For the 3D nerds Icon_minitimeby Smittyburger Sat May 18, 2024 11:54 pm
For the 3D nerds Icon_minitimeby ZackM Sat May 18, 2024 3:31 pm
For the 3D nerds Icon_minitimeby treemagnet Fri May 17, 2024 9:37 pm
For the 3D nerds Icon_minitimeby Shoveler74 Fri May 17, 2024 7:07 pm
For the 3D nerds Icon_minitimeby dgsselkirk Fri May 17, 2024 2:06 pm
» Super Pershing
For the 3D nerds Icon_minitimeby MikeC Fri May 17, 2024 9:16 am
For the 3D nerds Icon_minitimeby ZackM Thu May 16, 2024 9:55 pm
For the 3D nerds Icon_minitimeby Hammertime999999999 Wed May 15, 2024 5:29 pm
For the 3D nerds Icon_minitimeby HiawathaPete Tue May 14, 2024 11:41 am
For the 3D nerds I_vote_lcapFor the 3D nerds I_voting_barFor the 3D nerds I_vote_rcap
 For the 3D nerds
For the 3D nerds Empty
PostSubject: For the 3D nerds   For the 3D nerds Icon_minitimeThu Jan 28, 2021 1:11 pm
PostSubject: Re: For the 3D nerds   For the 3D nerds Icon_minitimeThu Jan 28, 2021 11:05 pm
Wall mount. A fancy internal thread with 4 screw holes to mount on the wall. $10 for STL file. Don't know the size of the thread. Purchased for $25
Magnetic Paddle stiffener. Holds a pair of magnets to give a more positive "click" when shifting. $8 for STL file. Likely 1-2 hours of print time, 4 magnets. Purchased for $33
Manual Torque ring for wheel securing. $8 for the STL file. Likely 1-2 hours of print time. Purchased for $20.
All depends on the time and effort it took to design and test. To me, my sell costs would be less than those retail costs, but I don't market myself. Plus it depends on the material used as well as what the internal fill (infil %) is.
Below is roughly what I would charge.
Wall mount is worth about $12.50-$15.00 in material/print time/wear & tear. Fairly large solid print.
Paddle shifters are harder to guage. Is it preassembled? If so, $7.50-$12.50 in material/print time/wear & tear, $5-10 in labour.
Torque ring is $5.00-7.50 in material/print time/wear & tear. It is a slide-on piece that is an easy print. By far the worst of the three in markup.
These prices would already assume that the designs had been formalized and tested for fit & finish. That alone can add a couple bucks for each pattern (Example is the 10+ prototypes for fit and functionality I did for my gen-1 recoil unit, which is a lot more complicated that those listed.)
PostSubject: Re: For the 3D nerds   For the 3D nerds Icon_minitimeFri Jan 29, 2021 12:01 am
So even with the file you still need to test print ? What is wear and tear ?
I thought the pedal shifts are one piece other than the magnet insert. Do you think it is printed on multiple pieces ? I am surprise that these are the most expensive ones (I shouldn't since he charges them the most). These are really the ones I am interested in.
Thanks for the pricing info !
PostSubject: Re: For the 3D nerds   For the 3D nerds Icon_minitimeFri Jan 29, 2021 12:14 am
I use ABS which has a shrinkage % depending on a multitude of factors. Size and shape being just a part of it.
So yes testing in my case.
I've worn out 6 nozzles ($50) and replaced my print bed ($350) in the last 3 years. I'll likely need to replace/tension adjust my drive belts soon. My guess is 20 kg or so of ABS in 3 years.
Power outages & browns causing failed prints 6+ hours into an 8 hour print... Yay!
Again hard to visualise the shifters. Maybe very simple, or more complex. I dunno. Was a guess.
PostSubject: Re: For the 3D nerds   For the 3D nerds Icon_minitimeFri Jan 29, 2021 9:30 am
Okay thanks !
PostSubject: Re: For the 3D nerds   For the 3D nerds Icon_minitimeFri Jan 29, 2021 12:34 pm
I took a better look at the paddle shifters.
2 identical pieces, each with a pair of magnets glued in place.
You still need adhesive double sided tape to affix the paddles to the back of the wheel. (Or glue).
For the 3D nerds
Can-Am RC Tank Club :: Assembly Area :: The Lounge-
