Posts : 238 Join date : 2012-03-22 Age : 30 Location : Sudbury, ON
Subject: Bulldog Problem Mon Apr 02, 2012 6:59 pm
So I was running the M41 through my field when I heard an aweful grinding noise. Took it in, unscrewed it and it looks like the gears are loose on the left motor. I don't know how to solder anything and I'm afraid to pull everything apart (I'm gonna have to for the SLU installation) Can the gearbox be tightened? Also can anyone teach me how to solder or where to find one lol.
Subject: Re: Bulldog Problem Mon Apr 02, 2012 7:42 pm
Are you able to post a picture of the gears?
I got my soldering iron at Princess Auto last month, I think it was like $12. I just learn from Youtube videos and bugging Airbrushler with questions, or I get him to do it.
TeTris MoNk Sergeant
Subject: Re: Bulldog Problem Mon Apr 02, 2012 7:44 pm
They look fine but the ones on the left move side to side... which means the gear attached to the sprocket rolls freely while the others run with the motor.
Subject: Re: Bulldog Problem Mon Apr 02, 2012 7:54 pm
Do you mean the gear slides along the axis it's on?
Exactly.
Subject: Re: Bulldog Problem Mon Apr 02, 2012 8:05 pm
That is a new one for me. I'll see what I can find out.
Subject: Re: Bulldog Problem Mon Apr 02, 2012 8:06 pm
Lol in Captain's words: Phil - RC TANK WARS. I was thinking that too... would a 480 motor be realistic for a Bulldog?
Subject: Re: Bulldog Problem Mon Apr 02, 2012 9:51 pm
TAMIYA !!! JUST BUY A TAMIYA DAMIT !!!..[i]Love Panther G ....
I may have a spare sold iron , I will take a look.
So do you say the gear spins free and the motor does not spin ,when you spin the gear ? So you need a new motor, it sounds like ? Or you may be able to tap the gear back on to the drive shaft of the motor, if the motor is OK. The 480 motors are nice but if you have stock gear boxes you may tare them up ? Capt.
ho ya PHIL R/C TANK WARS ...DAMIT.....
_____________________________________________ The Great Pan-Tiger
Guest Guest
Subject: Re: Bulldog Problem Mon Apr 02, 2012 10:07 pm
i have some gears that go a bit side to side but still make contact with the other gears so i figure they are ok but sounds like you may have a problem with yours sorry i wasn't on earlier fell asleep on the couchmaybe take a pic so we can see what it's doing ?
Guest Guest
Subject: Re: Bulldog Problem Mon Apr 02, 2012 10:16 pm
oh i don't do soldering like that guy in the film he talks about tinning but looks like you waste more solder than anything..lol i use Flux paste i put some on the wire and the solder just gets sucked right onto the wire you don't have the heat on it as much as that guy in the video i think the amount of time he leaves that iron on there would do damge to a board and i use 30watts
Subject: Re: Bulldog Problem Mon Apr 02, 2012 10:33 pm
Please Remember people solder fumes are Real BAD for you, Have a fan to blow the smoke away, dont hang over what you are working on and get a face full of fumes..LEAD !!!! I have seem a few good people get the shakes from soildering over the years and it dont take much.
Flux past can rot some wires, in time.
Not Joking.
Fireman Tim Corporal
Posts : 193 Join date : 2012-03-22 Age : 51 Location : Stevensville
Subject: Re: Bulldog Problem Mon Apr 02, 2012 10:40 pm
Buy a new gear box. Easy fix.
Subject: Re: Bulldog Problem Mon Apr 02, 2012 10:44 pm
I'm not working tomorrow, gonna go to PA with my dad and pick up an solder iron. Gonna need one when I get a HE tank anyways to wire all the HL electronics.
With the 480s I was going to get steel gearboxes. I don't know if 3:1 are realistic for the Bulldog.
Yes the motor works, but the gear attached to the axle that the sprocket is screwed too isn't making contact with the rest of the gears. I'll put apart the tank tomorrow and see if there is something I can tighten.
Subject: Re: Bulldog Problem Sun Apr 15, 2012 11:09 am
Tetris, did you ever find out more about your gear box?
Subject: Re: Bulldog Problem Sun Apr 15, 2012 1:31 pm
Not yet. I'm gonna fix everything when my transmitter from HobbyKing comes in while I hook up the SLU. Thanks to Captain for the soldering iron
