HL Panther G Idler Mount Repair Icon_minitimeby dgsselkirk Today at 10:43 am
» Hello new here
HL Panther G Idler Mount Repair Icon_minitimeby Hammertime999999999 Today at 6:49 am
HL Panther G Idler Mount Repair Icon_minitimeby Hammertime999999999 Today at 6:11 am
HL Panther G Idler Mount Repair Icon_minitimeby dgsselkirk Yesterday at 2:04 pm
» 2024 CLUB DUES.....
HL Panther G Idler Mount Repair Icon_minitimeby dgsselkirk Yesterday at 1:07 pm
» Taigen KV metal swing arms
HL Panther G Idler Mount Repair Icon_minitimeby MikeC Sat Mar 23, 2024 6:10 pm
HL Panther G Idler Mount Repair Icon_minitimeby Hammertime999999999 Sat Mar 23, 2024 1:41 pm
» HERITAGECON 2024
HL Panther G Idler Mount Repair Icon_minitimeby Negaduck Fri Mar 22, 2024 7:38 pm
» New member
HL Panther G Idler Mount Repair Icon_minitimeby Hammertime999999999 Fri Mar 22, 2024 2:58 pm
HL Panther G Idler Mount Repair I_vote_lcapHL Panther G Idler Mount Repair I_voting_barHL Panther G Idler Mount Repair I_vote_rcap
Bktanker
HL Panther G Idler Mount Repair Empty
PostSubject: HL Panther G Idler Mount Repair   HL Panther G Idler Mount Repair Icon_minitimeFri Jun 28, 2013 8:47 am
While I was installing the new 400 Motors in the Panther 435, I noticed the right, rear idler repair I did in 2010 was not holding and the crack had returned.
This was my first tank, bought in 2010 and the assembly people at HL had used 3/8" impact guns to tighten the fasteners Shocked  so when I did the rebuild/refinish last year, I did a lot of repairs.  Most held but the plastic collar glued around the idler mount did not.
The idler mount had an O.D. of .435", and was tough to get a piece of metal tube of the right diameter to fit.
Then I got looking at a fired .30-06 cartridge, it looked close, so I cut one and found it to be .405" I.D.
I got the idea to cut some notches in the cut end, to make a (very) crude milling tool.  I chucked this up in the 3/8" variable speed drill and milled down the O.D. of the mount, it took it to the same size as the I.D. of the cartridge case.
I took another case and made a 1/8" wide ring from it which fit the milled end of the idler mount.  Then I glued it in place and painted it to match.
Posting this as a tip was an after thought, so I did not take pictures of the whole process Embarassed
HL Panther G Idler Mount Repair Repair10
HL Panther G Idler Mount Repair Repair11
PostSubject: Re: HL Panther G Idler Mount Repair   HL Panther G Idler Mount Repair Icon_minitimeFri Jun 28, 2013 11:33 am
So far Glen, we've seen you fix your tanks with aluminum arrow shafts and bullet casings.
I'd love to see what you could with a ammo shell from a tank! geek
» Internal barrel mount for HL Panther G
» Pz IV Repair Video
» Repair Tanks
» PVC Frame to service/repair my tanks
» Repair M1 Abrams tank facility
