Tank Arrived Let the work start! Icon_minitimeby hachleopard2 Yesterday at 7:23 pm
Tank Arrived Let the work start! Icon_minitimeby Jarlath Fri Sep 13, 2019 4:04 pm
Tank Arrived Let the work start! Icon_minitimeby Strato50 Wed Sep 11, 2019 10:50 pm
Tank Arrived Let the work start! Icon_minitimeby treemagnet Tue Sep 10, 2019 5:15 pm
Tank Arrived Let the work start! Icon_minitimeby Strato50 Tue Sep 10, 2019 3:29 am
Tank Arrived Let the work start! Icon_minitimeby knispel Tue Sep 10, 2019 1:21 am
Tank Arrived Let the work start! Icon_minitimeby Negaduck Sun Sep 08, 2019 5:09 pm
Tank Arrived Let the work start! Icon_minitimeby Strato50 Sat Sep 07, 2019 9:30 pm
Tank Arrived Let the work start! Icon_minitimeby Airbrushler Sat Sep 07, 2019 8:15 pm
Tank Arrived Let the work start! I_vote_lcapTank Arrived Let the work start! I_voting_barTank Arrived Let the work start! I_vote_rcap
Go to page : 1, 2, 3, 4  Next
White Tiger
White Tiger
Tank Arrived Let the work start! Empty
PostSubject: Tank Arrived Let the work start!   Tank Arrived Let the work start! Icon_minitimeMon Apr 29, 2013 8:35 pm
Well my tank just showed up here are some pictures so far.........
Big issue is that the damn 480 motors i bought don't fit!!!!!!! So any suggestions would be great on that one..... Debating cutting down the frame on each one but....
Tank Arrived Let the work start! 902701_10151649068247642_1854997596_o_zpsede6aad5
Tank Arrived Let the work start! 475196_10151649068777642_577770562_o_zps344d4286
Tank Arrived Let the work start! 472630_10151649067672642_1364901157_o_zpsaa862954
Tank Arrived Let the work start! 904765_10151649066747642_588891334_o_zpsed9e52c9
Tank Arrived Let the work start! Signature
White Tiger
White Tiger
PostSubject: Re: Tank Arrived Let the work start!   Tank Arrived Let the work start! Icon_minitimeMon Apr 29, 2013 8:39 pm
oh and how the bloody hell do i get the metal tracks off???
CJ781
CJ781
PostSubject: Re: Tank Arrived Let the work start!   Tank Arrived Let the work start! Icon_minitimeMon Apr 29, 2013 9:25 pm
Darth Vader will not make the tank go faster, however being able to harness the dark side of the force may be the advantage on the battle field. "you don't need to shoot this tank. This isn't the tank you're looking for. "
My Tanks = HL PzIII, HL KV-1, Tamiya Leopard (unbuilt)
White Tiger
White Tiger
PostSubject: Re: Tank Arrived Let the work start!   Tank Arrived Let the work start! Icon_minitimeMon Apr 29, 2013 9:29 pm
he also makes a great proper upper! lol
White Tiger
White Tiger
PostSubject: Re: Tank Arrived Let the work start!   Tank Arrived Let the work start! Icon_minitimeMon Apr 29, 2013 11:28 pm
Ugh the stupid Radio & Receiver wont bind now!
PostSubject: Re: Tank Arrived Let the work start!   Tank Arrived Let the work start! Icon_minitimeTue Apr 30, 2013 2:06 am
Those motors will never fit the Asiatam low profile gearbox, ever. Sorry mate.
Can we keep your tank issues to one thread please?
Which receiver did you end up getting? You need to give us clear concise info on here, most of these guys are not mind readers/are old (lol)
The metal tracks come off most easily when you remove the drive sprocket... 2.5mm hex driver, I think... you should have a nice high quality hex/Allen key set in metric if you want to work on tanks, and a nice micro screwdriver to.
White Tiger
White Tiger
PostSubject: Re: Tank Arrived Let the work start!   Tank Arrived Let the work start! Icon_minitimeTue Apr 30, 2013 2:10 am
Radio is
X6i DSMX 6-Channel Full-Range without Servo MD2
Receiver is
AR6115e 6-Channel DSMX Microlite Receiver: End Pin
I got them detected but the controls are bit wonky still (I need to program it, working on that slowly, the turret and tank move just no sound) So ya....am wondering if i just got a one off faulty sound board?
Edit:Got the turret spinning side to side & and gun flash randomly but the damn Recoil servo is down....... And the sound is just still a super high pitch whine.
Keeping the speaker unplugged well i try to get the turret working.
Tank Arrived Let the work start! 20130429_222808_zpsfc5946bc
Tank Arrived Let the work start! 20130429_222847_zps55822b65
Tank Arrived Let the work start! 20130429_222802_zpsa0bceb3f
PostSubject: Re: Tank Arrived Let the work start!   Tank Arrived Let the work start! Icon_minitimeTue Apr 30, 2013 4:53 am
I assume you're using the 'real recoil' function and a servo on this Tiger.. first off make sure the servos are plugged in the right way, on my Hitech's the black wire side is facing AWAY from the board. When I accidentally had mine in backwards, I got a high pitched whine like you described (and obviously the servo won't work at all plugged in backwards)
What recoil unit are you using (barrel recoil right?) Describe the flash issue.
White Tiger
White Tiger
PostSubject: Re: Tank Arrived Let the work start!   Tank Arrived Let the work start! Icon_minitimeTue Apr 30, 2013 5:02 am
hmm well i took the turret off and found this inside
Tank Arrived Let the work start! 902762_10151649566877642_773488531_o_zpscd9e35e3
Tank Arrived Let the work start! 920375_10151649567232642_674865375_o_zps068ef0cf
I thought it was a barrel recoil but turns out that isn't the case from what i can see..........Starting to feel a bit worried about my purchase but once i get the remote set up i will hopefully have better luck testing. (Running it when i get up with no top to see if i can get the sound going and im going to give it a good cleaning since the gears inside the turret maybe seized)
OH and uh.....Anyone know what the weird switch in the top of the turret maybe? i am afraid to flip it lol (the odd capacitor doesn't help)
Also as i have never programmed a Radio before maybe just getting the bottom going should be a start...... But i did this like a guide i found said.
Tiger 1
TRAVEL ADJ
THROT ^100% v 35%
ELEV ^125% V125%
GEAR ^100% V100%
AILE <100% >100%
RUDD <80% >59%
FLAP ^100% V100%
SUB TRIM
ELEV ^15
FLAPS Set to 100 both directions
MIX 1
GEAR > ELEV ACT
RATE D +125% U 0%
SW MIX TRIM INH
MIX 2
GEAR > ELEV ACT
RATE D-125% U 0%
SW AIL D/R TRIM ACT
DIFFERENTIAL
INHIBIT
PostSubject: Re: Tank Arrived Let the work start!   Tank Arrived Let the work start! Icon_minitimeTue Apr 30, 2013 5:16 am
That's the asiatam recoil & elevation unit, it does both.. the gears aren't ceased, theyre plastic.. they just wont turn because its on a worm gear. Don't try Razz
Read this
http://www.rcuniverse.com/forum/m_11137871/mpage_20/tm.htm
White Tiger
White Tiger
PostSubject: Re: Tank Arrived Let the work start!   Tank Arrived Let the work start! Icon_minitimeTue Apr 30, 2013 5:24 am
Read this
Hmmm Interesting! I am wondering if that was already done because of the odd wireing inside the turret......or is this the stock wiring >_@
PostSubject: Re: Tank Arrived Let the work start!   Tank Arrived Let the work start! Icon_minitimeTue Apr 30, 2013 5:25 am
That's stock and you'll have to cut it all off and start fresh Razz
Good luck! Hope you're good at soldering.
White Tiger
White Tiger
PostSubject: Re: Tank Arrived Let the work start!   Tank Arrived Let the work start! Icon_minitimeTue Apr 30, 2013 5:26 am
My brother is a pro at it >_> my iron died so ill have him do it or just go buy a cheap one lol so its safe to say i can cut all the wires in the turret now and get a new switch for the power and so on?
AKA:All top wire go snip snip >Very Happy
PostSubject: Re: Tank Arrived Let the work start!   Tank Arrived Let the work start! Icon_minitimeTue Apr 30, 2013 5:39 am
Well figure out what you have and what you need to do...
Both motors need to come down to the Clark board & plug in, and the black switch needs to plug into the extensions in the switch wiring. The 'bigger' switch on top in your picture, with the black and red wire, is useless and you don't need it.
Read my guide.
White Tiger
White Tiger
PostSubject: Re: Tank Arrived Let the work start!   Tank Arrived Let the work start! Icon_minitimeTue Apr 30, 2013 5:43 am
I am it would seem this might be why my tank wasn't work right in general due to the power going to the turret funny.... Will update tomorrow! I think the black thing inside the turret is the Ir or flash? (also would appear i need to buy some connectors...)
PostSubject: Re: Tank Arrived Let the work start!   Tank Arrived Let the work start! Icon_minitimeTue Apr 30, 2013 5:46 am
Both motors need to come down to the upper hull & plug in, the 8-pin connector powers both recoil & elevation, i think.. and the black switch needs to plug into the extensions in the switch wiring. The 'bigger' switch on top in your picture, with the black and red wire, is useless and you don't need it.
Read my guide.
PostSubject: Re: Tank Arrived Let the work start!   Tank Arrived Let the work start! Icon_minitimeTue Apr 30, 2013 5:55 am
where did you get this tank from ask if the recoil worked you might just have to lube it up or something
to me it looks like your speaker has all the wires connecting only two wires should be on there and seperated from eachother might be why mo sound
Tank Arrived Let the work start! Soviet10
White Tiger
White Tiger
PostSubject: Re: Tank Arrived Let the work start!   Tank Arrived Let the work start! Icon_minitimeTue Apr 30, 2013 6:00 am
Ill take a look but they should be seperate, Also just took the turret apart more and the recoil screw's area to hold in has been cracked and glued back to hide the damage -_-
PostSubject: Re: Tank Arrived Let the work start!   Tank Arrived Let the work start! Icon_minitimeTue Apr 30, 2013 6:03 am
should be black on one tab and red on the other tab looks like black one goes to the red one with a little black wire then then both red and black long wires are on one tab
PostSubject: Re: Tank Arrived Let the work start!   Tank Arrived Let the work start! Icon_minitimeTue Apr 30, 2013 6:10 am
i don't know what you see but i see the wires on one tab i zoomed in and looks like black and red wires are soldered on same tab
Tank Arrived Let the work start! Speake10
White Tiger
White Tiger
PostSubject: Re: Tank Arrived Let the work start!   Tank Arrived Let the work start! Icon_minitimeTue Apr 30, 2013 6:20 am
Ok that might just be it....i copied how the old speaker was set up here are some pictures......Maybe i did mess it up! On a side note the recoil unit is damaged so i have no idea what to do..........This doesn't seem exactly reliable....There is also a hot glued split d own the connector for the barrel....
Tank Arrived Let the work start! 20130430_030853_zpsbc87bf53Tank Arrived Let the work start! 20130430_030840_zps28eca268Tank Arrived Let the work start! 20130430_030740_zps9f0df67a
lol that was part of the receiver that was under it, I am starting to wonder if i got taken on this tank.........I am slowly looking for more hot glue all over to see if anything else is broken.
PostSubject: Re: Tank Arrived Let the work start!   Tank Arrived Let the work start! Icon_minitimeTue Apr 30, 2013 6:53 am
If you clean that up and use some super glue it will be good as new.
A good quality hobby CA (superglue) is necessary for hobbies Very Happy
White Tiger
White Tiger
PostSubject: Re: Tank Arrived Let the work start!   Tank Arrived Let the work start! Icon_minitimeTue Apr 30, 2013 6:55 am
Fair enough, But im still rather ticked the guy lied to me about it and said there where no problems at all.
PostSubject: Re: Tank Arrived Let the work start!   Tank Arrived Let the work start! Icon_minitimeTue Apr 30, 2013 7:08 am
My tanks are glued together and have no problems either Wink
White Tiger
White Tiger
PostSubject: Re: Tank Arrived Let the work start!   Tank Arrived Let the work start! Icon_minitimeTue Apr 30, 2013 4:30 pm
Well i think my board might be cooked....... I have lost my ability to control my tank at all.....But power is flowing so i am pretty confused as to what is going on.
As much as i hate to say it this might of been a bad purchase and beyond my ability to get running. (I have to go find the multi-meter to check out the batteries....)
Page 1 of 4Go to page : 1, 2, 3, 4  Next
