Need advice for beginner. Icon_minitimeby Smittyburger Sat May 18, 2024 11:54 pm
Need advice for beginner. Icon_minitimeby ZackM Sat May 18, 2024 3:31 pm
Need advice for beginner. Icon_minitimeby treemagnet Fri May 17, 2024 9:37 pm
Need advice for beginner. Icon_minitimeby Shoveler74 Fri May 17, 2024 7:07 pm
Need advice for beginner. Icon_minitimeby dgsselkirk Fri May 17, 2024 2:06 pm
» Super Pershing
Need advice for beginner. Icon_minitimeby MikeC Fri May 17, 2024 9:16 am
Need advice for beginner. Icon_minitimeby ZackM Thu May 16, 2024 9:55 pm
Need advice for beginner. Icon_minitimeby Hammertime999999999 Wed May 15, 2024 5:29 pm
Need advice for beginner. Icon_minitimeby HiawathaPete Tue May 14, 2024 11:41 am
Need advice for beginner. I_vote_lcapNeed advice for beginner. I_voting_barNeed advice for beginner. I_vote_rcap
MedicalMercenary
Recruit
Need advice for beginner. Empty
PostSubject: Need advice for beginner.   Need advice for beginner. Icon_minitimeThu Nov 24, 2022 10:02 am
Hi all,
Looking to purchase two HL tanks from Matomart that are IR battle-ready out of the box.  How can I tell if any particular model/configuration is applicable?  I'm not knowledgeable enough to do any of upgrades on my own right now. Just want to be that cool dad who bought RC tanks for his kids to battle in the basement Christmas morning.  grin
Any advice is greatly appreciated.  Maybe I can take advantage of their Black Friday sales.
Cheers
PostSubject: Re: Need advice for beginner.   Need advice for beginner. Icon_minitimeThu Nov 24, 2022 1:14 pm
When you are looking at a tank on Matomart and you want them to be able to combat each other, make sure you look for those tanks that have the "IR" label in the description.
Example: "Newest Henglong 1:16 M4A3 Sherman RC Tank with Steel Gearbox IR and Airsoft Special Version" or "Newest Henglong 1:16 Panzer III R/C Tank Steel Gearbox IR and Airsoft"
I would also try and make sure that the tanks are the same control versions to ensure 100% IR battle compatibility.
The Airsoft side of the tanks will break the plastic bits and piece off another tank if you forget to remove the airsoft BB's.
MedicalMercenary
Recruit
PostSubject: Re: Need advice for beginner.   Need advice for beginner. Icon_minitimeSat Nov 26, 2022 10:40 am
Thanks Jarlath. Gonna pull the trigger on a HL Panther and a Pershing.
Can’t wait for Christmas!
PostSubject: Re: Need advice for beginner.   Need advice for beginner. Icon_minitimeMon Nov 28, 2022 8:02 am
Now I will give you a bit of advanced warning.
After some time, the idler mounts will crack, and you will start throwing tracks.
This is just a design weakness of all plastic hull tanks.
Track tension continually stresses the idlers. And it will happen at some point.
The harder you drive these tanks on terrain that has turning resistance (aka grass). the larger the forces experienced by the idler mount.
If your tank suddenly starts turning in one direction, you likely have a jammed track. Do NOT try and power through it. You break tracks that way.
krijn
krijn
PostSubject: Re: Need advice for beginner.   Need advice for beginner. Icon_minitimeSat Feb 18, 2023 10:06 pm
Greetings
Does anyone know the voltage of the "machine gun" led's of the heng long and mato tanks using a Clark TK22 board ?
thanks in advance
Krijn
705th Armored Brigade. (Peterborough)
Krijn
https://www.facebook.com/groups/975850753212371
PostSubject: Re: Need advice for beginner.   Need advice for beginner. Icon_minitimeMon Feb 20, 2023 12:12 am
I believe it's 5V
krijn
krijn
PostSubject: Re: Need advice for beginner.   Need advice for beginner. Icon_minitimeMon Feb 20, 2023 11:26 am
Thank you Doug,
i have a few 6V led's i can try and see if they work. if not the voltage must be lower or higher.. if all i get is a flash.
hard to measure voltages on a DVM when the input is onoffonoffonoffon in rapid succession.
Krijn
Krijn
» looking for newbie advice
