Hammertime999999999 Captain
Posts : 807 Join date : 2017-01-09 Location : Waterloo ON
| Subject: Re: It’s Alive!! Thu Sep 01, 2022 10:13 pm | |
| That's cool. Will be interesting to see it totally resurrected. Considering how many of the very old Tamiya Shermans you see still on Ebay there must be some threads on forums on how to get them running to modern standards. Speaking of resurrections my late version Tiger is totally resurrected after it's upside down equivalent of a 300 foot drop and running on my good IBU with everything working but the recoil that never works on Taigens . It really is amazing how little damage happened and how easy it was to fix |
| Subject: Re: It’s Alive!! Thu Sep 01, 2022 10:26 pm | |
| I’ll have to research that. It would be really great to get thing updated and battling against all the Sherman’s.
When I ran it on the floor I was surprised to see how fast it moved after being used to the plodding KT.
Ahh that tough German armour, it is like a timex! |
| Subject: Re: It’s Alive!! Fri Sep 02, 2022 12:08 am | |
| Very nice ! Just put in some new electronics and you are good to go ! I know Leo1A4 are all built like that didn't know early Sherman also. |
| Subject: Re: It’s Alive!! Fri Sep 02, 2022 7:46 am | |
| Most of the gen 1 Tamiya's are the single motor, clutch steer system. 2nd Gen are twin motors. and the 3rd gen are the twin motors with the black plastic housings on them. |
| Subject: Re: It’s Alive!! Fri Sep 02, 2022 12:22 pm | |
| Interesting!
So mine’s a dual motor dual clutch...I must say hearing that drivetrain run after 20+ years of it sitting in a box after running in mud made my heart skip a beat...and appreciate the high quality of Tamiya products.
Now if they can fab up some actual hatch handles and not just blobs of plastic! |
| Subject: Re: It’s Alive!! Fri Sep 02, 2022 2:31 pm | |
| Except I don't believe that Tamiya ever made a twin motor, dual clutch system. My guess it that it is a well made kit bashed version. The non-bullet connectors on the motors is the 2nd clue... |
| Subject: Re: It’s Alive!! Fri Sep 02, 2022 2:37 pm | |
| Bought ‘er brand new cellophane still on box and assembled myself. |
| Subject: Re: It’s Alive!! Fri Sep 02, 2022 3:09 pm | |
| A picture of the front cover of instructions: kit # RT1601 and I think printed 7511. This thing is way older than Ren and possibly almost older than a few here. |
| Subject: Re: It’s Alive!! Sat Sep 03, 2022 12:05 pm | |
| - Hammertime999999999 wrote:
- Interesting!
Mitch, There is two clutches in theory but this is not a dual clutch. The fact that you have two drive motors vs single one does not change the clutch which is control by one servo. All it means is that it is driven by two motors vs a single motor. There is not two clutch control, right ? It is still just a single lever controlled by the direction servo. This is the picture of the single motor version. Yours won't be any different than this, just when you drive it is driven by two motors vs one. The clutch when engaged will stop one or the other motors to turn. Otherwise both motor will drive straight. |
| Subject: Re: It’s Alive!! Sat Sep 03, 2022 6:36 pm | |
| Subject: Re: It’s Alive!! Sat Sep 03, 2022 10:38 pm | |
| Hey Mike,
Just out of curiosity, what is the history of the tank in your image?
Mitch |
| Subject: Re: It’s Alive!! Sat Sep 03, 2022 11:02 pm | |
| It is a Leo1A4 even though the tracks looks like it is a Sherman. I can't remember which is which, but I have owned multiple Leo 1A4's as it is one of my favorite tank. This is either from Dean, or I have build one for Lester (another club member) which subsequently sold it to Greg and I ended up buying it from his estate (Dean and Les will have to confirm this as I don't really remember).
Early Tamiya single motor clutch drive system. |
| Subject: Re: It’s Alive!! Sun Sep 04, 2022 12:21 pm | |
| Ahh, looks like my Sherman tracks but different drive configuration...did the tracks come assembled out of the box, or did you have to piece them together like I had to? |
| Subject: Re: It’s Alive!! Sun Sep 04, 2022 12:24 pm | |
| No zinc tracks that came assembled and I probably couldn't take them apart if I wanted to. The clutch lever should be the same, resting position means both gears (motors in your case) would work, and pull one way would stop/clutch one side and the other way would stop/clutch the other track to turn. |
| Subject: Re: It’s Alive!! Sun Sep 04, 2022 12:53 pm | |
| I ended up making a jig to start the track pins into the endconnecter otherwise the chamfer on the pins would make them go into the endconnector askew and then it was really tough to straighten them out. |
| Subject: Re: It’s Alive!! Sun Sep 04, 2022 12:54 pm | |
| It’s always amazing how the instructions make it look easy |
| Subject: Re: It’s Alive!! Sun Sep 04, 2022 1:11 pm | |
| So true with Tamiya. It's like how they show an example of the wiring fitting perfectly into the tiny amount space of space available on tanks like the JPIV or Pershing but then they forget that putting in their battle system totally throws a wrench into the whole mess. Of course I'm having my own WTH time with the Clark board. I thought I would be messed up where there was soldering involved but I am totally lost at sea. Not sure if I'm even looking at the right manual as all I can find is the TK40 one on the Clark site. |
| Subject: Re: It’s Alive!! Sun Sep 04, 2022 2:13 pm | |
| Sounds like a Tylenol moment. |
| Subject: Re: It’s Alive!! Sun Sep 04, 2022 2:29 pm | |
| Subject: Re: It’s Alive!! Sun Sep 04, 2022 2:41 pm | |
| Pull out either Tamiya KT, run it around, have a beer and enjoy! You will soon forget the letters C L A R K... |
| Subject: Re: It’s Alive!! Sun Sep 04, 2022 4:06 pm | |
| Wow... I stand corrected! Information search! Dual Motor, Dual Clutch Gearbox
Tamiya RT5601/56001, M4 Sherman, Released November 1974 This Sherman was the ONLY 1/16 RC Tank to use that dual motor, clutch driven system. Single Motor, Dual Clutch, Split gearbox (Separated drive gearsets)
Tamiya 56002, Leopard 1A4, Released July 1977 Tamiya 56003, Gepard, Released October 1978 Single Motor, Dual Clutch, Combined Gearbox (Gen 1 as a image above)Tamiya 56004, King Tiger (H), Released July 1981 Dual Motor, Separate Drive (No Clutch) (Gen 2 as a image above)Tamiya 56005/56006, M4 Sherman, Released December 1998 Tamiya 56007/56008, King Tiger (P), Released June 1999 Tamiya 56009/56010/560011, Tiger I, Released August 2000 Dual Motor, Separate Drive, Plastic covers (Gen 3 as a image above)Tamiya 56013/56014, M4 Sherman, Released June 2001 Tamiya 56015/56016, M26 Pershing, Released June/March 2002 Tamiya 56017/56018, King Tiger (H), Released November 2002 Tamiya 56021/56022, Panther A, Released March 2007 Tamiya 56023/56024, JagdPanther, Released December 2007 Tamiya 56025/56026, Panzer IV-J, Released July 2008 Tamiya 56027/56028, KV-1, Released June/April 2009 Tamiya 56029/56030, KV-2, Released October/September 2009 Tamiya 56031/56032, Super Sherman, Released November/October 2010 Tamiya 56033, Tiger I, Released December 2011 Tamiya 56034/56035, JS-2, Released Feb/Jan 2013 Tamiya 56038/56039, Jagdpanzer IV/70, Released September 2016 Dual Motor, Separate drive, formed plastic (Gen 4)Tamiya 56019/56020, Leopard 2A6, Released June 2004 Tamiya 56036/56037, JSDF Type 10, Released March 2015 Tamiya 56040/56041, M1A2 Abrams, Released December 2017 Dual Motor, Separate drive, No Plastic (Gen 5)
Tamiya 56041/56042, M155 Sheridan, Released July 2019 Tamiya 56043/56044, Centurion Mk. III, Released December 2021 |
| Subject: Re: It’s Alive!! Sun Sep 04, 2022 5:28 pm | |
| Subject: Re: It’s Alive!! | |
