Reapers Hummel Icon_minitimeby hachleopard2 Yesterday at 7:23 pm
Reapers Hummel Icon_minitimeby Jarlath Fri Sep 13, 2019 4:04 pm
Reapers Hummel Icon_minitimeby Strato50 Wed Sep 11, 2019 10:50 pm
Reapers Hummel Icon_minitimeby treemagnet Tue Sep 10, 2019 5:15 pm
Reapers Hummel Icon_minitimeby Strato50 Tue Sep 10, 2019 3:29 am
Reapers Hummel Icon_minitimeby knispel Tue Sep 10, 2019 1:21 am
Reapers Hummel Icon_minitimeby Negaduck Sun Sep 08, 2019 5:09 pm
Reapers Hummel Icon_minitimeby Strato50 Sat Sep 07, 2019 9:30 pm
Reapers Hummel Icon_minitimeby Airbrushler Sat Sep 07, 2019 8:15 pm
Reapers Hummel I_vote_lcapReapers Hummel I_voting_barReapers Hummel I_vote_rcap
 Reapers Hummel
Go to page : 1, 2  Next
Reaper332
Reaper332
Reapers Hummel Empty
PostSubject: Reapers Hummel   Reapers Hummel Icon_minitimeWed Aug 07, 2013 4:35 am
Hi everyone, got my Hummel kit in the mail today.... ;D ;D really looking forward to this build as I have wanted one for quite awhile, this one I got came with a few extra and I have also ordered from Daryl Turner a gearbox kit to allow me to run Tamiya gearboxes and also a spring adjusted idler kit. Both these kits are custom made and should make the Hummel a nice runner...... WinkWink
Very happy with the detail and the quality of the kit, its very close to Tamiya quality in the mouldings and its quite a large tank too.
Reapers Hummel Img_5925
Reapers Hummel Img_5926
Reapers Hummel Stugad10
Reapers Hummel Idleri10
Reapers Hummel Img_5927
Reapers Hummel Img_5928
Reapers Hummel Img_5929
PostSubject: Re: Reapers Hummel   Reapers Hummel Icon_minitimeWed Aug 07, 2013 8:09 am
i always like the Hummel and the Wespe can't wait to see  what you do to it and when you finish it
Reapers Hummel Soviet10
tomzag
PostSubject: Re: Reapers Hummel   Reapers Hummel Icon_minitimeWed Aug 07, 2013 10:25 am
NIce build so far. here was the one i built for a client.
http://rctankart.com/fohummel.asp
Reaper332
Reaper332
PostSubject: Re: Reapers Hummel   Reapers Hummel Icon_minitimeThu Aug 08, 2013 2:37 am
Thanks guys.....
Nice Hummel Tomzag, can I ask how you did the recoil and elevation/traverse in the one you did.
Cheers Ken
tomzag
PostSubject: Re: Reapers Hummel   Reapers Hummel Icon_minitimeThu Aug 08, 2013 11:00 am
Ken,
It was sold long time ago. otherwise i can take some pictures inside.
All gun traverse, elevation and recoil were hiden inside the hull.
the traverse, attach an arm to the axle undermeath the hull, so you use servo to pull it back forth.
gun elevation is the easiest, a servo underneath pull the arm through a hole, the arm attached to the gun bottom.
the recoile is the hardest, you have to drill a hole in the rod which connect the gun bottom and hull, there is a wire pulling the gun back through two roller hiden inside the gun. when the recoil unit recover, the spring in the gun push the gun back to original position.
hard to explain, it is easier to show you in person.
Reaper332
Reaper332
PostSubject: Re: Reapers Hummel   Reapers Hummel Icon_minitimeThu Aug 08, 2013 5:15 pm
Thanks Tomzag,
I am not sure if mine will recoil yet definately doing traverse and elevation. Hopefully mibe well turn out as nice as yhe obe you did.
Cheers Ken
tomzag
PostSubject: Re: Reapers Hummel   Reapers Hummel Icon_minitimeThu Aug 08, 2013 5:27 pm
Ken, you definitely need to beef up your chassis. check the pic here
http://rctankart.com/nashorn.asp
Reaper332
Reaper332
PostSubject: Re: Reapers Hummel   Reapers Hummel Icon_minitimeThu Aug 08, 2013 6:48 pm
Nice I like that.
So I should plate both sides and the bottom on the inside. I see also you used the working suspension is it any good.
Cheers Ken
tomzag
PostSubject: Re: Reapers Hummel   Reapers Hummel Icon_minitimeThu Aug 08, 2013 6:55 pm
suspension from kk is ok, but need work to make them not wigglely. the road wheels and return rollers got to be replaced by metal ones. check ebay and see if you can find them. I still have one set if you are interested.
Reaper332
Reaper332
PostSubject: Re: Reapers Hummel   Reapers Hummel Icon_minitimeThu Aug 08, 2013 7:07 pm
most definitely interested mate.... how much do you want for them and will they go on tje standard suspension...?
tomzag
PostSubject: Re: Reapers Hummel   Reapers Hummel Icon_minitimeThu Aug 08, 2013 7:08 pm
pm sent
doug818tiger
PostSubject: Re: Reapers Hummel   Reapers Hummel Icon_minitimeThu Aug 08, 2013 9:47 pm
Very nice how is the build as for parts fitting correctly and parts finish ...I know from some of my former tamiya kits I have done sometimes they can get a little sloppy on flashing or miss alighned parts ..just asking basicly ....quality.......
Reaper332
Reaper332
PostSubject: Re: Reapers Hummel   Reapers Hummel Icon_minitimeThu Aug 08, 2013 11:38 pm
Hey mate I have found it to be pretty dam good actually and was a bit surprised of how good it was and how good the parts fitted together.
tomzag
PostSubject: Re: Reapers Hummel   Reapers Hummel Icon_minitimeThu Aug 15, 2013 11:49 pm
Just sold my nashorn. It is gone, i can not afford to keep it. Crying or Very sad
Reaper332
Reaper332
PostSubject: Re: Reapers Hummel   Reapers Hummel Icon_minitimeSat Aug 17, 2013 4:15 am
Sorry to hear that Tom, it was very nicely done.
Well Everyone I have done some work to the Hummel over the last couple of days. The upper hull is finished, the gun assembly is yet too be finished as is the lower hull just waiting on some parts to turn up... ( Thanks Tom )
Here are a couple pics of it mocked up with the standard gearboxes while I am awaiting for parts to arrive.
Cheers Ken
Reapers Hummel Img_5936
Reapers Hummel Img_5937
Reapers Hummel Img_5938
Reapers Hummel Img_5939
Reapers Hummel Img_5940
tomzag
PostSubject: Re: Reapers Hummel   Reapers Hummel Icon_minitimeSat Aug 17, 2013 7:13 am
really nice, realy nice. pls check the tracking number in paypal.
PostSubject: Re: Reapers Hummel   Reapers Hummel Icon_minitimeSat Aug 17, 2013 10:48 am
what a beauty, Great job now i want one...one day
PostSubject: Re: Reapers Hummel   Reapers Hummel Icon_minitimeSat Aug 17, 2013 1:03 pm
Can't wait to see it with some paint, good job so far! thumbs up
Reaper332
Reaper332
PostSubject: Re: Reapers Hummel   Reapers Hummel Icon_minitimeSat Aug 17, 2013 5:07 pm
Thanks guys its fast becoming my favourite tank......thumbs up
Thanks Tom yeah already tracking the parcel you sent......thumbs up
Reaper332
Reaper332
PostSubject: Re: Reapers Hummel   Reapers Hummel Icon_minitimeFri Aug 23, 2013 6:27 pm
The parts from Tom turned up yesterday...... they are fantastic and he gave me heaps of parts so a HUGE thank Tom for everything.
Also the parts from Daryl Turner turned up as well so the build can move on now................thumbs up
Cheers Ken
Reapers Hummel Img_6025
Reapers Hummel Img_6026
PostSubject: Re: Reapers Hummel   Reapers Hummel Icon_minitimeFri Aug 23, 2013 6:34 pm
Oh wow.. what is all that stuff in the lower pic?
PostSubject: Re: Reapers Hummel   Reapers Hummel Icon_minitimeFri Aug 23, 2013 6:56 pm
don't forget to keep it refrigerated...lol
Reaper332
Reaper332
PostSubject: Re: Reapers Hummel   Reapers Hummel Icon_minitimeFri Aug 23, 2013 8:01 pm
Hey Strato the parts in the lower pic are a gearbox plate to mount Tamiya gearboxes in it and drive shaft adapters and the other is a spring loaded idler set up.
I have another set of these coming as I just brought another brand new in the box Hummel cheap and going to maybe make a Nashorn ( Inspired by Tom's ) out of it.
Airbrushler you noticed the box....lol!
PostSubject: Re: Reapers Hummel   Reapers Hummel Icon_minitimeFri Aug 23, 2013 8:22 pm
yep i did...hehehe
i think Strato was wondering what all those disks were in the smaller box look like metal road wheels
Reaper332
Reaper332
PostSubject: Re: Reapers Hummel   Reapers Hummel Icon_minitimeFri Aug 23, 2013 9:57 pm
Oh yep they are the metal road wheels and in the packet are the metal return rollers.
Reapers Hummel
