Hi all,
Run into a rather strange problem and just wondering if any of the Tamiya owners out there has ever experience this. So I picked up a Sherman M4A3 from Russ who got it from Jack, and will be using it as a base for my "Fury" build. I know that the Tamiya M4A3 does not come with recoil, so I took a chance, got a recoil (from Jack also) and plug it in and see what happens.
Lo and behold there is no recoil from the Sherman MF unit, so I turn off the tank and that's when things got weird:
The MF goes from green to orange, but instead of fading away, it stays blinking orange even though the on/off switch is in the off position.
After about 15 seconds, when I turn on the radio again, instead of turning green, it turns blinking red, and the barrel flash start firing (with no sound), and the recoil working along the same. It will keep doing this (i.e. barrel flash and recoil) until I unplug the battery.
Clearly I have a fault on the on/off switch so I will replace that, but the silent barrel flash and the recoil is interesting since I couldn't get the recoil to work when it is all functioning properly, but when it is not, it starts working.
So basically my questions are:
1. WTF is going on ?
2. What does blinking red means on the MF ?
3. What does the little white switch control (next to the recoil plug on the MF).
Regards,
