| Subject: Re: Stalin's Organ Wed Aug 22, 2018 1:54 pm | |
| Nice looking delivery system Mike. (Shapeways is a ripoff IMHO, but they do have some unique stuff). |
Posts : 3256 Join date : 2013-02-12 Age : 64 Location : Kitchener ON
| Subject: Re: Stalin's Organ Wed Aug 22, 2018 4:37 pm | |
| WHAT? NO SERVO ELEVATION? LOL! _____________________________________________ "There are things in Russia which are not as they seem..." Georgy Konstantinovich Zhukov
| Subject: Re: Stalin's Organ Wed Aug 22, 2018 5:51 pm | |
| Right..... Will put that in.
Maybe I should put a Mako board in it and set up a Tamiya 2 shot kill mode. |
| Subject: Re: Stalin's Organ Wed Aug 22, 2018 8:41 pm | |
| Find a linear actuator like your trailer's tailgate |
| Subject: Re: Stalin's Organ Thu Aug 23, 2018 12:20 pm | |
| Good looking project Mike. Were the rockets a stock item at Shapeways or custom order? |
| Subject: Re: Stalin's Organ Thu Aug 23, 2018 1:07 pm | |
| The rockets and the large frame was the only one he had on Shaprways initially, but have all the other pieces in 1/25 and 1/32 scales, so I asked him to post a complete set for 1/16.
I am having issues gluing them together so will need to try different types. Super glue gel didn't work. |
| Subject: Re: Stalin's Organ Thu Aug 23, 2018 2:29 pm | |
| They are probably a stereolithography (SLA) 3D printed item. Great for detail.
If the Material is nylon, you may want to try Gorilla Glue, as CA does not bond well to Nylon. Or try standard polystyrene cement (plastic kit glue). I use old modelling glue for polystyrene all the time, takes a while to cure, but really is strong. Just make sure to do a light sanding to rough the surfaces and give the glue something to hook into. |
| Subject: Re: Stalin's Organ Thu Aug 23, 2018 2:41 pm | |
| I think it is nylon and it is quite rough already. It is not a smooth finish. I will try Gorilla Glue and see what happens. Does plastic kit glue "melt" it as well ? Also, for the trailer I have there isn't a power actuator. I got this set and will try to put it on the Broder : |
| Subject: Re: Stalin's Organ Thu Aug 23, 2018 4:17 pm | |
- I think it is nylon and it is quite rough already. It is not a smooth finish. I will try Gorilla Glue and see what happens. Does plastic kit glue "melt" it as well ?
Depends on what type. This cement type, does not melt the pieces, but does require some roughness for the glue to adhere to. This is what I use for my polystyrene pieces inside my tank hulls. When the plastic if roughed up, this stuff holds very well, but is not permanent (aka you can still force apart) Solvent based ones melt plastics together... Sometimes very messy due to the resultant "slurry" of plastic. The old very thin liquid based "glues" are usually like this. |
| Subject: Re: Stalin's Organ Thu Aug 23, 2018 7:04 pm | |
| i use super glue and if that don't work 5 min epoxy all from the dollar store oh and yes Heed The warning...lol it does stick fingers together good....lol _____________________________________________ |
| Subject: Re: Stalin's Organ Sun Aug 26, 2018 11:11 pm | |
| Subject: Re: Stalin's Organ | |
