Gearbox "Ratios" Icon_minitimeby MikeC Today at 12:01 am
Gearbox "Ratios" Icon_minitimeby Airbrushler Yesterday at 5:33 pm
Gearbox "Ratios" Icon_minitimeby Strato50 Wed Sep 18, 2019 8:49 pm
Gearbox "Ratios" Icon_minitimeby hachleopard2 Sat Sep 14, 2019 7:23 pm
Gearbox "Ratios" Icon_minitimeby Jarlath Fri Sep 13, 2019 4:04 pm
Gearbox "Ratios" Icon_minitimeby Strato50 Wed Sep 11, 2019 10:50 pm
Gearbox "Ratios" Icon_minitimeby treemagnet Tue Sep 10, 2019 5:15 pm
Gearbox "Ratios" Icon_minitimeby Strato50 Tue Sep 10, 2019 3:29 am
Gearbox "Ratios" Icon_minitimeby Negaduck Sun Sep 08, 2019 5:09 pm
Gearbox "Ratios" I_vote_lcapGearbox "Ratios" I_voting_barGearbox "Ratios" I_vote_rcap
 Gearbox "Ratios"
Gearbox "Ratios" Empty
PostSubject: Gearbox "Ratios"   Gearbox "Ratios" Icon_minitimeTue Jul 23, 2013 6:31 am
Hey guys,
I was curious as to whether anyone has ever published / figured out the ACTUAL gear ratios of the popular HL-based aftermarket gearboxes.
For example the number of motor rotations required for a single rotation of the output shaft.
I can guarantee that between the Asiatam, Taigen, HL and Mato "3:1" gears there is a significant difference in ratio. Same goes for a few of the "4:1" gears, which judging from pictures, are similar in ratio to the 3:1!
I'd like to know, because most of the time I've wanted slow, high torque tanks because of our field conditions, but lately I'm very tempted to make something fast.. Wink
doug818tiger
PostSubject: Re: Gearbox "Ratios"   Gearbox "Ratios" Icon_minitimeTue Jul 23, 2013 10:42 am
There is a formula I use in the boat industry for gear ratios it should be the same for all gear ratios that happen throu out life aside from planetary gear sets they have a special formula to figure them out because there is 3 different ratios possible and a revese for each planatary set
doug818tiger
PostSubject: Re: Gearbox "Ratios"   Gearbox "Ratios" Icon_minitimeTue Jul 23, 2013 9:41 pm
Formula .....the # of teeth on driven gear divided by # of teeth on drive gear note this does not apply to planatarys
Freakydude
Freakydude
PostSubject: Re: Gearbox "Ratios"   Gearbox "Ratios" Icon_minitimeWed Jul 24, 2013 7:11 pm
bay area tankers has a really good calculator to figure out your tank speed
http://www.bayareatankers.org/Intelligence/Article_09/Scale_Tank_Speed_Calulations_Table_.htm
if your bored and you need to crunch some numbers
PostSubject: Re: Gearbox "Ratios"   Gearbox "Ratios" Icon_minitimeWed Jul 24, 2013 7:14 pm
Cool Razz
Ive been searching around the gearbox market, and although I really don't need a set I've found a few examples of 'newer' heavy duty sets, including a 'standard' HL ration with steel gears and bearings on rctank.de, but those guys are pricey.
Curtis I really like the set you had and I think Knipsel purchased, very smooth,
Any idea who MAKES these?
Gearbox "Ratios" Tg200010
Freakydude
Freakydude
PostSubject: Re: Gearbox "Ratios"   Gearbox "Ratios" Icon_minitimeWed Jul 24, 2013 8:02 pm
made by Heng Long my friend ( Well they are the ones that brand them, like everything from Asia it would be impossible to tell you who actually does make them.
By the way I will be constantly stocking them, Knispels was the last set I had but I have more on order, should be here in about a week.
I think I am going to try and move a bigger pinion in one set just to see how the speed will get reduced.
doug818tiger
PostSubject: Re: Gearbox "Ratios"   Gearbox "Ratios" Icon_minitimeWed Jul 24, 2013 9:56 pm
The waltersons gear set I'm my Sherman is extramly smooth its all brass
Gearbox "Ratios"
