| Not another Tiger I....... | |
| Subject: Not another Tiger I....... Sat Apr 24, 2021 11:22 pm | |
| Subject: Re: Not another Tiger I....... Sun Apr 25, 2021 1:54 pm | |
| LOL. Looks nice Mike. Does it work like the real early version Tiger and the barrel can knock off the corner mounted headlights?
| Subject: Re: Not another Tiger I....... Sun Apr 25, 2021 3:51 pm | |
| Yup. Not the S mine launchers though. Just the headlights. |
| Subject: Re: Not another Tiger I....... Tue Apr 27, 2021 2:22 pm | |
| Needs more yellow! _____________________________________________ Tiger I - Panzer II - Panzer III - Panzer IV - Chi Nu Kai - Panther G - KV-1b 756(r) M4A3(76) Sherman - T-34/85 - M3 Grant - SECRET PROJECT
Posts : 605 Join date : 2021-03-15 Location : Toronto
| Subject: Re: Not another Tiger I....... Mon May 03, 2021 6:06 pm | |
| I've just finished my IR battler Tiger 1 build. Just the tools and tow cables to add and the weathering. Could you if possible post an image of the inner hull with everything in place? Considering the size of the tank I found it a nightmare to try and get the wires and everything to fit and the Tamiya manual diagram is next to useless. The YouTube vids I saw just blow right past that step or they are using aftermarket stuff which fits a lot nicer. I don't want to look at the mess again until I have to recharge the batteries |
| Subject: Re: Not another Tiger I....... Tue May 04, 2021 12:02 am | |
| Subject: Re: Not another Tiger I....... Tue May 04, 2021 3:00 am | |
| Thanks for those images. So it's not just me as a newb. I'll clean up as much as I can with the zip ties and get the battery connectors into position under the turret opening and then just screw the top hull down. With 2 5000mah NiMH in there it must give at least 90 minutes of runtime with resin tracks. The tank I want to try and convert into my real IR battler is a Taigen metal airsoft Panther G. I figure with no recoil in the turret and ditching the smoker I should have a ton of room so it will just be me trying to figure out how an IBU2U board with a FlySky i6 with the Taigen wiring if it ever arrives at my door |
| Subject: Re: Not another Tiger I....... Tue May 04, 2021 9:37 am | |
| Crap sorry I forgot some of the Tamiya's (including my Tiger I) does not come with a Y adapter for the DMD and the MF unit so you need two batteries ! I DIYed a Tamiya Y adapter (didn't have a spare one) for this so I needed one battery, Lipo or NiMH.
That would help. You are correct when I first got this tank there was two old NiMH stacked in there and it was tight as a drum. |
| Subject: Re: Not another Tiger I....... | |
