DKLM M60A2 "Starship" Icon_minitimeby Smittyburger Sat May 18, 2024 11:54 pm
DKLM M60A2 "Starship" Icon_minitimeby ZackM Sat May 18, 2024 3:31 pm
DKLM M60A2 "Starship" Icon_minitimeby treemagnet Fri May 17, 2024 9:37 pm
DKLM M60A2 "Starship" Icon_minitimeby Shoveler74 Fri May 17, 2024 7:07 pm
DKLM M60A2 "Starship" Icon_minitimeby dgsselkirk Fri May 17, 2024 2:06 pm
» Super Pershing
DKLM M60A2 "Starship" Icon_minitimeby MikeC Fri May 17, 2024 9:16 am
DKLM M60A2 "Starship" Icon_minitimeby ZackM Thu May 16, 2024 9:55 pm
DKLM M60A2 "Starship" Icon_minitimeby Hammertime999999999 Wed May 15, 2024 5:29 pm
DKLM M60A2 "Starship" Icon_minitimeby HiawathaPete Tue May 14, 2024 11:41 am
DKLM M60A2 "Starship" I_vote_lcapDKLM M60A2 "Starship" I_voting_barDKLM M60A2 "Starship" I_vote_rcap
DKLM M60A2 "Starship" Empty
PostSubject: DKLM M60A2 "Starship"   DKLM M60A2 "Starship" Icon_minitimeMon May 15, 2023 12:41 am
Well I am always a sucker for the next shining object from DKLM........... Apparently this is the next one. Always like the 152mm cannon so M551 Sheridan and the Starship is always on my wish list. Will be mated to the OKMO M60A3 kit that I have on the shelf. This turret is available for the TongDe M60A3 as well, but the details is somewhat lacking and the turret itself would cost more than the TongDe tank it is going on........ But fear not, if you buy the TongDe version you can also get a detail kit that will compensate for the lack of details on the TongDe body.
https://www.dklmrc.com/details/p2389473_22110894.aspx
DKLM M60A2 "Starship" 34700210
PostSubject: Re: DKLM M60A2 "Starship"   DKLM M60A2 "Starship" Icon_minitimeMon May 15, 2023 9:04 am
That is all resin?
PostSubject: Re: DKLM M60A2 "Starship"   DKLM M60A2 "Starship" Icon_minitimeMon May 15, 2023 9:09 am
SLA 3DP.
PostSubject: Re: DKLM M60A2 "Starship"   DKLM M60A2 "Starship" Icon_minitimeSat Aug 12, 2023 10:52 pm
Well everything has been build and now have to sort out the electronics. The OEM stuff is fine for a simple tank, but the DKLM M60A2 turret has separate cupola rotation and elevation so will have to mate it to something to make everything working.
DKLM M60A2 "Starship" Dscn2865
DKLM M60A2 "Starship" Dscn2866
DKLM M60A2 "Starship" Dscn2910
PostSubject: Re: DKLM M60A2 "Starship"   DKLM M60A2 "Starship" Icon_minitimeSat Aug 12, 2023 10:53 pm
More pics.
DKLM M60A2 "Starship" Dscn2867
DKLM M60A2 "Starship" Dscn2912
DKLM M60A2 "Starship" Dscn2911
PostSubject: Re: DKLM M60A2 "Starship"   DKLM M60A2 "Starship" Icon_minitimeSun Aug 13, 2023 10:01 am
Looks awesome Mike! Unique !!
PostSubject: Re: DKLM M60A2 "Starship"   DKLM M60A2 "Starship" Icon_minitimeSun Aug 13, 2023 11:48 am
Looks great and the upper is fantastic...
I'm just not thrilled about he lower hull construction...
Side mounted gearboxes don't help with hull flex.
Seen posts of the torsion bar retaining blocks breaking when run on high suspension travel terrain.
PostSubject: Re: DKLM M60A2 "Starship"   DKLM M60A2 "Starship" Icon_minitimeSun Aug 13, 2023 2:25 pm
Couple of the plastic swing arms are shot after one battle day so I have to upgrade to metal ones with the metal gearbox and the metal tracks as well as ball bearings. Runs much more realistic now and heavy as hell. Will see how it works out.
The upper is only good because of the upgrades from DKLM's kit. They use parts from their much more expensive custom M60A3 which I have also.
Sandy, you are right I am starting to think they are all 1/15 rather than 1/16 as I put it next to the Leo1A4 and it looks like it is from a different planet. On the otherhand, I did a google search and the M60 is quite large compares to its contemporary Leo1s and the next gen M1s.
DKLM M60A2 "Starship" 34e21710
DKLM M60A2 "Starship" 23127410
PostSubject: Re: DKLM M60A2 "Starship"   DKLM M60A2 "Starship" Icon_minitimeSun Aug 13, 2023 2:34 pm
Hi Mike - not sure about the rest of the Tongde lineup, but I had read on one of the forums that the Tongde Bradley was 1/15 scale to accommodate the drive train. Not sure how true that is but nevertheless that’s not too much of an issue and no one will ever notice on the battle field while running and hiding!
PostSubject: Re: DKLM M60A2 "Starship"   DKLM M60A2 "Starship" Icon_minitimeSun Aug 13, 2023 2:37 pm
Ah I see. I have it on order and I rather it be 1/15 than 1/18.
Still the M60 looks a little large........ But maybe not if you look at the photo.
PostSubject: Re: DKLM M60A2 "Starship"   DKLM M60A2 "Starship" Icon_minitimeTue Aug 15, 2023 12:26 am
Turret functions testing video. It has servo elevation for the main gun and the cupola MG, and motor drive for the turret and cupola rotation. I need to use a small ESC to control the cupola rotation as there isn't enough motor drive port on the IBU (or any other board for that matter).
PostSubject: Re: DKLM M60A2 "Starship"   DKLM M60A2 "Starship" Icon_minitimeTue Aug 15, 2023 8:42 am
Very cool Mike!
PostSubject: Re: DKLM M60A2 "Starship"   DKLM M60A2 "Starship" Icon_minitimeSat Aug 19, 2023 1:27 pm
Looks awesome. Can you get an insanely bright LED in the light fixture? Ha haa
PostSubject: Re: DKLM M60A2 "Starship"   DKLM M60A2 "Starship" Icon_minitimeSat Aug 19, 2023 2:31 pm
I didn’t setup the spot light yet but that can be accomplish quite easily.
PostSubject: Re: DKLM M60A2 "Starship"   DKLM M60A2 "Starship" Icon_minitimeSun Aug 20, 2023 3:46 pm
Some pics of the details in the DKLM/OKMO turret and also the detail kit on the upper of the TongDe. It is better than most Heng Longs. A good combination of RTR body and custom tank details.
DKLM M60A2 "Starship" Dscn2913
DKLM M60A2 "Starship" Dscn2914
DKLM M60A2 "Starship" Dscn2915
PostSubject: Re: DKLM M60A2 "Starship"   DKLM M60A2 "Starship" Icon_minitimeSun Aug 20, 2023 3:47 pm
DKLM M60A2 "Starship" Dscn2916
DKLM M60A2 "Starship" Dscn2918
DKLM M60A2 "Starship" Dscn2917
PostSubject: Re: DKLM M60A2 "Starship"   DKLM M60A2 "Starship" Icon_minitimeSun Aug 20, 2023 3:48 pm
DKLM M60A2 "Starship" Dscn2921
DKLM M60A2 "Starship" Dscn2920
DKLM M60A2 "Starship" Dscn2919
PostSubject: Re: DKLM M60A2 "Starship"   DKLM M60A2 "Starship" Icon_minitimeSun Aug 20, 2023 5:08 pm
Fantastic detail Mike. What did you use for the view ports on the cupola - look great.
PostSubject: Re: DKLM M60A2 "Starship"   DKLM M60A2 "Starship" Icon_minitimeSun Aug 20, 2023 10:39 pm
I had this sheet of reflective material on both side. It changes colour depends on the viewing angle. I got it either from Dean or from Carson at DKLM. It is card board like and you just cut size and it works great.
» OKMO/DKLM T-90MS Prototype Kit
» DKLM Churchill Mk VII
» DKLM website
» New items on DKLM RC
» Double present from Carson/DKLM
