| Taigen tank to Clarktk22 board | |
treemagnet Sergeant
Posts : 295 Join date : 2018-07-14 Location : Georgetown Ont
| Subject: Taigen tank to Clarktk22 board Sat Jul 28, 2018 1:27 pm | |
| So far I have the motors working sound turret traverse Machine guns working. I can't see to get the recoil, elevation, and Gun flash working and how can I tell it the IR transmitter is working? I have the Panther G and put the Tamiya Apple in it and that seems ok I am using the original recoil and elevation from the Taigen kit Thanks Tom |
| Subject: Re: Taigen tank to Clarktk22 board Sat Jul 28, 2018 1:36 pm | |
| you have to look through you phone camera to see the emitter flash not sure if you have to be filming but you can't see it with the naked eye _____________________________________________ |
treemagnet Sergeant
| Subject: Re: Taigen tank to Clarktk22 board Sat Jul 28, 2018 1:49 pm | |
| I will do that but first want to to get the recoil and elevation working but never thought about looking thru the phone camera II guess there is no IR filter unlike webcams |
| Subject: Re: Taigen tank to Clarktk22 board Sat Jul 28, 2018 4:38 pm | |
| can you send a pic of the way you have it hooked up _____________________________________________ |
treemagnet Sergeant
| Subject: Re: Taigen tank to Clarktk22 board Sat Jul 28, 2018 5:29 pm | |
| well I seem to have the recoil working now but the BOOM comes after the gun has finished the recoil cycle I have the barrel flash wired correctly red to battery + black to battery - and strobe to strobe but no flash (maybe has to do with the boom at the end of the cycle ) the elevation still isn't working right not sure if it radio set up. the machine guns fire engine starts motors |
treemagnet Sergeant
| Subject: Re: Taigen tank to Clarktk22 board Sat Jul 28, 2018 5:31 pm | |
| one more thing I need one of those really small connectors for the IR J1 any ideas where I can get one I was at the hobby shop today and nothing Tom |
| Subject: Re: Taigen tank to Clarktk22 board Sat Jul 28, 2018 6:44 pm | |
| They are JST-GH 1.25mm connectors. I have a few coming from Ebay. eBay link here |
treemagnet Sergeant
| Subject: Re: Taigen tank to Clarktk22 board Sat Jul 28, 2018 7:38 pm | |
| Thanks Ill look into that I have one coming now but want to get a couple |
| Subject: Re: Taigen tank to Clarktk22 board Sat Jul 28, 2018 8:09 pm | |
| Well I have 50 coming. So no issues when they arrive if you need one...
treemagnet Sergeant
| Subject: Re: Taigen tank to Clarktk22 board Sun Jul 29, 2018 11:29 am | |
| OK now getting frustrated I checked my wiring according to the clack web site my recoil works but the gun fires at the end of the recoil cycle any suggestions? also the flash unit wont flash but does flash when I turn off the power |
| Subject: Re: Taigen tank to Clarktk22 board Sun Jul 29, 2018 11:32 am | |
| Tom, one thing you can also try is to see if the flash port that uses the small connectors are also doing the same thing (i.e. flashing after recoil). Also, the flash unit does take time to charge up so if you are firing continuously it might not be able to charge up enough to fire. |
treemagnet Sergeant
| Subject: Re: Taigen tank to Clarktk22 board Sun Jul 29, 2018 11:42 am | |
| If you talking about J3 port I don't have any small connector to plug in to try. do you know why the gun sound doesn't come until after the recoil cycle is done |
| Subject: Re: Taigen tank to Clarktk22 board Sun Jul 29, 2018 12:07 pm | |
| Probably the same problem you are having with the flash. Your flash is out of sync with the recoil and so is the sound. This is not an adjustment on the board, so if everything is correct than there is probably some problem with the board itself. I assummed you have the recoil servo set-up correctly ? |
Posts : 580 Join date : 2017-03-23 Age : 49 Location : Prineville, Oregon
| Subject: Re: Taigen tank to Clarktk22 board Sun Jul 29, 2018 12:40 pm | |
| Coincidently I am working on this same problem. I've got the flash plugged into CN3 and it works properly. Bright as hell too outside the barrel! I found this video that for an Open Panzer board that should help some but it does not work directly with the Clark TK22 I am using. https://www.youtube.com/watch?v=lFB5zhplN2QFrom that video I have gotten the recoil motor to run but havn't gotten the limit switch to recognize. In the pics below, I've wired the recoil motor into a spare servo connector and have it plugged into J2. I am only using the + and -. I need to get a three wire servo connector and am going to try adding the signal wire in respect to how the video wired it. Elevation motor is also working but I don't like how it is controlled. Half down and half left on the left stick. It is plugged into the aux distribution board that feeds the CN9. I may try wireing it into a servo connector and trying J4. Cheers |
treemagnet Sergeant
| Subject: Re: Taigen tank to Clarktk22 board Sun Jul 29, 2018 1:45 pm | |
| Thank shoveler74 I have mine wired up the same as the video except the switch has two wires going to the tk22 board going to checking the wiring one more time ug lol |
| Subject: Re: Taigen tank to Clarktk22 board Sun Jul 29, 2018 1:49 pm | |
| oh i guess you got the elevation going the more of them you do the better you get at them...lol _____________________________________________ |
treemagnet Sergeant
| Subject: Re: Taigen tank to Clarktk22 board Sun Jul 29, 2018 5:01 pm | |
| no haven't got elevation going need gun going yet so elevation will worry about it later waiting for my emitter to come first to see if that helps |
| Subject: Re: Taigen tank to Clarktk22 board Sun Jul 29, 2018 7:23 pm | |
| sometimes the solder on the back of this board sucks you might want to check it out _____________________________________________ |
treemagnet Sergeant
| Subject: Re: Taigen tank to Clarktk22 board Sun Jul 29, 2018 7:26 pm | |
| Subject: Re: Taigen tank to Clarktk22 board Sun Jul 29, 2018 7:51 pm | |
| no the connection of the harness to to tank that board sometimes has bad soldering the board in the pic _____________________________________________ |
treemagnet Sergeant
| Subject: Re: Taigen tank to Clarktk22 board Sun Jul 29, 2018 7:58 pm | |
| every thing worked prior to installing the clark board so all the solder connections should be ok on the boards that were on the tank |
| Subject: Re: Taigen tank to Clarktk22 board Sun Jul 29, 2018 8:13 pm | |
| what radio you using _____________________________________________ |
treemagnet Sergeant
| Subject: Re: Taigen tank to Clarktk22 board Sun Jul 29, 2018 8:15 pm | |
| taranis 9xd but that shouldn't effect the "boom" coming at the end of the cycle |
| Subject: Re: Taigen tank to Clarktk22 board Sun Jul 29, 2018 9:46 pm | |
| you trust HL's Soldering too much ...lol _____________________________________________ |
treemagnet Sergeant
| Subject: Re: Taigen tank to Clarktk22 board Sun Jul 29, 2018 9:48 pm | |
| Subject: Re: Taigen tank to Clarktk22 board | |
