| Subject: Re: IR LED for Tanks Sun Sep 20, 2020 2:10 pm | |
| - Jarlath wrote:
- Strato50 wrote:
- With your MG function turned on the bulb should remain bright as long as you have the trigger down.
It may appear that way, but it should be a duration (pulse) to determine hit type (MG vs Cannon) This will only work with Clark board. Tamiya and IBU does not shoot IR from the MG. But then this IR issue seems to be largely a Clark board problem. |
| Subject: Re: IR LED for Tanks Sun Sep 20, 2020 10:48 pm | |
But then this IR issue seems to be largely a Clark board problem. Oh I keep forgetting about you guys with disability control boards _____________________________________________ Tiger I - Panzer II - Panzer III - Panzer IV - Chi Nu Kai - Panther G - KV-1b 756(r) M4A3(76) Sherman - T-34/85 - M3 Grant - SECRET PROJECT
| Subject: Re: IR LED for Tanks Mon Sep 21, 2020 7:03 am | |
- This will only work with Clark board. Tamiya and IBU does not shoot IR from the MG.
But then this IR issue seems to be largely a Clark board problem. Dunno why you say it is an issue/problem when we are discussing features that Tamiya/IBU don't have. Still a discussion about LED's and how to measure their actual output performance... |
| Subject: Re: IR LED for Tanks Wed Apr 14, 2021 8:58 am | |
| On a Clark IR emitter bulb , does it matter on how it is wired , concerning a + side and - side wire hook up on the emitter ? If so how do you distinguish the positive side of the emitter ? _____________________________________________ The Great Pan-Tiger |
| Subject: Re: IR LED for Tanks Wed Apr 14, 2021 9:19 am | |
| Yes it does. If you look at the bulb, the longer leg is always the positive. If they are the same length, you need to look at the element itself. The smaller one is the positive. |
| Subject: Re: IR LED for Tanks Wed Apr 14, 2021 2:16 pm | |
| On a 5mm LED. IR or not, the longer leg is the +VE, and the flat side leg is the -VE. For those that cannot be examined, note the inside orientations of the "Anvil" and "Post". The larger section opposite the legs, is the is the Anvil and is the Cathode (-VE). |
| Subject: Re: IR LED for Tanks Wed Apr 14, 2021 2:38 pm | |
| I like mine explanation better. But Big Mike has the final word. |
| Subject: Re: IR LED for Tanks Thu May 20, 2021 10:45 am | |
| Finally added MikeC's IR Bulb to the list with specs. (Dean and I were talking about emitters again last night...) |
| Subject: Re: IR LED for Tanks | |
