| Subject: Re: AMX-13 75/90/105 ? Tue Sep 15, 2020 7:16 am | |
| Hey Mike. Are those the idlers that look like sewing machine spools in your image showing the kit parts? They look a tad large compared to the real thing....
The single pc road wheels and the 3 piece sprockets seem to match up...
N/M... I just noticed the PZ III remark... |
| Subject: Re: AMX-13 75/90/105 ? Tue Sep 15, 2020 11:42 am | |
| I will have to look at it when it is up. Not going to change it. The wheels are all from the kit. I am only using PzIII suspension bits.
Your recoil works perfectly in the thin turret. Will post some pictures as I have done more turret work since then. |
| Subject: Re: AMX-13 75/90/105 ? Wed Sep 16, 2020 6:18 am | |
| Geeze.. That turret looks like I 3D printed it... (I wish I had the files to do so). My recommendation is a servo for elevation. Servo in/on the rotation unit with lever arm either to the turret back edge of rotation or under the recoil unit. Further from the pivot point = greater fine control. |
| Subject: Re: AMX-13 75/90/105 ? Wed Sep 16, 2020 10:54 am | |
| Might put a small servo right where circled and use the elevation rail on the recoil. A little worry about the whole thing as the servo unit is only mounted mostly via that one piece of styrene at the front. We should see. |
| Subject: Re: AMX-13 75/90/105 ? | |
