Screw needed for Taigen Tiger road wheel Icon_minitimeby hachleopard2 Sat Sep 14, 2019 7:23 pm
Screw needed for Taigen Tiger road wheel Icon_minitimeby Jarlath Fri Sep 13, 2019 4:04 pm
Screw needed for Taigen Tiger road wheel Icon_minitimeby Strato50 Wed Sep 11, 2019 10:50 pm
Screw needed for Taigen Tiger road wheel Icon_minitimeby treemagnet Tue Sep 10, 2019 5:15 pm
Screw needed for Taigen Tiger road wheel Icon_minitimeby Strato50 Tue Sep 10, 2019 3:29 am
Screw needed for Taigen Tiger road wheel Icon_minitimeby knispel Tue Sep 10, 2019 1:21 am
Screw needed for Taigen Tiger road wheel Icon_minitimeby Negaduck Sun Sep 08, 2019 5:09 pm
Screw needed for Taigen Tiger road wheel Icon_minitimeby Strato50 Sat Sep 07, 2019 9:30 pm
Screw needed for Taigen Tiger road wheel Icon_minitimeby Airbrushler Sat Sep 07, 2019 8:15 pm
Screw needed for Taigen Tiger road wheel I_vote_lcapScrew needed for Taigen Tiger road wheel I_voting_barScrew needed for Taigen Tiger road wheel I_vote_rcap
Kagan
Recruit
Screw needed for Taigen Tiger road wheel Empty
PostSubject: Screw needed for Taigen Tiger road wheel   Screw needed for Taigen Tiger road wheel Icon_minitimeFri Mar 29, 2013 7:18 pm
I lost one. I have no idea how and suspect that it was never assembled with it in place. Anyway, I need it before I can use the tank. Anyone have one that I could buy from them?
It's 4mm Dia, 40.5mm OAL, 28mm shank with 9.2mm threaded end.
Any assistance would be appreciated.
-Art
PostSubject: Re: Screw needed for Taigen Tiger road wheel   Screw needed for Taigen Tiger road wheel Icon_minitimeFri Mar 29, 2013 7:44 pm
Would you be able to post a picture of what you need?
Kagan
Recruit
PostSubject: Re: Screw needed for Taigen Tiger road wheel   Screw needed for Taigen Tiger road wheel Icon_minitimeFri Mar 29, 2013 8:19 pm
I tried to attach a photo on the first post. I'll try again.
Code:
Kagan
Recruit
PostSubject: Re: Screw needed for Taigen Tiger road wheel   Screw needed for Taigen Tiger road wheel Icon_minitimeFri Mar 29, 2013 8:24 pm
Kagan
Recruit
PostSubject: Re: Screw needed for Taigen Tiger road wheel   Screw needed for Taigen Tiger road wheel Icon_minitimeFri Mar 29, 2013 8:26 pm
Did it work?
PostSubject: Re: Screw needed for Taigen Tiger road wheel   Screw needed for Taigen Tiger road wheel Icon_minitimeFri Mar 29, 2013 8:39 pm
Are you sure that is from a Taigen Tiger I (or perhaps a Tiger II, sometimes called a King Tiger)
The reason is that the description doesn't match anything on the Taigen Tiger I that I just completed.
This is what you sent;
Screw needed for Taigen Tiger road wheel Hl_roa10
The Taigen Tiger I has metal road wheel axles, secured to a metal swing arm with a 3mm set screw;
Screw needed for Taigen Tiger road wheel Img_1417
The screw in the picture looks like a Heng Long Tiger road wheel screw, or possibly one from a Taigen King Tiger.
If we can figure this out, someone here should be able to help.
Kagan
Recruit
PostSubject: Re: Screw needed for Taigen Tiger road wheel   Screw needed for Taigen Tiger road wheel Icon_minitimeFri Mar 29, 2013 8:48 pm
The sticker next to the battery cover says Taigen. It could very well be a King. Sorry, I'm new at rc tanks. Any other identifiers that I could look for? The manual says German Tiger I, Taigen 3818-1.
Kagan
Recruit
PostSubject: Re: Screw needed for Taigen Tiger road wheel   Screw needed for Taigen Tiger road wheel Icon_minitimeFri Mar 29, 2013 9:08 pm
https://servimg.com/view/18211373/10
https://servimg.com/view/18211373/11
This is the tank. I removed the screw from the exact wheel from the opposite side for the photo.
PostSubject: Re: Screw needed for Taigen Tiger road wheel   Screw needed for Taigen Tiger road wheel Icon_minitimeFri Mar 29, 2013 9:22 pm
I think I know what you may have, does does the upper hull attach with a quick release system, or screws?
Screw needed for Taigen Tiger road wheel Taigen10
PostSubject: Re: Screw needed for Taigen Tiger road wheel   Screw needed for Taigen Tiger road wheel Icon_minitimeFri Mar 29, 2013 9:36 pm
Are the swing arms plastic or metal?
Is the upper hull attached with screws, or this system in the pictures;
Screw needed for Taigen Tiger road wheel Img_1418
Screw needed for Taigen Tiger road wheel Img_1419
PostSubject: Re: Screw needed for Taigen Tiger road wheel   Screw needed for Taigen Tiger road wheel Icon_minitimeFri Mar 29, 2013 9:38 pm
I have what you need Art. Send me a PM and we can make arrangements to get it to you.
PostSubject: Re: Screw needed for Taigen Tiger road wheel   Screw needed for Taigen Tiger road wheel Icon_minitimeFri Mar 29, 2013 9:40 pm
I knew someone here would come through Very Happy
Kagan
Recruit
PostSubject: Re: Screw needed for Taigen Tiger road wheel   Screw needed for Taigen Tiger road wheel Icon_minitimeFri Mar 29, 2013 10:04 pm
Just for clarification sake, under the rear mud flaps there are #2 Philips screws. What the heck have I got? How do I reference my tank model the next time I encounter a problem? It seems there are many generations/variations and manufacturers trading under different names. Yikes!
PostSubject: Re: Screw needed for Taigen Tiger road wheel   Screw needed for Taigen Tiger road wheel Icon_minitimeFri Mar 29, 2013 10:14 pm
I suspect that you have what is basically a Heng Long Tiger I marked by Taigen.
This isn't a bad thing, since there are lots of parts, replacement and upgrade, for Heng Longs.
The threaded road wheel screw should be easy to get and I assume that is what Stinger is offering (he has an impressive collection of bits & pieces).
THe Taigen Tigers like mine are what they call HC version, some of the differences are the quick release upper hull and the way the turret goes together, your turret looks like the Heng Long turret.
I think the Heng Long parts should fit your tank.
PostSubject: Re: Screw needed for Taigen Tiger road wheel   Screw needed for Taigen Tiger road wheel Icon_minitimeFri Mar 29, 2013 10:38 pm
Correct you are Glen, it is a standard HL screw that I just went down to my parts bin and stripped out one of my Tiger parts tanks.
