King Tiger - Re-wiring... Icon_minitimeby hachleopard2 Sat Sep 14, 2019 7:23 pm
King Tiger - Re-wiring... Icon_minitimeby Jarlath Fri Sep 13, 2019 4:04 pm
King Tiger - Re-wiring... Icon_minitimeby Strato50 Wed Sep 11, 2019 10:50 pm
King Tiger - Re-wiring... Icon_minitimeby treemagnet Tue Sep 10, 2019 5:15 pm
King Tiger - Re-wiring... Icon_minitimeby Strato50 Tue Sep 10, 2019 3:29 am
King Tiger - Re-wiring... Icon_minitimeby knispel Tue Sep 10, 2019 1:21 am
King Tiger - Re-wiring... Icon_minitimeby Negaduck Sun Sep 08, 2019 5:09 pm
King Tiger - Re-wiring... Icon_minitimeby Strato50 Sat Sep 07, 2019 9:30 pm
King Tiger - Re-wiring... Icon_minitimeby Airbrushler Sat Sep 07, 2019 8:15 pm
King Tiger - Re-wiring... I_vote_lcapKing Tiger - Re-wiring... I_voting_barKing Tiger - Re-wiring... I_vote_rcap
King Tiger - Re-wiring... Empty
PostSubject: King Tiger - Re-wiring...   King Tiger - Re-wiring... Icon_minitimeMon Jun 18, 2018 10:42 am
So as you may have seen if you were at Aquino, I finished my eldest son's King Tiger. I basically just got it mobile and functional using a cheap, battery powered, soldering iron. It was a meh soldering tool, but worked in a pinch. Of course when I quickly rebuilt it at the field, I didn't optimize anything. No mounted switches, pots, etc... On/Off switch, Sound Volume, and Smoker switch were loose.  Well the cheap solder joint on the power switch failed on Thursday evening do to shifting and vibration on the cheap solder joint.
Time to re-wire/rebuild...
King Tiger - Re-wiring... Img_2011
The original plastic gears held up way better than expected at Aquino... That Plastic "Torque clutch" works surprisingly well. The fact that there is no metal running gear likely helps a lot... Receiver antenna on the left track cover.
King Tiger - Re-wiring... Img_2012
The Clark Board layout and added cross brace. Note the smoker on/off switch has been mounted and the volume control replaced with the jumper (I blame MikeC for that and maximum volume...) Yes I like a clean wiring job...
King Tiger - Re-wiring... Img_2010
I kept the original speaker and smoker unit, but did re-glue the speaker mount and screwed down the speaker itself. Rewires the main on/off switch to an external hull mount (Remember this is for my eldest son).
King Tiger - Re-wiring... Img_2014
The new on/off switch location on the outside, between the exhausts. simple and easy to get at.
King Tiger - Re-wiring... Img_2013
Use of adhesive backed aluminum wire guides to clean up the wiring routing... I like it clean and organized.
King Tiger - Re-wiring... Img_2015
Nice open and exposed Clark Board for easy access for upper hull/turret wiring.
PostSubject: Re: King Tiger - Re-wiring...   King Tiger - Re-wiring... Icon_minitimeMon Jun 18, 2018 1:44 pm
Binding plug jumper = Volume knob setting 11.
PostSubject: Re: King Tiger - Re-wiring...   King Tiger - Re-wiring... Icon_minitimeTue Jun 19, 2018 11:06 am
The direct plug is actually louder than via the Pot? I guess there is always some excess resistance?
PostSubject: Re: King Tiger - Re-wiring...   King Tiger - Re-wiring... Icon_minitimeTue Jun 19, 2018 11:13 am
Always seems louder to me but it could be my crappy volume is controls.
PostSubject: Re: King Tiger - Re-wiring...   King Tiger - Re-wiring... Icon_minitimeTue Jun 19, 2018 1:16 pm
I'm looking to try a small sound amplifier.
King Tiger - Re-wiring... S-l16010
6-12V input with 18W max output. Love Ebay... ~$2 CDN shipped.
