Heng Long 5.3 track recoil Icon_minitimeby Abteilung 506 Today at 11:09 am
Heng Long 5.3 track recoil Icon_minitimeby MikeC Today at 9:33 am
Heng Long 5.3 track recoil Icon_minitimeby Chimo Yesterday at 7:06 pm
Heng Long 5.3 track recoil Icon_minitimeby HiawathaPete Yesterday at 6:04 pm
Heng Long 5.3 track recoil Icon_minitimeby dgsselkirk Sat May 11, 2024 8:13 pm
Heng Long 5.3 track recoil Icon_minitimeby HiawathaPete Thu May 09, 2024 4:10 pm
Heng Long 5.3 track recoil Icon_minitimeby Jarlath Thu May 09, 2024 10:27 am
Heng Long 5.3 track recoil Icon_minitimeby Jarlath Wed May 08, 2024 3:29 pm
» Matomart Sale again
Heng Long 5.3 track recoil Icon_minitimeby MikeC Sun May 05, 2024 10:59 pm
Heng Long 5.3 track recoil I_vote_lcapHeng Long 5.3 track recoil I_voting_barHeng Long 5.3 track recoil I_vote_rcap
Heng Long 5.3 track recoil Empty
PostSubject: Heng Long 5.3 track recoil   Heng Long 5.3 track recoil Icon_minitimeSat Mar 27, 2021 11:27 pm
Is there a way to adjust track recoil on a Heng Long version 5.3 King Tiger?
I know on the version 6.0 you can adjust the recoil level with the K + S keys on the transmitter, but that does not work on the version 5.3
PostSubject: Re: Heng Long 5.3 track recoil   Heng Long 5.3 track recoil Icon_minitimeSat Mar 27, 2021 11:56 pm
No. 5.3 was not controllable by the main MFU.
There were aftermarket boards that removed track recoil for them.
PostSubject: Re: Heng Long 5.3 track recoil   Heng Long 5.3 track recoil Icon_minitimeSun Mar 28, 2021 12:10 am
Thanks Jarlath
As a quick & dirty alternative, I was wondering if it's possible to simply disconnect a wire.
I tried googling '5.3 wiring diagram' and found this, but I'm not sure if it's the correct one for v5.3. The main board seems to have a connector labelled 'track recoil'.
https://www.rctankwarfare.co.uk/forums/download/file.php?id=63143&mode=view
Thanks again.
PostSubject: Re: Heng Long 5.3 track recoil   Heng Long 5.3 track recoil Icon_minitimeSun Mar 28, 2021 9:00 am
It is the two wires that connect to the small cotact switch that is on the BB/Recoil unit in the turret. When the switch closes (completes the circuit) the board then causes track recoil and the sound effect. No switch = No track recoil and No "Cannon Boom".
Shorting the switch means never ending track recoil and cannon sound effect
PostSubject: Re: Heng Long 5.3 track recoil   Heng Long 5.3 track recoil Icon_minitimeSun Mar 28, 2021 9:10 am
An option that has been done in the past without replacing the MFU is to use one of the following:
ATRC: Anti Track Recoil Circuit, when the recoil switch circuit is completed, this cuts power to the motors, thereby diabling the track recoil. Drawback, no shooting while moving (which is bad for the driveline with track recoil on anyways). I also do not think anyone makes a ATRC anymore...
MAKO: A plug in board that contains ATRC and makes the tank Tamiya compatible (to a certain extent). These have gotten very expensive... May be cheaper to buy a 6.0 replacement TX/MFU combo.
PostSubject: Re: Heng Long 5.3 track recoil   Heng Long 5.3 track recoil Icon_minitimeSun Mar 28, 2021 9:38 am
Wow, then I guess that's not an option - I like having the "boom" sound. Thanks for the info. Clears up a lot of grey areas for me.
I just got the KT not knowing it wasn't the latest version. Am planning to return the tank (it's brand new) for a 6.0 version so I haven't taken it apart.
If that falls through, then I like your suggestion of upgrading the 5.3 to a 6.0. I see some places have the kits including the tx, looks like I'd have to get the IR attachments & wiring separate. Thanks again!
» Can-Am Battleday October 2014?
» Heng Long track recoil & firing sound intermittently not working
» Heng Long JT
» Heng Long T34/85
» Heng Long v6.0S MFU
