Battery type? Icon_minitimeby dgsselkirk Yesterday at 4:25 pm
Battery type? Icon_minitimeby Shoveler74 Thu May 09, 2024 10:10 pm
Battery type? Icon_minitimeby HiawathaPete Thu May 09, 2024 4:10 pm
Battery type? Icon_minitimeby Jarlath Thu May 09, 2024 10:27 am
Battery type? Icon_minitimeby Jarlath Wed May 08, 2024 3:29 pm
» Matomart Sale again
Battery type? Icon_minitimeby MikeC Sun May 05, 2024 10:59 pm
» TongDe New Tank
Battery type? Icon_minitimeby Abteilung 506 Sun May 05, 2024 5:48 pm
» Martin's PZ III combat god?
Battery type? Icon_minitimeby Abteilung 506 Sun May 05, 2024 9:39 am
Battery type? Icon_minitimeby dgsselkirk Sun May 05, 2024 1:52 am
Battery type? I_vote_lcapBattery type? I_voting_barBattery type? I_vote_rcap
 Battery type?
Old_Tanker
Battery type? Empty
PostSubject: Battery type?   Battery type? Icon_minitimeTue Feb 23, 2021 8:01 am
Which battery type to you guys/gals prefer and why??
I'm old school rc'r from back int he dirt track days (Black Widow Speedway etc for those who remember)
LiPo
NiCad
NiMh
Thanks in advance,
Russ
Battery type? Empty
PostSubject: Re: Battery type?   Battery type? Icon_minitimeTue Feb 23, 2021 9:23 am
NiCad (1910, 1899 origin) is old school battery tech that had fast charge times, good temperature stability and high cycle times, but suffer from memory effect and were not environmentally friendly.
NiMh (1989, 1970 origin) is the current standard of simple rechargeable battery types and has higher capacity, can be charged many times, but have very fast transitions of voltage (When power is low it fades FAST).
LiPo (1997, 1970 origin) is the current generation of high energy density battery. Higher more stable power output, but the chemical reaction of the component parts results in "Puffing" (electrolyte decomposition). Limited cycle life.
I personally use Lipo's and still have a plethora of NiMh batteries.
(5000 MaH NiMh runs my KV-1 for an 3/4 oh an hour, 5000 MaH LiPo runs it for 2.)
Some rules of thumb: (Ignoring NiCd, since it is toxic and not really used anymore...)
NiMh: Run them from 100% to 0% before recharging. Reduces memory effect. In the tank, usually the sound starts to go wonky when the battery power is low.
LiPo: Make sure to connect a battery alarm. Lipo's generate heat when they have current overdraw (not likely with our tanks) and when there is resistance in their cells (caused by delamination of anode/cathode layers, aka electrolyte decomposition). Aka the more puffed they are, the more puffed they become when used. There is NO way to stop the decomposition. Use proper chargers, and inspect your batteries. A good thread for LiPo's.
Old_Tanker
Battery type? Empty
PostSubject: Re: Battery type?   Battery type? Icon_minitimeTue Feb 23, 2021 11:21 am
Thanks Mike.
Good info for sure... LiPo has always worried me....but I like the run time you get from your Wink
I still have some Nicads kicking around....lol I run them through my battery charger/conditioner
Maybe I'll play it safe and get NiMh..
Battery type? Empty
PostSubject: Re: Battery type?   Battery type? Icon_minitimeSat Mar 27, 2021 9:25 am
I know I'm coming in late here, but might I suggest Li-ion batteries?  They're very similar to the LiPo in terms of performance, but they tend to catch on fire far less often.
They're what I use in my tank, anyway.
Battery type? Empty
PostSubject: Re: Battery type?   Battery type? Icon_minitimeSat Mar 27, 2021 11:17 am
Li-Ion is a viable alternatives for our tanks.
For a comparable battery (voltage & mAH):
Li-Ion is cheaper, but heavier and usually have a lower cycle life (number of recharges). Li-Ion also can have a memory effect and cannot be used for high discharge applications (High power ESCs like for RC cars). 1/16 tanks do not require more than 20C discharge rates (even 10C is good enough) due to the huge gearbox reductions and slow speed/acceleration. Unless you are Ren...
Tanker
Recruit
Battery type? Empty
PostSubject: Re: Battery type?   Battery type? Icon_minitimeSun Mar 28, 2021 10:03 am
I've been using Lipos for a number of year's in my RC planes with no issue.
BUT you do need to properly maintain them.
Don't over charge and don't drain them right down.
Buy a good quality charger if your going to use lipo batteries and ALWAYS monitor when charging.
Woody6063
Recruit
Battery type? Empty
PostSubject: Re: Battery type?   Battery type? Icon_minitimeWed Jun 23, 2021 3:28 pm
Does anyone know if you can run 3s Lipo in the new HL 7.0 Leopard ?
Battery type? Empty
PostSubject: Re: Battery type?   Battery type? Icon_minitimeWed Jun 23, 2021 5:57 pm
I was looking at the Heng Long 6.0/6.1 and 7.0/7.1 yesterday and noticed all of them has input power rated at 7.4v to 12.6v so my take would be that you are good to go. Don't know if they are lipo aware but just stick a lipo warning plug on it and you are good to go. 3S is rated at 11.1v nominal and even with the overage you are only looking at 12.1v at most.
Woody6063
Recruit
Battery type? Empty
PostSubject: Re: Battery type?   Battery type? Icon_minitimeWed Jun 23, 2021 8:25 pm
thanks for the reply MikeC Smile
Battery type? Empty
Battery type?
» New RC Tamiya JGDF Type 10 tank
» ROC Hobby 1/12 Kubelwagen Type 82
» Type 3 Chi Nu - Japanese Tank
» 1/16 Tamiya JGSDF Type 10
» WWII German Type VII Submarine
