HL Panther G Idler Mount Repair Icon_minitimeby MikeC Today at 12:01 am
HL Panther G Idler Mount Repair Icon_minitimeby Airbrushler Yesterday at 5:33 pm
HL Panther G Idler Mount Repair Icon_minitimeby Strato50 Wed Sep 18, 2019 8:49 pm
HL Panther G Idler Mount Repair Icon_minitimeby hachleopard2 Sat Sep 14, 2019 7:23 pm
HL Panther G Idler Mount Repair Icon_minitimeby Jarlath Fri Sep 13, 2019 4:04 pm
HL Panther G Idler Mount Repair Icon_minitimeby Strato50 Wed Sep 11, 2019 10:50 pm
HL Panther G Idler Mount Repair Icon_minitimeby treemagnet Tue Sep 10, 2019 5:15 pm
HL Panther G Idler Mount Repair Icon_minitimeby Strato50 Tue Sep 10, 2019 3:29 am
HL Panther G Idler Mount Repair Icon_minitimeby Negaduck Sun Sep 08, 2019 5:09 pm
HL Panther G Idler Mount Repair I_vote_lcapHL Panther G Idler Mount Repair I_voting_barHL Panther G Idler Mount Repair I_vote_rcap
HL Panther G Idler Mount Repair Empty
PostSubject: HL Panther G Idler Mount Repair   HL Panther G Idler Mount Repair Icon_minitimeFri Jun 28, 2013 8:47 am
While I was installing the new 400 Motors in the Panther 435, I noticed the right, rear idler repair I did in 2010 was not holding and the crack had returned.
This was my first tank, bought in 2010 and the assembly people at HL had used 3/8" impact guns to tighten the fasteners Shocked  so when I did the rebuild/refinish last year, I did a lot of repairs.  Most held but the plastic collar glued around the idler mount did not.
The idler mount had an O.D. of .435", and was tough to get a piece of metal tube of the right diameter to fit.
Then I got looking at a fired .30-06 cartridge, it looked close, so I cut one and found it to be .405" I.D.
I got the idea to cut some notches in the cut end, to make a (very) crude milling tool.  I chucked this up in the 3/8" variable speed drill and milled down the O.D. of the mount, it took it to the same size as the I.D. of the cartridge case.
I took another case and made a 1/8" wide ring from it which fit the milled end of the idler mount.  Then I glued it in place and painted it to match.
Posting this as a tip was an after thought, so I did not take pictures of the whole process Embarassed
HL Panther G Idler Mount Repair Repair10
HL Panther G Idler Mount Repair Repair11
PostSubject: Re: HL Panther G Idler Mount Repair   HL Panther G Idler Mount Repair Icon_minitimeFri Jun 28, 2013 11:33 am
So far Glen, we've seen you fix your tanks with aluminum arrow shafts and bullet casings.
I'd love to see what you could with a ammo shell from a tank! geek
