Change Cannon recoil direction Icon_minitimeby hachleopard2 Sat Sep 14, 2019 7:23 pm
Change Cannon recoil direction Icon_minitimeby Jarlath Fri Sep 13, 2019 4:04 pm
Change Cannon recoil direction Icon_minitimeby Strato50 Wed Sep 11, 2019 10:50 pm
Change Cannon recoil direction Icon_minitimeby treemagnet Tue Sep 10, 2019 5:15 pm
Change Cannon recoil direction Icon_minitimeby Strato50 Tue Sep 10, 2019 3:29 am
Change Cannon recoil direction Icon_minitimeby knispel Tue Sep 10, 2019 1:21 am
Change Cannon recoil direction Icon_minitimeby Negaduck Sun Sep 08, 2019 5:09 pm
Change Cannon recoil direction Icon_minitimeby Strato50 Sat Sep 07, 2019 9:30 pm
Change Cannon recoil direction Icon_minitimeby Airbrushler Sat Sep 07, 2019 8:15 pm
Change Cannon recoil direction I_vote_lcapChange Cannon recoil direction I_voting_barChange Cannon recoil direction I_vote_rcap
Change Cannon recoil direction Empty
PostSubject: Change Cannon recoil direction   Change Cannon recoil direction Icon_minitimeMon Mar 13, 2017 8:49 pm
Hello!
Recently I install IR battle system on my CF Leopard 2 but IR range is too short, only 6 feet, even changing better IR LED.
Swap Clark board. surprise !! The IR range is over 25 feet. It's depend on the board.
Problem now. Cannon recoil goes different direction.
How to change it on Clark board? Please give me an advise
Thanks
PostSubject: Re: Change Cannon recoil direction   Change Cannon recoil direction Icon_minitimeMon Mar 13, 2017 10:55 pm
Hach just go into programming mode and use Channel Down/PROGR - button on the remote and it will switch the servo direction.
I have pretty well given up on trying to figure out why some clark IR just doesn't or stop working when it use to before All my batters will be on IBUs.
PostSubject: Re: Change Cannon recoil direction   Change Cannon recoil direction Icon_minitimeTue Mar 14, 2017 12:22 am
Hi Mike ! plug in program cable then press Channel down or program. It will change direction after that ?
PostSubject: Re: Change Cannon recoil direction   Change Cannon recoil direction Icon_minitimeTue Mar 14, 2017 8:47 am
Yes.
PostSubject: Re: Change Cannon recoil direction   Change Cannon recoil direction Icon_minitimeTue Jul 18, 2017 2:15 pm
In regards to the Clark and recoil direction...
Does the Clark board start the servo in a neutral position or in an extreme position?
Aka From zero angle to +-60 degrees (120 total)
Or from zero angle to 120 degrees one way?
PostSubject: Re: Change Cannon recoil direction   Change Cannon recoil direction Icon_minitimeTue Jul 18, 2017 2:28 pm
I believe it is from 0 to 120 extreme position. Note as above, you can reverse the direction in the programming.
PostSubject: Re: Change Cannon recoil direction   Change Cannon recoil direction Icon_minitimeTue Jul 18, 2017 2:41 pm
I've never actually checked it so hard to gauge, but I am looking into that for the new recoil design so that having it run backwards does not destroy the gears.
PostSubject: Re: Change Cannon recoil direction   Change Cannon recoil direction Icon_minitimeTue Jul 18, 2017 2:44 pm
I always leave mine disconnected on a new build till I fire it up and see which way it locks first...
