| Strato's Sd.Kfz. 251/22 Halftrack | |
| Subject: Re: Strato's Sd.Kfz. 251/22 Halftrack Wed Sep 04, 2013 9:42 pm | |
| SO!!..
I got 4x of the micro gear motors from Servo City to use in these monsters.
2 out of the 4 motors in my package JUST DONT WORK. No response to power at all. Wow.
Having really sh*tty luck with these things... I'm amazed at this cr*p... ><
Anyhoo.. the story continues... dealing with Servo City now to fix this...
Sigh... _____________________________________________ Tiger I - Panzer II - Panzer III - Panzer IV - Chi Nu Kai - Panther G - KV-1b 756(r) M4A3(76) Sherman - T-34/85 - M3 Grant - SECRET PROJECT
| Subject: Re: Strato's Sd.Kfz. 251/22 Halftrack Tue Sep 10, 2013 8:14 am | |
| Did some work on the steering arrangement. So far so good, these pivoting servo connectors came in real handy. _____________________________________________ Tiger I - Panzer II - Panzer III - Panzer IV - Chi Nu Kai - Panther G - KV-1b 756(r) M4A3(76) Sherman - T-34/85 - M3 Grant - SECRET PROJECT
Posts : 2374 Join date : 2012-03-21 Age : 50 Location : Windsor, Ontario
| Subject: Re: Strato's Sd.Kfz. 251/22 Halftrack Tue Sep 10, 2013 12:03 pm | |
| Won't the protruding bolt head snag something when driving off road?
| Subject: Re: Strato's Sd.Kfz. 251/22 Halftrack Tue Sep 10, 2013 12:29 pm | |
| Probably yes, but it's only about 1/4 below the front bumper and higher up above ground level than I thought.. I think it'll be ok. _____________________________________________ Tiger I - Panzer II - Panzer III - Panzer IV - Chi Nu Kai - Panther G - KV-1b 756(r) M4A3(76) Sherman - T-34/85 - M3 Grant - SECRET PROJECT
| Subject: Re: Strato's Sd.Kfz. 251/22 Halftrack Fri Sep 20, 2013 3:30 am | |
| Subject: Re: Strato's Sd.Kfz. 251/22 Halftrack Fri Sep 20, 2013 9:25 am | |
| It looks like a good fit Jordan. Can't wait to get started on mine. _____________________________________________ HL Panzer III | HL Tiger | HL Jagdpanther | HL Panther | Mato Sherman Hooben Elefant | HL Pershing | HL Bergepanzer IV | Tamiya Leopard 1A | WSN T-34 HL "Golden" Pan-Tiger | M16 Halftrack | HL Panzer IV | Tamiya KV-1 | Tamiya Tiger
| Subject: Re: Strato's Sd.Kfz. 251/22 Halftrack Fri Sep 20, 2013 10:54 am | |
| It is Derek! I cut the plastic hull in such a way that as things are now, it manages to hold the transmission in place without glue or anything. Of course I'll later epoxy it and probably reinforce with some styrene but it's nice to have it 'line replaceable' should things break.
Also the sprocket offset is a bit wide. I can either trim the gearbox ends to bring them closer to the hull, or just reattach the road wheels a few millimeters outward. I'm leaning towards widening the road wheels.. should give better turning & less rollovers *COUGHFRANKCOUGH* _____________________________________________ Tiger I - Panzer II - Panzer III - Panzer IV - Chi Nu Kai - Panther G - KV-1b 756(r) M4A3(76) Sherman - T-34/85 - M3 Grant - SECRET PROJECT
| Subject: Re: Strato's Sd.Kfz. 251/22 Halftrack Fri Sep 20, 2013 11:21 am | |
| Wider is always better on the field. Are you bring it on Sunday so I can take some notes. _____________________________________________ HL Panzer III | HL Tiger | HL Jagdpanther | HL Panther | Mato Sherman Hooben Elefant | HL Pershing | HL Bergepanzer IV | Tamiya Leopard 1A | WSN T-34 HL "Golden" Pan-Tiger | M16 Halftrack | HL Panzer IV | Tamiya KV-1 | Tamiya Tiger
| Subject: Re: Strato's Sd.Kfz. 251/22 Halftrack Fri Sep 20, 2013 8:57 pm | |
| It'll be there, no flash photography though.. _____________________________________________ Tiger I - Panzer II - Panzer III - Panzer IV - Chi Nu Kai - Panther G - KV-1b 756(r) M4A3(76) Sherman - T-34/85 - M3 Grant - SECRET PROJECT
| Subject: Re: Strato's Sd.Kfz. 251/22 Halftrack Mon Sep 23, 2013 2:03 am | |
| You might be amazed but it's 2am the same "day" as our meet, I'm still awake & at work, BUILDING A HALF-TRACK! Woohoo Anyhoo, some progress. I changed my mind and decided to 'even out' the width of the drive sprockets. I had to grind down the final drive shaft a bit, and also the outside collar of the transmission unit, which brought the drive sprocket closer to the hull by about 1/8". They are now even. I glued some thick styrene sheets in between the road-wheel plates and the hull, the same width on each side. Now the wheels are a bit further from the hull. This gives the wider track more clearance and also lines up the drive sprockets with the road wheels! I'm very happy with how this is going. _____________________________________________ Tiger I - Panzer II - Panzer III - Panzer IV - Chi Nu Kai - Panther G - KV-1b 756(r) M4A3(76) Sherman - T-34/85 - M3 Grant - SECRET PROJECT
Reaper332 Sgt-Major
| Subject: Re: Strato's Sd.Kfz. 251/22 Halftrack Mon Sep 23, 2013 2:11 am | |
| Nice work Strato.......... |
Negaduck Captain
Posts : 816 Join date : 2013-01-03 Age : 40 Location : Grafton Ontario
| Subject: Re: Strato's Sd.Kfz. 251/22 Halftrack Mon Sep 23, 2013 11:17 am | |
| you're nuts to stay up that late to work on this lol _____________________________________________ I do things in the name of science but first hold my beer
| Subject: Re: Strato's Sd.Kfz. 251/22 Halftrack Mon Sep 23, 2013 11:28 am | |
| Oh! What I meant by "at work" was that I was physically AT work, nightshift @ the airport fixing the airplanes (And halftracks)
I made some more progress but pictures later... Zzzzzzzz _____________________________________________ Tiger I - Panzer II - Panzer III - Panzer IV - Chi Nu Kai - Panther G - KV-1b 756(r) M4A3(76) Sherman - T-34/85 - M3 Grant - SECRET PROJECT
| Subject: Re: Strato's Sd.Kfz. 251/22 Halftrack Mon Sep 23, 2013 6:38 pm | |
| At least you have your priorities straight .......nice work by the way |
| Subject: Re: Strato's Sd.Kfz. 251/22 Halftrack Mon Sep 23, 2013 6:58 pm | |
| nice job Jordan look like it was a stock item _____________________________________________ |
| Subject: Re: Strato's Sd.Kfz. 251/22 Halftrack Tue Sep 24, 2013 1:51 pm | |
| Thanks Greg, again I'm really happy with how it's going together. I did some more work, got the tracks installed without a single issue. Test fit various internal layouts and what works best is the Clark board in the rear, speaker up front and a 1700mAh 7.2v battery wedged in between. It all fits perfectly, even with the big gun mount in the way. I did some more work on the front steering & suspension, and even went a LITTLE crazy (Im a engineer so.. we do that..) added my own leaf springs! It slightly pushes the wheels onto the ground and keeps them from rubbing on the fenders. Works perfect. _____________________________________________ Tiger I - Panzer II - Panzer III - Panzer IV - Chi Nu Kai - Panther G - KV-1b 756(r) M4A3(76) Sherman - T-34/85 - M3 Grant - SECRET PROJECT
| Subject: Re: Strato's Sd.Kfz. 251/22 Halftrack Tue Sep 24, 2013 6:19 pm | |
| It look good Jordan! I hope to start mine this weekend.
Are you using metal or plastic tracks? I've got both. _____________________________________________ HL Panzer III | HL Tiger | HL Jagdpanther | HL Panther | Mato Sherman Hooben Elefant | HL Pershing | HL Bergepanzer IV | Tamiya Leopard 1A | WSN T-34 HL "Golden" Pan-Tiger | M16 Halftrack | HL Panzer IV | Tamiya KV-1 | Tamiya Tiger
| Subject: Re: Strato's Sd.Kfz. 251/22 Halftrack Tue Sep 24, 2013 7:03 pm | |
| awesome work _____________________________________________ |
| Subject: Re: Strato's Sd.Kfz. 251/22 Halftrack Wed Sep 25, 2013 2:53 am | |
| Plastic tracks. I occasionally hear them jumping off the sprocket, but it isn't consistent at all. Usually while turning very sharp. They pop right back into the sprocket and I've yet to lose a track. It's not very fast, probably about the same as some of our slowest tanks with reduced gears. I have a few ideas about how these vehicles can be used strategically in battle... _____________________________________________ Tiger I - Panzer II - Panzer III - Panzer IV - Chi Nu Kai - Panther G - KV-1b 756(r) M4A3(76) Sherman - T-34/85 - M3 Grant - SECRET PROJECT
pzkpfw_steve Lance Corporal
Posts : 92 Join date : 2013-07-09 Location : Hamilton, On.
| Subject: Re: Strato's Sd.Kfz. 251/22 Halftrack Wed Sep 25, 2013 3:25 pm | |
| starting to look nice! _____________________________________________ My Tanks: HL - Pershing, Pz III/IV My Blog |
Posts : 3159 Join date : 2013-08-25 Location : Toronto, Ontario
| Subject: Re: Strato's Sd.Kfz. 251/22 Halftrack Wed Sep 25, 2013 5:05 pm | |
| Derek,
You are using PzIII plastic tracks, right ? I have the Stuka zu Fuss version and would love to do what you have done but don't think I have the skill set. I did fit it with a set of metal FAMO tracks from Asiatam and it fits perfect. Maybe I will tried to just fit the Vs motor in and leave the front steering stock. The sucker won't turn but at least it will run !
Amazing work.
Mike. |
| Subject: Re: Strato's Sd.Kfz. 251/22 Halftrack Wed Sep 25, 2013 11:07 pm | |
| Hey Mike, yea they're Panzer III/IV tracks (same thing). If the front end seems tough you can always set up some kind of dummy castor system, so the wheels just follow the direction of the vehicle. Everything else is just a matter of careful use of a file, hobby saw and knife.
-Jordan _____________________________________________ Tiger I - Panzer II - Panzer III - Panzer IV - Chi Nu Kai - Panther G - KV-1b 756(r) M4A3(76) Sherman - T-34/85 - M3 Grant - SECRET PROJECT
| Subject: Re: Strato's Sd.Kfz. 251/22 Halftrack Thu Sep 26, 2013 9:33 am | |
| Sorry Jordan....... It would be nice to have a who is who for Newbies here. Just one more question, which motor did you end up using or it doesn't matter ? I noticed that on the Vs Tank Page the motors are with the individual tanks and not in the common parts section.
The castor is a great idea. I might even try just putting the track motors in and run it and see what happens.
Mike. |
| Subject: Re: Strato's Sd.Kfz. 251/22 Halftrack Thu Sep 26, 2013 11:10 am | |
| I ordered the Tiger I gears. I choose them mostly because someone on RCU had actually measured theres and posted pictures. So I knew almost for sure what I was getting and how they'd fit.
There's an introduction page somewhere, hehe, I think it hasn't been posted on in awhile, but if you find it say hello!! _____________________________________________ Tiger I - Panzer II - Panzer III - Panzer IV - Chi Nu Kai - Panther G - KV-1b 756(r) M4A3(76) Sherman - T-34/85 - M3 Grant - SECRET PROJECT
| Subject: Re: Strato's Sd.Kfz. 251/22 Halftrack Thu Sep 26, 2013 11:31 am | |
| Subject: Re: Strato's Sd.Kfz. 251/22 Halftrack | |
