Latest batch of Tk-22A from Matomart Icon_minitimeby dgsselkirk Today at 8:16 am
Latest batch of Tk-22A from Matomart Icon_minitimeby Shoveler74 Yesterday at 10:10 pm
Latest batch of Tk-22A from Matomart Icon_minitimeby HiawathaPete Yesterday at 4:10 pm
Latest batch of Tk-22A from Matomart Icon_minitimeby Jarlath Yesterday at 10:27 am
Latest batch of Tk-22A from Matomart Icon_minitimeby Jarlath Wed May 08, 2024 3:29 pm
» Matomart Sale again
Latest batch of Tk-22A from Matomart Icon_minitimeby MikeC Sun May 05, 2024 10:59 pm
» TongDe New Tank
Latest batch of Tk-22A from Matomart Icon_minitimeby Abteilung 506 Sun May 05, 2024 5:48 pm
» Martin's PZ III combat god?
Latest batch of Tk-22A from Matomart Icon_minitimeby Abteilung 506 Sun May 05, 2024 9:39 am
Latest batch of Tk-22A from Matomart Icon_minitimeby dgsselkirk Sun May 05, 2024 1:52 am
Latest batch of Tk-22A from Matomart I_vote_lcapLatest batch of Tk-22A from Matomart I_voting_barLatest batch of Tk-22A from Matomart I_vote_rcap
Latest batch of Tk-22A from Matomart Empty
PostSubject: Latest batch of Tk-22A from Matomart   Latest batch of Tk-22A from Matomart Icon_minitimeWed Mar 13, 2024 7:12 pm
So I purchased two T1 and one KV board from Matomart on my last order. The KV was fine as far as I can tell, but one of the T1 board will not file the cannon. Th strange part is that I can get elevation, engine start and MG, which means that it is reading that channel, but no matter what I do I couldn't get cannon fire.
Thinking it might be my radio which doesn't make sense but you never know, I swap it with the second T1 board I got, and it can fire no problem. So it is not the radio. However, then I realized that the elevation is doing really strange stuff, so I plug in the volt meter and found out that the elevation port is given out constant voltage.
My work around right now is to switch the tank to use servo elevation which is fine. I hate the Clark's motor elevation and servo elevation control anyway, but I am now worry that I have a bad batch of Clark boards.
Did I mentioned I hate Clark boards ? I am just getting used to them again, small plugs and all, after the defection to Tamiya and IBUs and now this.
I might have to start looking at Heng Long 7.1's just for playing around boards. The new guy Chris has it on the PanTiger at the March 9th meet and it worked great. Since it is only 5 hits and not adjustable I can just use them for all my mediums like Shermans etc.
PostSubject: Re: Latest batch of Tk-22A from Matomart   Latest batch of Tk-22A from Matomart Icon_minitimeWed Mar 13, 2024 8:02 pm
Odd... TK-22's are pretty much bulletproof unless you burn out a FET. I've had dozens of them... Literally...
Likely a soldering/circuit issue on the board. Note the error, send it back to Matomart (if you can?).
Refund/replace?
PostSubject: Re: Latest batch of Tk-22A from Matomart   Latest batch of Tk-22A from Matomart Icon_minitimeWed Mar 13, 2024 10:23 pm
big Mike, we discussed this problem with the clarks from Mato. We had to change the elevation back to regular from servo and that fixed that exact problem MikeC.
PostSubject: Re: Latest batch of Tk-22A from Matomart   Latest batch of Tk-22A from Matomart Icon_minitimeWed Mar 13, 2024 11:16 pm
Damn. I had too much time today. Already converted it to servo elevation. Probably for the better anyway.
What do you mean by converting back to regular from servo ? Is it set for servo as a default ? I have no change the elevation setting.
Still doesn't address my firing problem on board # 1 but I have a feeling it is a radio issue even thought it didn't happen after I swap the board, but one problem at a time.
PostSubject: Re: Latest batch of Tk-22A from Matomart   Latest batch of Tk-22A from Matomart Icon_minitimeWed Mar 13, 2024 11:30 pm
Yes, it did affect the firing because you can't fire while the gun is elevating. I am sure it fixed both problems because it did EXACTLY the same thin on the Sherman boards I got. Prices on Matomart have gone up again. I might have to start ordering direct again... :-)
PostSubject: Re: Latest batch of Tk-22A from Matomart   Latest batch of Tk-22A from Matomart Icon_minitimeThu Mar 14, 2024 3:05 pm
Okay thanks mate.
PostSubject: Re: Latest batch of Tk-22A from Matomart   Latest batch of Tk-22A from Matomart Icon_minitimeThu Mar 14, 2024 7:41 pm
Well that worked. When I turn on servo rotation I can fire again. I assume that it is the elevation motor like you said. Someone had their logic gate programming messed up. It should be the other way around.
Either way though there shouldn't be power to the elevation motor regardless of the setting.
» Latest addition from UK
» My latest kit bashing - M36 Jackson
» My latest build - ARC Reactor Mk I
» Airbrushers Latest Painting Job
» Latest Information for RC show at Tet Festival 2015
