My Gearbox Issue Icon_minitimeby Shoveler74 Today at 6:04 am
My Gearbox Issue Icon_minitimeby hachleopard2 Sat Sep 14, 2019 7:23 pm
My Gearbox Issue Icon_minitimeby Jarlath Fri Sep 13, 2019 4:04 pm
My Gearbox Issue Icon_minitimeby Strato50 Wed Sep 11, 2019 10:50 pm
My Gearbox Issue Icon_minitimeby treemagnet Tue Sep 10, 2019 5:15 pm
My Gearbox Issue Icon_minitimeby Strato50 Tue Sep 10, 2019 3:29 am
My Gearbox Issue Icon_minitimeby knispel Tue Sep 10, 2019 1:21 am
My Gearbox Issue Icon_minitimeby Negaduck Sun Sep 08, 2019 5:09 pm
My Gearbox Issue Icon_minitimeby Strato50 Sat Sep 07, 2019 9:30 pm
My Gearbox Issue I_vote_lcapMy Gearbox Issue I_voting_barMy Gearbox Issue I_vote_rcap
 My Gearbox Issue
My Gearbox Issue Empty
PostSubject: My Gearbox Issue   My Gearbox Issue Icon_minitimeSun Aug 26, 2012 5:32 am
Those of you who saw my open Panzer 3 at Saturday's battleday may remember the 'gear wobble' issue I was having with the right gearbox.
I took the entire unit apart at work this evening, and it was actually not a hard process at all. 3 machine screws hold the halves of the gearbox together, and they surprisingly came out very easily.. as if loose. This may have been what led to my problem.
Removing the troublesome gear, it was evident that the 'big' and 'little' sections of the gear had simply unseated themselves. They are mated to each other and secured by a small pin or rivet, allowing them to rotate together.
So I took my hammer & punch, and realigned the gear. Voila, spins smooth as butter, in fact even better than the other gearbox. I can now freely rotate the gears by hand at the drive sprocket, when before I could not because of the tightness. I think over time I will be disassembling all of my 3:1s like this.
Goes to show ya, taking things apart isn't always a bad idea. The Panzer 3 is even better now Wink
My Gearbox Issue Gears10
PostSubject: Re: My Gearbox Issue   My Gearbox Issue Icon_minitimeSun Aug 26, 2012 7:20 am
Its very satisfying when things can be repaired like that, not to mention the cost savings from not having to replace it Very Happy
of the Pan-Tiger Panzer Div.
PostSubject: Re: My Gearbox Issue   My Gearbox Issue Icon_minitimeSun Aug 26, 2012 10:45 am
Good info, can you get some more pictures when you do the second unit and show the big and little gear alignment pin. My 3/1 gears are good but I would like to see and Not take mine apart .... just in case...
thanks
The Great Pan-Tiger pirat
My Gearbox Issue
