Heng Long King Tiger IR emitter problem Icon_minitimeby dgsselkirk Today at 4:42 pm
» Matomart Sale again
Heng Long King Tiger IR emitter problem Icon_minitimeby MikeC Yesterday at 10:59 pm
» TongDe New Tank
Heng Long King Tiger IR emitter problem Icon_minitimeby Abteilung 506 Yesterday at 5:48 pm
Heng Long King Tiger IR emitter problem Icon_minitimeby Robert B. Marks Yesterday at 1:08 pm
» Martin's PZ III combat god?
Heng Long King Tiger IR emitter problem Icon_minitimeby Abteilung 506 Yesterday at 9:39 am
Heng Long King Tiger IR emitter problem Icon_minitimeby dgsselkirk Yesterday at 1:52 am
Heng Long King Tiger IR emitter problem Icon_minitimeby dgsselkirk Sun Apr 28, 2024 5:20 pm
» Panther 1 to 1
Heng Long King Tiger IR emitter problem Icon_minitimeby Jarlath Sun Apr 28, 2024 3:47 pm
Heng Long King Tiger IR emitter problem Icon_minitimeby MikeC Sun Apr 28, 2024 12:51 pm
Heng Long King Tiger IR emitter problem I_vote_lcapHeng Long King Tiger IR emitter problem I_voting_barHeng Long King Tiger IR emitter problem I_vote_rcap
Heng Long King Tiger IR emitter problem Empty
PostSubject: Heng Long King Tiger IR emitter problem   Heng Long King Tiger IR emitter problem Icon_minitimeThu May 27, 2021 2:29 pm
Hi folks,
I was wondering if anyone else here has experienced this. My Heng Long 6.0 King Tiger is no longer "sending" hits to any of my other two HL tanks.
It's not an issue with the IR receivers on my other tanks (HL Sherman & HL Tiger I) because they both send and receive hits on each other OK.
My King Tiger however will receive, but not send hits. It's only a couple months old and was working fine till now.
At the bottom of this post is a video of my KT emitter as compared to my Sherman.
In the first part of the video (sorry for the lighting, it gets better later) the IR flash pattern is present but looks erratic as compared to my Sherman. At this point my KT was only able to send hits to other tanks very intermittently (about 1 in 10 firings)
In the second part of the video, the KT emitter has now stopped working completely (no flash at all).
The third part of the video shows my fully functional Sherman IR emitter.
So my question is: What is the most likely culprit - IR emitter LED? or MFU board?
And if it is a problem with the MFU, is there a way to 'pair' a new 6.0 board with my current 6.0 transmitter, or would I need to buy both the the board and transmitter together as a package?
I'm going to open the tank up later to check for anything obvious like a wiring or connection issue, but I have my doubts that is the problem as the emitter was flashing initially.
Thanks in advance for any feedback you can provide.  Aye Aye
PostSubject: Re: Heng Long King Tiger IR emitter problem   Heng Long King Tiger IR emitter problem Icon_minitimeThu May 27, 2021 2:46 pm
Hey Pete, one thing you can check very quickly is swap the KT broad with the Sherman board and see if you have the same problem. If you do then chances it is probably the IR emitter LED. If not then your Sherman will not work and it is probably the HL board.
You can pair HL board with different radio so you can just replace the faulty board.
You might also find that both of them are working in which case it is probably a loose wire.........  :-)
PostSubject: Re: Heng Long King Tiger IR emitter problem   Heng Long King Tiger IR emitter problem Icon_minitimeThu May 27, 2021 3:02 pm
Thanks Mike!  Smile Sounds good. If not some obvious broken connection or other, I'll see if the problem transfers to the other tank when I swap the board.
If it does turn out to be the board, I was wondering how do you pair a new board to your transmitter? (ie is it the same process as described in the HL instruction manual when powering the tank up for the first time using the "lock" button on the transmitter - Or would I need to buy a new crystal or something?)
Thanks again! Pete
PostSubject: Re: Heng Long King Tiger IR emitter problem   Heng Long King Tiger IR emitter problem Icon_minitimeThu May 27, 2021 3:38 pm
Yes just following the same instruction to bind the new board to your existing radio.
PostSubject: Re: Heng Long King Tiger IR emitter problem   Heng Long King Tiger IR emitter problem Icon_minitimeThu May 27, 2021 4:58 pm
Also check your wiring. Occasionally the wiring will get "eaten" but the turret rotation gears.
Odds are that it is the Bulb. Which is a cheaper fix than a new MFU.
PostSubject: Re: Heng Long King Tiger IR emitter problem   Heng Long King Tiger IR emitter problem Icon_minitimeFri May 28, 2021 4:30 pm
Swapped the MFU's (the KT board in the Sherman & the Sherman board in the KT) and the problem did not transfer - KT still not 'sending' hits (and Sherman still good). In all likelihood not a board problem.
Took the tank completely apart, visually inspected LED wiring -looks OK.
Going to order a new HL emitter LED & wiring harness and replace.
Mike C and Jarlath -thank you once again for the info, you guys rock!
Best Regards, Pete
PostSubject: Re: Heng Long King Tiger IR emitter problem   Heng Long King Tiger IR emitter problem Icon_minitimeFri May 28, 2021 4:52 pm
If you are handy with the soldering iron I would try replacing the IR bulb first. There are dim and a dozen and you can get it much cheaper and faster.
PostSubject: Re: Heng Long King Tiger IR emitter problem   Heng Long King Tiger IR emitter problem Icon_minitimeFri May 28, 2021 5:43 pm
I'm good with a soldering iron and have no problem ordering an IR LED from newark electronics or digikey: https://www.digikey.ca/en/products/detail/osram-opto-semiconductors-inc/SFH-4545/2205955
But I'm still thinking replace the harness with new wiring (in addition to replacing the LED) to circumvent any possible intermittent problem with the Heng Long factory wiring.
Matomart also sells the OEM Heng Long LED together with harness for 4.14CAD:
https://www.matomart.com/prodview.php?p=493 .
Still have to decide which route I'm going to take.
Cheers, Pete
PostSubject: Re: Heng Long King Tiger IR emitter problem   Heng Long King Tiger IR emitter problem Icon_minitimeFri May 28, 2021 9:21 pm
What do you mean the harness ? Do you mean the JST connector that goes onto the board ? The link you sent from Matomart is just the IR emitter with wires. I have all the plugs and crimper so I can make one for you with a new IR emitter and mail it to you. Save you money and time. Just send me a picture of what you need.
PostSubject: Re: Heng Long King Tiger IR emitter problem   Heng Long King Tiger IR emitter problem Icon_minitimeFri May 28, 2021 10:27 pm
Hi Mike. By harness I meant the wires/leads.
I know the one from Mato comes without connectors, so yes technically it's not really a harness. I just bought the LED+wires from Mato and am simply going to re-use the existing 2 pin connector by cutting it out of the circuit leaving an inch or two of the old wire at the connector end and soldering the new LED wires to that ... Not perfect but that's what I'm doing for now.
But if I have a future need for LED's/wiring/connectors, I would certainly consider giving you a shout (I just noticed the personal message button here on the forum for the first time)
Thanks again & Best Regards, Pete
PostSubject: Re: Heng Long King Tiger IR emitter problem   Heng Long King Tiger IR emitter problem Icon_minitimeFri Jun 11, 2021 3:23 pm
King Tiger fixed - problem was the IR LED - which I've since replaced. Thanks MikeC & Jarlath!
PostSubject: Re: Heng Long King Tiger IR emitter problem   Heng Long King Tiger IR emitter problem Icon_minitimeFri Jun 11, 2021 5:10 pm
Cool.
PostSubject: Re: Heng Long King Tiger IR emitter problem   Heng Long King Tiger IR emitter problem Icon_minitimeSat Jun 12, 2021 5:53 pm
YAY. Love solutions that work!
» Weird problem with my Heng Long T-34
» Heng Long 1/6 Tiger I
» 1/16 Heng Long Tiger 1 R.C Tank
» Tiger Power's Stock Heng Long KT with Mako2
» Tiger I/King Tiger hatches/cupola For Sale
