| Screw needed for Taigen Tiger road wheel | |
Kagan Recruit
Posts : 7 Join date : 2013-03-29
| Subject: Screw needed for Taigen Tiger road wheel Fri Mar 29, 2013 7:18 pm | |
| I lost one. I have no idea how and suspect that it was never assembled with it in place. Anyway, I need it before I can use the tank. Anyone have one that I could buy from them? It's 4mm Dia, 40.5mm OAL, 28mm shank with 9.2mm threaded end. Any assistance would be appreciated. -Art |
| Subject: Re: Screw needed for Taigen Tiger road wheel Fri Mar 29, 2013 7:44 pm | |
| Would you be able to post a picture of what you need? _____________________________________________ "Luck favours the prepared!."
Kagan Recruit
| Subject: Re: Screw needed for Taigen Tiger road wheel Fri Mar 29, 2013 8:19 pm | |
| I tried to attach a photo on the first post. I'll try again. - Code:
Kagan Recruit
| Subject: Re: Screw needed for Taigen Tiger road wheel Fri Mar 29, 2013 8:24 pm | |
Kagan Recruit
| Subject: Re: Screw needed for Taigen Tiger road wheel Fri Mar 29, 2013 8:26 pm | |
| Subject: Re: Screw needed for Taigen Tiger road wheel Fri Mar 29, 2013 8:39 pm | |
| Are you sure that is from a Taigen Tiger I (or perhaps a Tiger II, sometimes called a King Tiger) The reason is that the description doesn't match anything on the Taigen Tiger I that I just completed. This is what you sent; The Taigen Tiger I has metal road wheel axles, secured to a metal swing arm with a 3mm set screw; The screw in the picture looks like a Heng Long Tiger road wheel screw, or possibly one from a Taigen King Tiger. If we can figure this out, someone here should be able to help. _____________________________________________ "Luck favours the prepared!."
Kagan Recruit
| Subject: Re: Screw needed for Taigen Tiger road wheel Fri Mar 29, 2013 8:48 pm | |
| The sticker next to the battery cover says Taigen. It could very well be a King. Sorry, I'm new at rc tanks. Any other identifiers that I could look for? The manual says German Tiger I, Taigen 3818-1. |
Kagan Recruit
| Subject: Re: Screw needed for Taigen Tiger road wheel Fri Mar 29, 2013 9:08 pm | |
| Subject: Re: Screw needed for Taigen Tiger road wheel Fri Mar 29, 2013 9:22 pm | |
| Subject: Re: Screw needed for Taigen Tiger road wheel Fri Mar 29, 2013 9:36 pm | |
| Are the swing arms plastic or metal? Is the upper hull attached with screws, or this system in the pictures; _____________________________________________ "Luck favours the prepared!."
Stinger Captain
| Subject: Re: Screw needed for Taigen Tiger road wheel Fri Mar 29, 2013 9:38 pm | |
| . I have what you need Art. Send me a PM and we can make arrangements to get it to you. Stinger _____________________________________________ My Tanks <<== Click hereCan-Am Tank Club <<< Web site linkTiger I | King Tiger | Panther G | PzIII | PzIV | Stug IV | SturmTiger | Pershing/Howitzer | M16 Halftrack | M26 Super Pershing | M48 Patton | M41 Bulldog | Gepard | Leopard | KV-1 | KV-2 |T-34 | |
| Subject: Re: Screw needed for Taigen Tiger road wheel Fri Mar 29, 2013 9:40 pm | |
| I knew someone here would come through _____________________________________________ "Luck favours the prepared!."
Kagan Recruit
| Subject: Re: Screw needed for Taigen Tiger road wheel Fri Mar 29, 2013 10:04 pm | |
| Just for clarification sake, under the rear mud flaps there are #2 Philips screws. What the heck have I got? How do I reference my tank model the next time I encounter a problem? It seems there are many generations/variations and manufacturers trading under different names. Yikes! |
| Subject: Re: Screw needed for Taigen Tiger road wheel Fri Mar 29, 2013 10:14 pm | |
| I suspect that you have what is basically a Heng Long Tiger I marked by Taigen.
This isn't a bad thing, since there are lots of parts, replacement and upgrade, for Heng Longs.
The threaded road wheel screw should be easy to get and I assume that is what Stinger is offering (he has an impressive collection of bits & pieces).
THe Taigen Tigers like mine are what they call HC version, some of the differences are the quick release upper hull and the way the turret goes together, your turret looks like the Heng Long turret.
I think the Heng Long parts should fit your tank. _____________________________________________ "Luck favours the prepared!."
Stinger Captain
| Subject: Re: Screw needed for Taigen Tiger road wheel Fri Mar 29, 2013 10:38 pm | |
| Correct you are Glen, it is a standard HL screw that I just went down to my parts bin and stripped out one of my Tiger parts tanks. Stinger _____________________________________________ My Tanks <<== Click hereCan-Am Tank Club <<< Web site linkTiger I | King Tiger | Panther G | PzIII | PzIV | Stug IV | SturmTiger | Pershing/Howitzer | M16 Halftrack | M26 Super Pershing | M48 Patton | M41 Bulldog | Gepard | Leopard | KV-1 | KV-2 |T-34 | |
| Subject: Re: Screw needed for Taigen Tiger road wheel | |
