Strato's KV-2 Build Icon_minitimeby Shoveler74 Today at 6:03 am
Strato's KV-2 Build Icon_minitimeby hachleopard2 Sat Sep 14, 2019 7:23 pm
Strato's KV-2 Build Icon_minitimeby Jarlath Fri Sep 13, 2019 4:04 pm
Strato's KV-2 Build Icon_minitimeby Strato50 Wed Sep 11, 2019 10:50 pm
Strato's KV-2 Build Icon_minitimeby treemagnet Tue Sep 10, 2019 5:15 pm
Strato's KV-2 Build Icon_minitimeby Strato50 Tue Sep 10, 2019 3:29 am
Strato's KV-2 Build Icon_minitimeby knispel Tue Sep 10, 2019 1:21 am
Strato's KV-2 Build Icon_minitimeby Negaduck Sun Sep 08, 2019 5:09 pm
Strato's KV-2 Build Icon_minitimeby Strato50 Sat Sep 07, 2019 9:30 pm
Strato's KV-2 Build I_vote_lcapStrato's KV-2 Build I_voting_barStrato's KV-2 Build I_vote_rcap
 Strato's KV-2 Build
Go to page : 1, 2, 3  Next
Strato's KV-2 Build Empty
PostSubject: Strato's KV-2 Build   Strato's KV-2 Build Icon_minitimeSat Sep 29, 2012 5:33 am
I'm actually afraid of what this tank is going to be able to do... It gives me shivers.
KV-2 turret & hull, asiatam metal lower hull, 4:1 (?) steel gearboxs, plastic tracks.
from rctank.de
I wont be able to sleep now!
PostSubject: Re: Strato's KV-2 Build   Strato's KV-2 Build Icon_minitimeSat Sep 29, 2012 11:59 am
When do you get the beast?
I read recently that the KV-2 was way under powered, it would struggle climbing small inclines. Is yours going to have scale speed? Wink geek
PostSubject: Re: Strato's KV-2 Build   Strato's KV-2 Build Icon_minitimeSun Sep 30, 2012 4:17 am
Not sure about deliver times, let's hope though that they are as fast as Welsh is! ie, faster than Mato down the road from me Wink
And... stince... *shakes head* None of my tanks are scale speed Wink Tigers too fast, Panzer's too slow... Sherman doesn't flip over....
Very Happy
PostSubject: Re: Strato's KV-2 Build   Strato's KV-2 Build Icon_minitimeMon Oct 01, 2012 10:16 am
I can't wait to see where you put the sensors, we'll need a step ladder to hit it. affraid
PostSubject: Re: Strato's KV-2 Build   Strato's KV-2 Build Icon_minitimeTue Oct 09, 2012 1:59 pm
The beast has arrived! I am VERY impressed and very overwhelmed... I don't know where to start!!
It came in several small boxes and was very nicely packed, kudos to RCtank.de for that. Anyway I'll upload pics as I work along, so, firstly the unpacking.
The steel 4:1's (as they are advertised) are bulletproof. 3 connecting bars hold them together as well as 2 more screws in the base. They simply do not flex. Final drive shaft has 2 ball bearings each. Wow.
These, I think, are the new Taigen ones...
Strato's KV-2 Build Photo122
Sprockets are metal, and idler supported by another 2 ball bearings. Wow.
Only issue is that it seems the plastic track isn't a perfect mesh with the sprocket... after about 1/3 of a revolution it throws the track, its too tight. I'll see what I can do to remedy this.
Strato's KV-2 Build Photo123
Hull is another example of amazing Asiatam work. Torsion bars are nice and tight. Mounting plate for the TU's is a perfect alignment. No complaints here.
Strato's KV-2 Build Photo124
I'm guessing the upper hull is stock HL. The equipment bins are metal, and they've added a charging port for the battery. Neato! It has these ghastly gaps in the spots with no bins.. is that normal?
Strato's KV-2 Build Photo125
The turret is a work of art. Metal track hangers, metal ladder rungs. Asiatam recoil & elevation unit inside, flash unit, & even the connector for the stock HL battle apple in the cupula. Not sure if it has en emitter in there but I'll figure it out. Has 3 working hatches; cupula, original Russian hatch, and the big oven door on the back.
Strato's KV-2 Build Photo126
Strato's KV-2 Build Photo127
Strato's KV-2 Build Photo128
PostSubject: Re: Strato's KV-2 Build   Strato's KV-2 Build Icon_minitimeTue Oct 09, 2012 3:59 pm
Couldn't help but notice the PzIV still sits in the box yelling "don't forget about me" lol
Very nice tank - KV2
PostSubject: Re: Strato's KV-2 Build   Strato's KV-2 Build Icon_minitimeTue Oct 09, 2012 6:25 pm
I think we're going to have some epic battles next year. Twisted Evil
Elefant vs KV-2: The Beasts of the Battlefield!
PostSubject: Re: Strato's KV-2 Build   Strato's KV-2 Build Icon_minitimeTue Oct 09, 2012 6:43 pm
Hah! Yes Stinger, it does but I do keep it on top of the pile! Unlike my 1/16 tanks while I'm totally fine ruining with wacky paint jobs & constantly falling apart, I do want to spend good time on the 'dicker max!'
Hopefully I can figure out the wiring for the recoil, elevation etc...
Anyway, more pics!
Strato's KV-2 Build Photo129
Strato's KV-2 Build Photo130
PostSubject: Re: Strato's KV-2 Build   Strato's KV-2 Build Icon_minitimeTue Oct 09, 2012 8:17 pm
I hope to have my E-75 Super Heavy built for the spring time..clash of the Titans !
PostSubject: Re: Strato's KV-2 Build   Strato's KV-2 Build Icon_minitimeTue Oct 09, 2012 9:50 pm
Tracks are pretty tight, more than I'd like even at fully loose on the tensioner, enough to compress the front wheels more than they should be. Didn't come with spare links, so I'll be ordering some!!
Strato's KV-2 Build Photo131
Strato's KV-2 Build Photo132
PostSubject: Re: Strato's KV-2 Build   Strato's KV-2 Build Icon_minitimeTue Oct 09, 2012 10:37 pm
Looking good, maybe the plastic tracks will stretch a bit.
PostSubject: Re: Strato's KV-2 Build   Strato's KV-2 Build Icon_minitimeWed Oct 10, 2012 1:40 pm
Man, that looks like it could be trouble for Axis tanks .( better try and capture/ reflag it ) Razz
PostSubject: Re: Strato's KV-2 Build   Strato's KV-2 Build Icon_minitimeWed Oct 10, 2012 3:47 pm
I've settled on making it a German-capture version (hence the cupula and other minor mods, courtesy of Torro), that has been RE-captured by the Russians in time for their winter offensive.
So, I primed it a hearty battle-grey, and will possibly white-wash it... any suggestions from our painters? It looks really sharp now I don't want to 'ruin' it Wink I read someplace that simply mixing chalk & water can work!
Strato's KV-2 Build Photo133
Strato's KV-2 Build Photo134
real_hulu
real_hulu
PostSubject: Re: Strato's KV-2 Build   Strato's KV-2 Build Icon_minitimeWed Oct 10, 2012 4:15 pm
Wa。。。 it is beautiful...
Did you do the test run...
In my case, the HL track doesn't fit sprocket of metal low hull I purchased from Welsh dragon model. Especially, when you make a turn...
I have to buy tamiya tracks from the ebay.
PostSubject: Re: Strato's KV-2 Build   Strato's KV-2 Build Icon_minitimeWed Oct 10, 2012 4:33 pm
NOT YELLOW!!! affraid
How will you tell it apart from the other tanks? Wink
of the Pan-Tiger Panzer Div.
PostSubject: Re: Strato's KV-2 Build   Strato's KV-2 Build Icon_minitimeWed Oct 10, 2012 5:37 pm
Captured and re-captured ??? What is it a Italian tank or maybe French ??
Orange would be a nice colour .
The Great Pan-Tiger pirat
real_hulu
real_hulu
PostSubject: Re: Strato's KV-2 Build   Strato's KV-2 Build Icon_minitimeWed Oct 10, 2012 5:42 pm
NO,.. Captain.
Pink.... Pink should be the best... Very Happy
Strato's KV-2 Build Ash-pink-panther
PostSubject: Re: Strato's KV-2 Build   Strato's KV-2 Build Icon_minitimeWed Oct 10, 2012 7:02 pm
Yea neither did mine. I took a file and eventually a 1/4" drill bit in a press to the sprockets and ground some material off, they fit better but not perfectly.
I might do that in the future!
No electronics yet, I'd like to have an SLU in there though!
PostSubject: Re: Strato's KV-2 Build   Strato's KV-2 Build Icon_minitimeWed Oct 10, 2012 8:36 pm
LOVE IT
PostSubject: Re: Strato's KV-2 Build   Strato's KV-2 Build Icon_minitimeThu Oct 11, 2012 11:45 am
...accidentally bought GLOSS clear coat... tank is now shiny... g*d d*mnit! Razz
Question.. I was thinking for a worn out white-washed look, to apply spray-on white then wipe with lacquer thinner to wear it down for a severely beaten look... will the thinner eat through 3 clear coats and mess up my primer?? Considering everything is nice and cured for a day or 2.
PostSubject: Re: Strato's KV-2 Build   Strato's KV-2 Build Icon_minitimeThu Oct 11, 2012 1:14 pm
Strato, seal it with a clear coat, then spray the white with a water-based paint.
Remove what you want off by wiping it with a wet cloth or brush, if you take to much off add more white.
When your happy with it seal it again, just don't use gloss! Very Happy
If all else fails mail it to Airbrushler! tongue
PostSubject: Re: Strato's KV-2 Build   Strato's KV-2 Build Icon_minitimeThu Oct 11, 2012 8:21 pm
Hey Jordan
well i made this video for white washing but it's rather boring apparently to one person that commented on it...lol
https://www.youtube.com/watch?v=vCV-N7m1Rw0&feature=player_detailpage
PostSubject: Re: Strato's KV-2 Build   Strato's KV-2 Build Icon_minitimeThu Oct 11, 2012 9:41 pm
Ya, that was me. Sleep
geek
PostSubject: Re: Strato's KV-2 Build   Strato's KV-2 Build Icon_minitimeFri Oct 12, 2012 12:34 am
I actually remember watching that video! I think I'll be going that route it looks effective.
PostSubject: Re: Strato's KV-2 Build   Strato's KV-2 Build Icon_minitimeFri Oct 12, 2012 12:49 am
sometimes i do the white and sometimes i do a black wash
Strato's KV-2 Build
Page 1 of 3Go to page : 1, 2, 3  Next
