Martin's PZ III combat god? Icon_minitimeby Smittyburger Yesterday at 11:54 pm
Martin's PZ III combat god? Icon_minitimeby ZackM Yesterday at 3:31 pm
Martin's PZ III combat god? Icon_minitimeby treemagnet Fri May 17, 2024 9:37 pm
Martin's PZ III combat god? Icon_minitimeby Shoveler74 Fri May 17, 2024 7:07 pm
Martin's PZ III combat god? Icon_minitimeby dgsselkirk Fri May 17, 2024 2:06 pm
» Super Pershing
Martin's PZ III combat god? Icon_minitimeby MikeC Fri May 17, 2024 9:16 am
Martin's PZ III combat god? Icon_minitimeby ZackM Thu May 16, 2024 9:55 pm
Martin's PZ III combat god? Icon_minitimeby Hammertime999999999 Wed May 15, 2024 5:29 pm
Martin's PZ III combat god? Icon_minitimeby HiawathaPete Tue May 14, 2024 11:41 am
Martin's PZ III combat god? I_vote_lcapMartin's PZ III combat god? I_voting_barMartin's PZ III combat god? I_vote_rcap
Martin's PZ III combat god? Empty
PostSubject: Martin's PZ III combat god?   Martin's PZ III combat god? Icon_minitimeMon Apr 29, 2024 9:25 pm
I guess I must be building tanks fairly well as this was my 3rd commission from Martin.
This time around, instead of a big heavy full metal Taigen tank, Martin commissioned me to rebuild his all plastic PZ III.
Martin's PZ III combat god? Pz3-0110
I did not touch the gearboxes themselves, just the wiring.
Cleaned up the former stiffeners and trimmed the internal cutting to nice clean vesions.
Added in the resin floor base from gearbox "wall" to the butt-end of the hull.
Elevated mounting tray for the TK board to allow for airflow to the bottom side of the board. (Never trust these things to stay cool since the TK40 Sound Amp BS).
Nice 20W speaker w/ vented mount that includes the power switch housing. More than enough speaker for any TK-50. As he informed me, the supplied TK board has a blown sound amp, but otherwise the Board seems to work fine. Side hull mounted volume control (It and the speaker work, I tried the setup with another TK Board).
I finished the lower and have been chasing RX issues. New TX/RX and the controls work well once again!
Currently using a 10 channel RX, because the original 6 channel ones must have come from the same places Dean bought his. The original 6 didn't work with the S-Bus.
Martin's PZ III combat god? Pz3-0210
Other 3/4 view.
Upper hull fixes. I upgraded the upper hull magnets, fixed the headlight wiring and cleaned it up.
I still may replace the MG LED, as it does not currently function.
Martin's PZ III combat god? Pz3-0310
And now the part that was the most interesting option requested.
Replace the original airsoft barrel with the supplied scale barrel. Recoil unit and if possible servo elevation.
Martin did not care about the barrel flash which had a 3mm LED in the scale 5cm barrel. So I had to find some 3mm IR Emitter LED's. Not cheap...
The barrel itself needed about a 10mm extension to be able to fit with the recoil unit, so Aluminum 8mm OD x 5mm ID tube with a 5mm OD x 4mm ID brass stiffener.
Martin's PZ III combat god? Pz3-0410
LED size comparison shown between the 3mm and a typical 5mm LED. Tested at 50cm as a test on my Bulldog. Hits registered. Success!
Have yet to test distance shooting however, so effective range is unknown. Also unknown is lifetime of the LED.
Martin's PZ III combat god? Pz3-0510
Unlike the huge turrets of the KT and cupola location in the Panther, the PZ 3 & 4 house the elevation in the turret bustle. So no real room to made servo elevation. Sorry Martin! But a nice custom apple mount that fits perfectly in the center of the removable cupola.
Just need to finish the turret mods (for the recoil unit) and reassemble and test (and for range with the new IR Emitter)!
PostSubject: Re: Martin's PZ III combat god?   Martin's PZ III combat god? Icon_minitimeMon Apr 29, 2024 9:41 pm
Man your wiring is beautiful!
PostSubject: Re: Martin's PZ III combat god?   Martin's PZ III combat god? Icon_minitimeMon Apr 29, 2024 11:18 pm
Nice. Is Tk-50 same foot print as the old Tk20 series ?
PostSubject: Re: Martin's PZ III combat god?   Martin's PZ III combat god? Icon_minitimeMon Apr 29, 2024 11:47 pm
TK2x - TK4x - TK5x are all the same basic foot print.
The TK2x series had a 3rd screw hole by the volume connection. The other 2 holes are in the same locations.
TK6x & TK-8x have the same foot print too.
PostSubject: Re: Martin's PZ III combat god?   Martin's PZ III combat god? Icon_minitimeTue Apr 30, 2024 9:25 am
Ah okay. I have only seen Tk60s and TK80s. Wasn't sure about the 40s and 50s.
PostSubject: Re: Martin's PZ III combat god?   Martin's PZ III combat god? Icon_minitimeTue Apr 30, 2024 6:14 pm
Looking real nice. I hope the emitter works good enough to use on the field. Not looking for huge range anyway as that is not how I want to use the tank. More to work with a Tiger like in the early Tiger battalions. I do like the realistic size barrel over the way too big airsoft one
PostSubject: Re: Martin's PZ III combat god?   Martin's PZ III combat god? Icon_minitimeTue Apr 30, 2024 7:04 pm
Yes it is!
I may, finally be pulling that pz3 I have out of the box and start cutting. We'll compare some time.
PostSubject: Re: Martin's PZ III combat god?   Martin's PZ III combat god? Icon_minitimeThu May 02, 2024 8:34 pm
And no Sound TK-50S PZ3 board swapped for a Tiger I and fully setup as a light Tank. LOL...
Martin's PZ III combat god? Camera12
The guts once I finished... with it. Relocated daughterboard as with the plugs installed, it hung up on the battery!
Martin's PZ III combat god? Panzer10
PostSubject: Re: Martin's PZ III combat god?   Martin's PZ III combat god? Icon_minitimeThu May 02, 2024 8:35 pm
Video was still processing when I first posted this... So give it time...
Video finished...
PostSubject: Re: Martin's PZ III combat god?   Martin's PZ III combat god? Icon_minitimeFri May 03, 2024 12:17 am
That recoil is sweet. Yea it is funny to hear the Tiger sounds on a light tank but I can confess to having no idea as to what the Panzer III board sounds will be. The tank in it's original condition from MatoMart was a total joke. Fortunately I knew you were going to a great job on the internals it so didn't care. Also since it won't be used as my everyday tank I'm hoping the plastic suspension arms, return rollers, idlers will hold up. The plastic tracks I imagine will help in that and they are so cheap to replace as they stretch
PostSubject: Re: Martin's PZ III combat god?   Martin's PZ III combat god? Icon_minitimeFri May 03, 2024 6:48 am
Nice!
PostSubject: Re: Martin's PZ III combat god?   Martin's PZ III combat god? Icon_minitimeFri May 03, 2024 4:26 pm
Very nice !
PostSubject: Re: Martin's PZ III combat god?   Martin's PZ III combat god? Icon_minitimeSun May 05, 2024 9:39 am
For anyone wanting to do a PZIII this popped up as a recommendation on YT. Probably the best resource outside of a museum I've seen for looking at the details on them. The one part where they are parking them in the enclosure after the surrender shows some pretty skilled driving too
https://www.youtube.com/watch?v=qVEnteNh2OU
» Night Combat
» Combat: The Duel
» IR Combat Hit Chart
» The IR LED too powerful for combat :O
» Night combat on Sep 28. 2018
