Taigen JS-2 ! Icon_minitimeby Negaduck Today at 8:01 pm
» For a laugh....
Taigen JS-2 ! Icon_minitimeby MikeC Today at 10:18 am
Taigen JS-2 ! Icon_minitimeby Airbrushler Yesterday at 5:33 pm
Taigen JS-2 ! Icon_minitimeby Strato50 Wed Sep 18, 2019 8:49 pm
Taigen JS-2 ! Icon_minitimeby hachleopard2 Sat Sep 14, 2019 7:23 pm
Taigen JS-2 ! Icon_minitimeby Jarlath Fri Sep 13, 2019 4:04 pm
Taigen JS-2 ! Icon_minitimeby Strato50 Wed Sep 11, 2019 10:50 pm
Taigen JS-2 ! Icon_minitimeby treemagnet Tue Sep 10, 2019 5:15 pm
Taigen JS-2 ! Icon_minitimeby Strato50 Tue Sep 10, 2019 3:29 am
Taigen JS-2 ! I_vote_lcapTaigen JS-2 ! I_voting_barTaigen JS-2 ! I_vote_rcap
 Taigen JS-2 !
Taigen JS-2 ! Empty
PostSubject: Taigen JS-2 !   Taigen JS-2 ! Icon_minitimeMon Jan 01, 2018 12:27 pm
Just when I finally got a Tamiya....... Oh well.
Taigen JS-2 ! 26167110
Renesis
Renesis
Taigen JS-2 ! Empty
PostSubject: Re: Taigen JS-2 !   Taigen JS-2 ! Icon_minitimeMon Jan 01, 2018 6:44 pm
Hmmm i wonder how their kit will compare to Tamiya's? I like the metal turret and what looks like a a functional engine hatch probably where the ON/OFF switch, smoke and volume controls are.
If they made JS3 id buy it lol
Taigen JS-2 ! Empty
PostSubject: Re: Taigen JS-2 !   Taigen JS-2 ! Icon_minitimeMon Jan 01, 2018 7:42 pm
This might be a sign of things to come. Because the smoker and on/off is mounted to the upper, the upper is actually hinged at the back so you can open up for battrery and not have to remove the wiring for on/off and the smoker........
Taigen JS-2 ! 26055910
Taigen JS-2 ! Empty
PostSubject: Re: Taigen JS-2 !   Taigen JS-2 ! Icon_minitimeMon Jan 01, 2018 7:58 pm
probably hard to get at the gearboxes
Taigen JS-2 ! Soviet10
Taigen JS-2 ! Empty
PostSubject: Re: Taigen JS-2 !   Taigen JS-2 ! Icon_minitimeMon Jan 01, 2018 11:05 pm
Those "scissor" bars for upper/lower are pretty "meh"..., Rather just have a single Prop Bar or similar than the dual lift arms. Plus how does the front secure?
Taigen JS-2 ! Empty
PostSubject: Re: Taigen JS-2 !   Taigen JS-2 ! Icon_minitimeMon Jan 01, 2018 11:16 pm
Its kinda of clever. They use the hinge for the engine cover at the back to double as the hinge for the upper, and then a latch type lock in the front. I have to seriously consider waiting for this or continue with the Tamiya that I have sitting on my to-do bench.
Taigen JS-2 ! 26168810
Taigen JS-2 ! 26233410
Taigen JS-2 ! Empty
PostSubject: Re: Taigen JS-2 !   Taigen JS-2 ! Icon_minitimeMon Jan 01, 2018 11:24 pm
Those two small plastic hinges takes all the mass of the upper? Cringe... Hope they never run into something or drop into our river at KW Smile.
I would have used a 'J' hinge internally that worked on the lower inner hull wall.
Renesis
Renesis
Taigen JS-2 ! Empty
PostSubject: Re: Taigen JS-2 !   Taigen JS-2 ! Icon_minitimeThu Jan 04, 2018 8:54 am
No torsion bars either? Hmm
Taigen JS-2 ! Empty
PostSubject: Re: Taigen JS-2 !   Taigen JS-2 ! Icon_minitimeThu Jan 04, 2018 2:29 pm
Spring is a not a bad thing if it is done properly. It also allows more space inside the tank as well.
Taigen JS-2 ! Empty
PostSubject: Re: Taigen JS-2 !   Taigen JS-2 ! Icon_minitimeThu Jan 04, 2018 2:39 pm
Not too concerned regarding the coil spring "torsion" arms. It will be the mass of that lower hull that concerns me more... Ugh. All metal lower (sprockets, idlers, roadwheels, tracks, arms, hull) means super heavy on the drivetrain.
Is it geared as a standard speed, or a low speed/high torque? (3:1 vs 4:1)? Would need to be offered with steel gearboxes obviously...
Taigen JS-2 ! Empty
Taigen JS-2 !
