I was driving around in the sand... Icon_minitimeby hachleopard2 Yesterday at 7:23 pm
I was driving around in the sand... Icon_minitimeby Jarlath Fri Sep 13, 2019 4:04 pm
I was driving around in the sand... Icon_minitimeby Strato50 Wed Sep 11, 2019 10:50 pm
I was driving around in the sand... Icon_minitimeby treemagnet Tue Sep 10, 2019 5:15 pm
I was driving around in the sand... Icon_minitimeby Strato50 Tue Sep 10, 2019 3:29 am
I was driving around in the sand... Icon_minitimeby knispel Tue Sep 10, 2019 1:21 am
I was driving around in the sand... Icon_minitimeby Negaduck Sun Sep 08, 2019 5:09 pm
I was driving around in the sand... Icon_minitimeby Strato50 Sat Sep 07, 2019 9:30 pm
I was driving around in the sand... Icon_minitimeby Airbrushler Sat Sep 07, 2019 8:15 pm
I was driving around in the sand... I_vote_lcapI was driving around in the sand... I_voting_barI was driving around in the sand... I_vote_rcap
I was driving around in the sand... Empty
PostSubject: I was driving around in the sand...   I was driving around in the sand... Icon_minitimeMon Sep 17, 2012 1:57 pm
..up at Sauble Beach yesterday, the water had receded about a KM from the 'normal' shore and it was all flat and hard, lots of fun with the Tiger splashing through puddles and such Razz
Take it back to the campsite, onto some 'regular' dry sand.. and I sheared a drive shaft! Whoa! What a god awful noise that made. So, where to get spares? Razz
I was driving around in the sand... Photo121
Also came across this bad boy in Owen Sound. Pretty awesome.
I was driving around in the sand... Photo120
PostSubject: Re: I was driving around in the sand...   I was driving around in the sand... Icon_minitimeMon Sep 17, 2012 6:02 pm
Nice Sherman
and that sand looks like it would have been fun to
PostSubject: Re: I was driving around in the sand...   I was driving around in the sand... Icon_minitimeMon Sep 17, 2012 7:52 pm
for the 3:1 brass drive Mato was able to send me replacement. I also have a lath and made my own from steel. Just in case the brass replacement sheared again.
PostSubject: Re: I was driving around in the sand...   I was driving around in the sand... Icon_minitimeMon Sep 17, 2012 8:46 pm
Phil at RCTANKWARS!!! Very Happy
Hahah, I beat you to it Captain Action! tongue
of the Pan-Tiger Panzer Div.
PostSubject: Re: I was driving around in the sand...   I was driving around in the sand... Icon_minitimeMon Sep 17, 2012 9:16 pm
DAM Mad
Tamiya ...Get a Tamiya . tongue
The Great Pan-Tiger pirat
Fireman Tim
Fireman Tim
PostSubject: Re: I was driving around in the sand...   I was driving around in the sand... Icon_minitimeTue Sep 18, 2012 6:54 am
M4A2E8! Cold war rocked!
PostSubject: Re: I was driving around in the sand...   I was driving around in the sand... Icon_minitimeFri Sep 21, 2012 7:22 am
ok, speaking of gears, what's the best replacement. Brass gears or full Steel gears? Is there also stainless gears? I'm going to be getting a set for my Tiger...opinions?
PostSubject: Re: I was driving around in the sand...   I was driving around in the sand... Icon_minitimeSat Oct 06, 2012 9:16 pm
I was checking my tank drives today and I noticed a wobble in one of the gears . I remember you pointed the same thing out on your Tiger at the last battle day. It seems my other 3:1 gear set has the same condition in one of the gears . It seems the gear was pressed onto the shaft with a bit of skew which gives them a wobble . This adds additional strain to the drive assembly which you can hear when it runs ( when compared to a good set )
I remember being puzzeled when I sheared my original drive shaft because the rear hub is screwed to just a plastic post and why did it not fail first?
Anyway I hope Mato found you a replacement drive shaft .
PostSubject: Re: I was driving around in the sand...   I was driving around in the sand... Icon_minitimeWed Oct 10, 2012 11:27 am
Drive shafts arrived, they are nice!
However the support bearing(s) are shot, I'm pretty sure to my own 'persuasion' removing the old broken one, but, hey, I'll chalk it up to the event that did the original damage! Blah
So, I emailed Mato asking if they have the bearings too. Can't wait to see what they expect me to pay for them.... yeesh...
Anyone have the up-and-up on bearings & be able to tell me what kind / size Mato uses??
PostSubject: Re: I was driving around in the sand...   I was driving around in the sand... Icon_minitimeWed Oct 10, 2012 1:31 pm
The gear set does come with some nice ball bearings on the final drive axel , However when mine blew out I thought perhaps with metal tracks were just too much of a load on them so I replaced one side with a 6 mm wide brass bushing as a test .So far both are working.
PostSubject: Re: I was driving around in the sand...   I was driving around in the sand... Icon_minitimeThu Oct 11, 2012 11:42 am
Interesting... did you make your own bushings or buy them?
I'd like to know what you did here. I was thinking of soldering a few layers of brass hobby tube together... that's if the driveshafts and gearbox's are metric..
PostSubject: Re: I was driving around in the sand...   I was driving around in the sand... Icon_minitimeThu Oct 11, 2012 12:45 pm
I turned my own bushing. But the tube idea sounds interesting as well . If you go that route I will be interested how it turns out.
PostSubject: Re: I was driving around in the sand...   I was driving around in the sand... Icon_minitimeTue Oct 16, 2012 5:52 am
Found an excellent source for the bearings required for the Mato 2.0 - 3:1s a lot of us use!
Bearings
Most other sites were charging 3-10$ for the same sized bearings... these are $1.
I ordered 10, for about $15 with shipping.
Hoping the quality doesn't reflect the price! Razz
real_hulu
real_hulu
PostSubject: Re: I was driving around in the sand...   I was driving around in the sand... Icon_minitimeTue Oct 16, 2012 11:17 am
please post some photos show where and how you put those bearing.
PostSubject: Re: I was driving around in the sand...   I was driving around in the sand... Icon_minitimeTue Oct 16, 2012 8:32 pm
Hey Hulu, I put in a new bearing today, it helps to have a pair of large pliers or a vice to press them in, its a snug fit but they slide in nicely. Proper size is 5mm inner, 8mm outer, 2.5mm wide & flanged.
Removing them is more delicate. I used a 5/16 brass punch (which is nearly almost exactly 8mm) and very gently tapped them out with a small hammer. Patience doing this! Make sure you're lined up straight or the bearing will be damaged.
Anyway with the new drive shaft, I took some scotch bright & a small file to smooth it out, and they sit in the bearings nicely. Again if the shaft is not smooth, you can damage the bearings. Theyre very delicate!
I have my drive assembled now and it's good as new, no wobble or play in the shaft. I'll have pictures soon!
PostSubject: Re: I was driving around in the sand...   I was driving around in the sand... Icon_minitimeTue Oct 23, 2012 7:33 am
Wow, so guess what?
I was driving around in the sand... Photo140
The OTHER side's driveshaft failed... The track snagged in a wayward towel on the floor, drove 2 feet, then only made right turns.
Luckily I had the extra from Mato.
Seems they do suffer from gradual stress, and eventually fail... Granted I drive like a maniac with an above average weight tank.
Anyway, repaired, good as new, 400 motors installed. I know the failure point now!
*edit* I have removed my metal tracks... I've taken the general advice I hear and will reserve them for 'parade days' only. FYI, 2 metal Tiger tracks weigh in at 3 pounds... thats 22% LESS weight on my tank & transmissions now, overall.
PostSubject: Re: I was driving around in the sand...   I was driving around in the sand... Icon_minitimeTue Oct 23, 2012 11:27 am
I hear you .I like the weighty feel to the tanks but not the repairs .
Then again, 3 lb of metal winter tracks with cleats will let you climb out of any ravine and keep you upright
PostSubject: Re: I was driving around in the sand...   I was driving around in the sand... Icon_minitimeTue Oct 23, 2012 11:26 pm
Thats a good point. On the Sherman and Panzer III, metal tracks are a good idea. Simply because they are smaller tracks, they wont weigh 3 pounds!! And they'll keep the C of G nice and low. I'm leaving the metal tracks on my Panzer for now, they run fine.
PostSubject: Re: I was driving around in the sand...   I was driving around in the sand... Icon_minitimeThu Nov 01, 2012 7:58 am
New presents came in the mail today!
For $15 (including shipping) I got 10 bearings, and a really nice decal sheet Great packaging, the little plastic tube is even threaded.
I was driving around in the sand... Img_6710
...and my KV-2 Tamiya speaker (first Tamiya part bought EVER...!) ... Hooked it up to my Tiger... WHOA!! The cat ran away so fast, I've yet to find him Sad Very loud super crisp sound. From "Jason's" eBay store, Japan.
real_hulu
real_hulu
PostSubject: Re: I was driving around in the sand...   I was driving around in the sand... Icon_minitimeThu Nov 01, 2012 4:18 pm
where do you install those bearing?
Henglong gearbox? or Mato 3:1 gearbox?
PostSubject: Re: I was driving around in the sand...   I was driving around in the sand... Icon_minitimeThu Nov 01, 2012 4:19 pm
They're the proper size for the mato 2.0 - 3:1 gears. I havent measured any other ones!!
real_hulu
real_hulu
PostSubject: Re: I was driving around in the sand...   I was driving around in the sand... Icon_minitimeThu Nov 01, 2012 4:38 pm
post more pictures when you modify it.
I am thinking doing the same thing. Very Happy
