riverboat Recruit
Posts : 6 Join date : 2021-03-27
| Subject: need a little help lol Mon Mar 29, 2021 12:18 am | |
| OK just got a Moto 1/16 tiger, tracks were on the idlers wrong so got one done do the other one tomorrow. but the nut on the tensioner is what size?? I tride 6,7 mm no good its half why between them so tried a 1/4 and a 9/32 same thing any one know what size it is?? and is there a radio up grade this matotoys black with good trim is junk would like one that i can have buttons on it to activate sound guns ex not this push the stick this why and the other one this why lol any help would be grate thanks |
Posts : 3278 Join date : 2013-02-12 Age : 64 Location : Kitchener ON
| Subject: Re: need a little help lol Mon Mar 29, 2021 12:38 am | |
| Hi Riverboat,
Where are you located? _____________________________________________ "There are things in Russia which are not as they seem..." Georgy Konstantinovich Zhukov
riverboat Recruit
| Subject: Re: need a little help lol Mon Mar 29, 2021 1:05 am | |
| I live on Vancouver Island |
Ukiewolf Sergeant
| Subject: Re: need a little help lol Mon Mar 29, 2021 7:32 am | |
| it is 3mm - - - I bought from Amazon a set of 2 and 3mm bolts, nuts, lock washers and washers with various length bolts and replaced the short standard bolt with a much longer bolt to accommodate easier adjusting. also, those tiny nuts and bolts like to escape and hide!!! _____________________________________________ Being new to this hobby, I am meeting a super group of people willing to share their knowledge and assistance. _____________________________________________________________________________ |
Ukiewolf Sergeant
| Subject: Re: need a little help lol Mon Mar 29, 2021 7:38 am | |
| OBTW - Brand: DANA FRED $22.92 Phillips Pan Round Head Machine Screw Cross Round Metric Threaded Bolts Nuts Flat Lock Washer Metal Standard Fastener Hardware SAE Assortment Kit Set 304Stainless Steel 800Pcs M2 M3 _____________________________________________ Being new to this hobby, I am meeting a super group of people willing to share their knowledge and assistance. _____________________________________________________________________________ |
| Subject: Re: need a little help lol Mon Mar 29, 2021 8:42 am | |
| Hey Riverboat, A couple questions and this is where images can help a lot. You got a 1/16 Mato Tiger I correct? I assume it is a metal version? (aka metal lower hull) Have you looked inside the tank yet? If so, do you have this inside that the idlers mount to? (Track tension adjuster set). Did you get this controller with it? |
riverboat Recruit
| Subject: Re: need a little help lol Mon Mar 29, 2021 9:24 am | |
| yes thats the radio that my idler is just a nut coming through the body loosen it up and move the arm out side it has indents got one done last night but its like I need a 6.5 mm wrench for it
I found this radio
Turnigy 9X 9Ch Transmitter w/ Module & iA8 Receiver (Mode 1) (AFHDS 2A system |
riverboat Recruit
| Subject: Re: need a little help lol Mon Mar 29, 2021 9:25 am | |
Ukiewolf Sergeant
| Subject: Re: need a little help lol Mon Mar 29, 2021 10:01 am | |
| ahhh. all metal. then my solution was based on a plastic tanks with TK6.0/6.1 MFU. then the info from Jarlath is more relevant. sorry for the misunderstanding. _____________________________________________ Being new to this hobby, I am meeting a super group of people willing to share their knowledge and assistance. _____________________________________________________________________________ |
| Subject: Re: need a little help lol Mon Mar 29, 2021 7:06 pm | |
| - riverboat wrote:
- yes thats the radio that
I found this radio
Turnigy 9X 9Ch Transmitter w/ Module & iA8 Receiver (Mode 1) (AFHDS 2A system) No issues with this radio. You will have to program the buttons/switches for creating separate functions however. Your control board will likely be a TK-22 which means that the controls are all normally controlled through 2 joysticks (4 channel control scheme to run many functions). Two axes (one joystick) is used for track direction and steering. The other is for multi-function controls. Turret rotation/elevation/Head light LED on-off/MG/Main Cannon/Engine on-off. |
| Subject: Re: need a little help lol | |
