Subject: Tank in a box..... Mon Oct 12, 2020 10:25 am
Tired of pulling out other tanks to test IR battle systems when I work on them, so put everything in a box and will use it as active target practice. I guess this is the same as building a gun encampment for the battle field.
treemagnet Sergeant
Posts : 299 Join date : 2018-07-14 Location : Georgetown Ont
Subject: Re: Tank in a box..... Mon Oct 12, 2020 10:32 am
Hey Mike if you want I have something you can use its the sane system I used for the anti tank guns in KW no sound but leds for hits and shots to see that you are doing I can work up something for you Tom
Subject: Re: Tank in a box..... Mon Oct 12, 2020 2:24 pm
Hey Tom is it like a 3D printed bracket for the receiver and emitter ? I am okay with my set-up since I just pop in TBU when I need to and have tons of spare IR emitter laying around.
treemagnet Sergeant
Subject: Re: Tank in a box..... Mon Oct 12, 2020 3:44 pm
its an Adruino an emitter, receiver, and a couple of LEDs same set up for the anti tank guns and things to come :-)
Subject: Re: Tank in a box..... Mon Oct 12, 2020 7:00 pm
Subject: Re: Tank in a box..... Mon Oct 12, 2020 11:08 pm
Wow that's crazy. What about sensor ? What do you use ? Just a IR LED receiver ? Let me know how much would love to get one from you.
Posts : 587 Join date : 2017-03-23 Age : 49 Location : Prineville, Oregon
Subject: Re: Tank in a box..... Thu Oct 15, 2020 3:51 pm
Nice test bed Mike! Is that an IBU for a board?
Subject: Re: Tank in a box..... Sat Nov 14, 2020 3:05 pm
Okay so thanks to Dean I got this small DK unit which can act as a tester as well as stationary artillery or Air Strike on the battle field. So everything in a little project box, on/off bottom plus the fire button, and it has a sensor for taking hit plus a tiny speaker. This will be the new mobile IR tester, and I can use it in the field to fight other tanks or randomly call in Air/Artillery Strike !
Old_Tanker Private
Posts : 38 Join date : 2021-02-14 Location : Kitchener
Subject: Re: Tank in a box..... Wed Mar 10, 2021 9:06 pm
I know this is an older post but... though it might be good for the field
