| IS-3 Roadwheels - Yet another 3D Printer Project... | |
| Subject: IS-3 Roadwheels - Yet another 3D Printer Project... Thu Dec 13, 2018 9:41 am | |
| So while it has been busy at work from a time perspective... I had a request to try and make a set of 3D printed road heels for an IS-3. Why? Cause the resin version available is garbage IMHO... The initial concept for ease of printing and some strength... Outer road wheel on bottom left. Inner Road Wheel on bottom right, and center spacer at the top middle. Current design uses the original resin center caps. May look at a 3D Printed cap. Two images of the prototype road wheel assembly. The screws are my 10mm hex caps from my recoil units, so I either need longer screws, or double the number and have some from the inner wheel as well. Need to clean up the through holes for the screws and increase bearing diameters and outer road wheel bearing mounting depth to get correct axle placement. Road wheels themselves are a tad thick (0.5mm or so to shave off.) Inner edge of the road wheels are smooth without any detail. |
treemagnet Sergeant
Posts : 295 Join date : 2018-07-14 Location : Georgetown Ont
| Subject: Re: IS-3 Roadwheels - Yet another 3D Printer Project... Thu Dec 13, 2018 4:25 pm | |
| What kind of plastic are you using |
| Subject: Re: IS-3 Roadwheels - Yet another 3D Printer Project... Thu Dec 13, 2018 4:31 pm | |
Posts : 580 Join date : 2017-03-23 Age : 49 Location : Prineville, Oregon
| Subject: Re: IS-3 Roadwheels - Yet another 3D Printer Project... Thu Dec 13, 2018 6:19 pm | |
| WOW! Very cool! _____________________________________________ [b]You may be a king or a little street sweeper, but sooner or later you dance with the reaper! - Death[/b]
| Subject: Re: IS-3 Roadwheels - Yet another 3D Printer Project... Thu Dec 13, 2018 11:40 pm | |
| With your resin wheels and the following image... |
| Subject: Re: IS-3 Roadwheels - Yet another 3D Printer Project... Fri Dec 14, 2018 12:42 am | |
| they look Good _____________________________________________ |
| Subject: Re: IS-3 Roadwheels - Yet another 3D Printer Project... Fri Dec 14, 2018 10:56 am | |
| The fully assembled Wheel from the outside. Cap would be attached with CA currently for simplicity, Also easy to replace if print works properly... Outer view, cap not in place. Showing existing pin and bearings reused. I have tweeked the counterbore depths to get some thread engagement into the inner wheel. Inner view showing the designed offset for the pin (same as the metal road wheels, 8.8mm) Again, reused bearing from the original. A section view showing the assembly, note that the outer wheel has very little "meat" behind the bearing. Not very worried as all the axial loads are taken up by the 5 screws that fasten the assembly together... You can see that I did not texture the inner areas of the road wheel where the track guides run. No real point, and adds for ease of printing to have a flat surface |
Renesis Corporal
| Subject: Re: IS-3 Roadwheels - Yet another 3D Printer Project... Fri Dec 14, 2018 9:55 pm | |
| This is very cool! Hey Big Mike I might need you to print me some road wheel caps for my tamiya JS2 as I've lost one to the ether at either kitchener or mississauga lol |
| Subject: Re: IS-3 Roadwheels - Yet another 3D Printer Project... Wed Dec 19, 2018 11:34 am | |
| And the final product is pretty much done... And for S&G I sharpied some if it... This re-uses the Taigen axle pin and bearings for the KV-1 chassis. Each wheel set takes about 90 minutes to print.... |
| Subject: Re: IS-3 Roadwheels - Yet another 3D Printer Project... Wed Dec 19, 2018 10:02 pm | |
| Niice! _____________________________________________ [b]You may be a king or a little street sweeper, but sooner or later you dance with the reaper! - Death[/b]
| Subject: Re: IS-3 Roadwheels - Yet another 3D Printer Project... Fri Dec 21, 2018 8:19 am | |
| Well.. FOOK... So went to print 5 sets of IS-3 road wheels last night in a single print. 5-1/2 hour print. Damned thing ran outta filament at 80% completed... SIGH... So I have 5 spacers and caps extra so far... My slicer said I needed 24.5 Meters of filament... Guess I was short by 3-5m... |
| Subject: Re: IS-3 Roadwheels - Yet another 3D Printer Project... Thu Dec 27, 2018 6:54 pm | |
| The batch of Inner wheels, caps, and center hubs for the IS-3... Next a 15 pack or so of outer wheels. |
| Subject: Re: IS-3 Roadwheels - Yet another 3D Printer Project... Mon Jan 07, 2019 8:23 am | |
| Chris. I have your set of road wheels complete and ready. Are you wanting to buy the screws yourself? Or want me to include all 70? |
| Subject: Re: IS-3 Roadwheels - Yet another 3D Printer Project... | |
