hachleopard2 Captain
| Subject: New look of CrossRC HC6 Sat Apr 25, 2020 9:41 am | |
Last edited by hachleopard2 on Sat Apr 25, 2020 11:26 am; edited 4 times in total |
Posts : 3062 Join date : 2013-08-25 Location : Toronto, Ontario
| Subject: Re: New look of CrossRC HC6 Sat Apr 25, 2020 10:04 am | |
| Wow that is nice. Where did you get the fuel drums ? Are they to scale ? They looks the part for sure ! Mine will be slightly different, yellow and with a canvas top so don't need to worry about stowage ! Any plan for driver ? |
| Subject: Re: New look of CrossRC HC6 Sat Apr 25, 2020 10:33 am | |
| Mike. the fuel drum is in any hobby store. You should lower towing hitch make it look real and better to tow your howitzer. If you decide to paint in yellow. This truck has served in Desert Storm operation, after thatĀ US has retired this truck and replace with Oshkosh trucks. it should have black decal. HN |
| Subject: Re: New look of CrossRC HC6 Sat Apr 25, 2020 12:05 pm | |
| Subject: Re: New look of CrossRC HC6 Sat Apr 25, 2020 3:21 pm | |
| Subject: Re: New look of CrossRC HC6 Sun Apr 26, 2020 12:07 am | |
| Yeah. Should be able to. I'll have to look it up and start modelling when I'm at work. |
| Subject: Re: New look of CrossRC HC6 Sun Apr 26, 2020 12:19 am | |
| Thanks Mike. Mike C may need some ammo for his 155mm Howitzer too |
| Subject: Re: New look of CrossRC HC6 Mon Apr 27, 2020 12:08 pm | |
| I did a fast quick print of something I scaled surfing the web.... They are 37.8mm long (Scaled to 604.8mm). So I'm close... Only off by 0.1125mm LOL... Not too happy with the resolution, but they can be sanded down... Also have fuses to be fitted into the tips... (Also meh for how they turned out...) |
| Subject: Re: New look of CrossRC HC6 Mon Apr 27, 2020 12:31 pm | |
| You may want to just look at some .375 H&H polymer tipped bullets... They need to be about 1.5" in length and have a boat tail...
| Subject: Re: New look of CrossRC HC6 Mon Apr 27, 2020 5:43 pm | |
| That's good Mike. I can use sandpaper paper to smooth them. How about holder ? it can hold 8 of them. Thanks |
| Subject: Re: New look of CrossRC HC6 Mon Apr 27, 2020 5:46 pm | |
| - hachleopard2 wrote:
- That's good Mike. I can use sand paperĀ to smooth them. How about holder? Or use thin wood to make it. it can hold 8 of them.
Thanks |
| Subject: Re: New look of CrossRC HC6 | |
