hachleopard2 Captain
| Subject: Tamiya new 1/16 M551 Tank Mon Mar 25, 2019 10:25 pm | |
| This massive Tamiya R/C replica recreates the shape of the rather unique M551 Sheridan in 1/16 scale. The M551 was designed as airdrop capable armor with wading capabilities, a key concept as the U.S. took on the role of global policeman post-WWII. With an aluminum hull and rolled steel turret, it weighed just 15 tons, but had impressive firepower in the shape of the M81 152mm gun/launcher, which could fire standard rounds and MGM-51 Shillelagh missiles. The M551 was in service with active units from 1968 to 1996 and saw action in the jungles of Vietnam. • 1/16 scale R/C model assembly kit. Length: 408mm, width: 177mm, height: 186mm. • Die cast components for suspension arms, sprocket wheels, idler arms and more offer excellent durability. • Utilizes an aluminum gun barrel for superb accuracy. • Offers a full range of movement: forward and reverse, a variety of turns, turret rotation and gun elevation. Suspension features a coil spring for each of the 10 suspension arms, giving the model excellent mobility. • Firing of the main gun is accompanied by an LED flash, realistic recoil, and vehicle kickback. Machine gun also produces LED flashes when fired. • Authentic engine and firing sounds were recorded from a full-size vehicle and are coordinated with model actions. A large speaker in the model ensures rich sounds. • Turret upper section is secured by magnets, allowing hassle-free access to the electronics within. • A plethora of lights are recreated, including the turret front searchlight. They can be operated via transmitter. • Assembled link type tracks have elastomer recreations of the rubber pads for an authentic look. • Requires: 4-channel transmitter with self-neutral function, 7.2-volt Ni-Cd or Ni-MH battery pack & compatible charger, transmitter batteries and Tamiya model paint. Tamiya ATTACK 2.4GHZ RADIO SYSTEM recommended for complete compatibility with included Multi-Function Unit control system. Item 7255252 |
| Subject: Re: Tamiya new 1/16 M551 Tank Mon Mar 25, 2019 11:14 pm | |
| AAF is taking pre-orders for a $100 deposit. Should be out in May. |
| Subject: Re: Tamiya new 1/16 M551 Tank Mon Mar 25, 2019 11:22 pm | |
| it's pretty Cool Looking _____________________________________________ |
| Subject: Re: Tamiya new 1/16 M551 Tank Tue Mar 26, 2019 5:33 pm | |
| Subject: Re: Tamiya new 1/16 M551 Tank | |
