IR beam set up Icon_minitimeby hachleopard2 Yesterday at 7:23 pm
IR beam set up Icon_minitimeby Jarlath Fri Sep 13, 2019 4:04 pm
IR beam set up Icon_minitimeby Strato50 Wed Sep 11, 2019 10:50 pm
IR beam set up Icon_minitimeby treemagnet Tue Sep 10, 2019 5:15 pm
IR beam set up Icon_minitimeby Strato50 Tue Sep 10, 2019 3:29 am
IR beam set up Icon_minitimeby knispel Tue Sep 10, 2019 1:21 am
IR beam set up Icon_minitimeby Negaduck Sun Sep 08, 2019 5:09 pm
IR beam set up Icon_minitimeby Strato50 Sat Sep 07, 2019 9:30 pm
IR beam set up Icon_minitimeby Airbrushler Sat Sep 07, 2019 8:15 pm
IR beam set up I_vote_lcapIR beam set up I_voting_barIR beam set up I_vote_rcap
 IR beam set up
IR beam set up Empty
PostSubject: IR beam set up   IR beam set up Icon_minitimeSun Oct 07, 2012 4:16 pm
When doing an install of an IR system, the IR is placed inside a sleeve/barrel so that it doesn't bounce all over the place, yes, this I know. How far, depth wise, it the IR Bulb supposed to be from the end of the IR sleeve/barrel. I heard a few different figures being talked about. Any help would be appreciated.
PostSubject: Re: IR beam set up   IR beam set up Icon_minitimeSun Oct 07, 2012 4:22 pm
I use the 1/4"tube, 0.25"diameter (6.3 mm) Evergreen Models Item No. 228; full designation on the package.
I understand the tip of the emitter must be recessed 9 mm
Some of mine are 10 mm, there doesn't seem to be a problem with that.
PostSubject: Re: IR beam set up   IR beam set up Icon_minitimeSun Oct 07, 2012 4:29 pm
I'm assuming you are saying the ID is 1/4". I'm sure I have some of that pipe down stairs. Thanks Glen.
PostSubject: Re: IR beam set up   IR beam set up Icon_minitimeSun Oct 07, 2012 4:53 pm
Actually, the O.D. is 1/4", the I.D. is 5 mm
PostSubject: Re: IR beam set up   IR beam set up Icon_minitimeSun Oct 07, 2012 6:09 pm
I tested my IR bean and found even at 9 to 10 mm the angle of fire was about 30 degrees ! that seems pretty wide spread . Is there a beam spread rule?
PostSubject: Re: IR beam set up   IR beam set up Icon_minitimeSun Oct 07, 2012 7:26 pm
From the resources of the SLU FAQ section;
Can I mount the IR emitter in the mantlet?
Yes. See the following pics on how I mounted my IR emitter in my Panther's mantlet. I mounted the emitter in a plastic tube with the tip of the emitter recessed 9mm from the opening of the tube. This gives the IR beam a tight pattern vs a shot gun light spray. The 9mm recess is widely recognized as the IR battling standard, but check with your local club first.
I then drilled out the airsoft light from the mantlet and glued the tube in place. Next I drilled a hole next to the receiver and ran the emitter wire through it and plugged it into the receiver. Be sure that the wire does not block any of the IR receivers.
Source; http://soundandlightunit.weebly.com/faq.html
PostSubject: Re: IR beam set up   IR beam set up Icon_minitimeSun Oct 07, 2012 7:31 pm
I find that this is often because of testing indoors; outside you wont run into the 30 degree spread so much Razz
PostSubject: Re: IR beam set up   IR beam set up Icon_minitimeSun Oct 07, 2012 9:22 pm
I agree.
I also found that if you fire a shot in the garage you can get the beam to deflect off the metal garage door for some nice trick shots.
But you have to be careful because you can hit yourself. Mad
PostSubject: Re: IR beam set up   IR beam set up Icon_minitimeWed Oct 10, 2012 1:34 pm
Bank shots ! Brilliant
PostSubject: Re: IR beam set up   IR beam set up Icon_minitimeWed Oct 10, 2012 1:40 pm
All we need now is a Disco Mirror Ball and I'll wack all of you with one shot...lol
PostSubject: Re: IR beam set up   IR beam set up Icon_minitimeWed Oct 10, 2012 1:45 pm
LaughingLaughingLaughingLaughing
IR beam set up
