ibu2 install in taigen Icon_minitimeSun Feb 05, 2017 10:50 pm
Plugged into cn3 on clark board sight , so it is the gun flash and the 4,5 pin is not used , so I dont even use it, I think my problem is solved I will try it tomorrow.
PostSubject: Re: ibu2 install in taigen   ibu2 install in taigen Icon_minitimeSun Feb 05, 2017 11:03 pm
This doesn't help because you can't see how the wires are connected thru the 360 but it does showed that it will work........ Very Happy
Credit - Not my picture. Just got it off the web.
ibu2 install in taigen Img_0510
